厦门兴锐达自动化设备有限公司
  • ABB Masterview 卡件备件
  • 发布时间:2009/10/19 16:28:19   修改时间:2009/10/19 16:28:19 浏览次数:623
    1.01 57390001-7 D50
                                                         ABB Masterview  卡件备件
    相关型号
    ABB MASTERVIEW
    57310001MP
    DSAO130
    DSCS140
    DSPC172
    01 SB5032 ABB DSIM 2918 picture tube board (replacement)
    1.02 57120001-P DSAI130 ABB Analog Input Board, 16 channel
    1.03 57120001-FG DSAO 30 ABB Analog Output Board, 16 channel
    1.04 57350001-CU DSAV111 ABB Video Board
    1.05 5712289-A DSAX 452 ABB Basic I/O Unit, 32 AI
    1.06 57330001-Y DSBB110A ABB Shield Board
    1.07 DSBB175 ABB Shield Board
    1.08 57310001-KD DSBC172 ABB Bus Repeater (Central Rack)
    1.09 57310001-KH DSBC173 ABB Bus Repeater (I/O Rack)
    1.10 57510001-AA DSCA114 ABB RS232C Communication Board
    1.11 57310001-KY DSCL110A ABB Redundant Controller Board
    1.12 57520001-BC DSCS116 ABB Communication Module
    1.13 57310001-CM DSCS131 ABB MasterFieldbus Controller Board
    1.14 57520001-EV DSCS140 ABB MasterBus Controller Card
    1.15 57160001-AAA DSDI110A ABB Digital Input Card, 32 channnel, 24VDC
    1.16 DSDI451 ABB Expansion I/O Module, 20 DI, 12 DO
    1.17 DSDI452 ABB Basic I/O Unit, 20 DI, 12 DO
    1.18 57160001-NF DSDO115 ABB Digital Output Card, 32 channel, 24VDC
    1.19 57160001-AK DSDO120 ABB Digital Output Card, 16 channel, 24/48VDC
    1.20 5716075-K DSDX451 ABB Expansion I/O Module, 20 DI, 12 DO
    1.21 5716075-P DSDX452 ABB Basic I/O Unit, 20 DI, 12 DO
    1.22 57310290-BY DSIH70 ABB Keyboard
    1.23 5735099-BA DSIH71 ABB Roller Ball
    1.24 26390410-CV   ABB Connection Cable for Roller Ball
    1.25 5735088-36 DSIM 2918 ABB 20" Color Monitor (RGB)
    1.26 57360001-CY DSMB133 ABB RWM Memory Board
    1.27 57360001-K DSMB151 ABB RWM Memory Board
    1.28 57360001-KE DSMB175 ABB RWM Memory Board, 4 Mbyte
    1.29 57360001-HC DSMC112 ABB FlexSK Controller Board
    1.30 57360001-DC DSMC120 ABB
    1.31 5736 045-N DSMD113 ABB Floppy Drive
    1.32 57360001-KM/1 DSMD122 ABB Hard Drive
    1.33 57310001-CX DSPC155 ABB CPU
    1.34 57310001-CC DSPC171 ABB CPU Unit Master View
    1.35 57310001-MP DSPC172H ABB CPU Unit, PROM
    1.36 57310001-T DSPB120 ABB
    1.37 21660559-H DSRA110 ABB DIN Rail
    1.38 52820083-LF DSRC113 ABB Cooling Fan Unit
    1.39   DSRC 113 ABB Spare Fans
    1.40 57310255-A DSRF150 ABB I/O Rack 1
    1.41 57310255-AV DSRF180A ABB I/O Rack 2
    1.42 57310255-AX DSRF181A ABB I/O Rack 1
    1.43 57310255-AL DSRF182 ABB I/O Rack 2
    1.44 48980002-A DSSB120 ABB Battery Backup Unit
    1.45   DSSB 120 ABB Spare Batteries
    1.46 48980001-AP DSSB146 ABB DC/DC Converter, 18-32V/4.75-5.25V
    1.47 48980001-AG DSSB170 ABB Rectifier Unit
    1.48 48980001-FK DSSR116 ABB Voltage Regulator Unit
    1.49 48980001-NK DSSR122 ABB Voltage Regulator Unit, 24VDC, 280W
    1.50 48980001-PC DSSR170 ABB Voltage Regulator Unit, 24V-5V
    1.51 2664109-DO DSSX129 ABB Supply Terminal
    1.52 5347049-BR DSSX161 ABB Supply Terminal
    1.53 57120001-CV DSTA131 ABB Connection Unit, Analog Input
    1.54 57120001-ET DSTA180 ABB Connection Unit, Analog Outrput
    1.55 57520001-A DSTC120 ABB Keyboard/Printer Connection Unit
    1.56 57310001-KN/2 DSTC175 ABB Connection Unit
    1.57 57310001-KT/1 DSTC176 ABB Connection Unit
    1.58 575 0001-ER DSTC190 ABB Master Bus
    1.59   DSTC404 ABB Terminal Board
    1.60 57520001-DX/1 DSTC 406 ABB Terminal Board
    1.61 57520001-FE DSTC 408 ABB Terminal Board
    1.62 5751017-A DST 452 ABB Modem
    1.63 5751017-L DSTC456 ABB Multiplexer
    1.64 57160001-TZ DSTD110A ABB Connection Unit
    1.65 57160001-UH DSTD150A ABB Connection Unit
    1.66 26390582-AY DSTK126 ABB Connection Cable
    1.67 26390582-BR DSTK127 ABB Connection Cable
    1.68 26390582-BL DSTK128 ABB Connection Cable
    1.69 26390582-BM DSTK129 ABB Connection Cable
    1.70 26390582-CR DSTK132 ABB Connection Cable
    1.71 26390603-BS DSTK181 ABB Ribbon Cable
    1.72 26390603-A DSTK150 ABB Ribbon Cable
    1.73 57350001-A DSTV 10 ABB Display Driver Card
    1.74 LB94/1.2 MP, CPU-PC, MA-BK ABB CPU Programming Cable
    1.75     ABB Rack I/O Blank Plastic Slot Filler
    1.76 K9033-015 K9033-015 ABB Advant Programming Station 120
    2.00   MURELEKTRONIC
    2.01   54043 Terminal Block
    2.02   61031 Terminal Block, Relay
    2.03   546149 Terminal Block
    2.04   546150 Terminal Block
    2.05   546152 Terminal Block, PKB 20
    2.06   546181 Terminal Block
    2.07   549802 Terminal Block
    3.00   EPIC II
    3.01   2002 EPIC II ESP Controller
    4.00   DIGI TABLE
    4.01   SG 807-5600 DC/DC Isolator Rack (8 Slot):
          ABB CEAG Sicherhietstechnik
          Best Nr: 100/45041195
          Komm Nr: 50/1491/93
          Typ: SG 807-5600
    4.02   SG 807-5600 DC/DC Isolator Rack (4 Slot):
          Komm Nr: 50/1491/93
          Typ: SG 807-5600
    4.03   CMC 303 S3 DC/DC Isolator Card:  CMC 303 S3
    4.04   CMC DC/DC Isolator Test Card:  CMC
    ABB Masterview DCS System Two Masterview 850/1 Systems version 5.0, 6
    operator consoles, 5 keyboards,  and 5 trackballs.
     Each Masterview licensed for 2000 points
    Part Number Description Quanity
    57310001-CC DSPC171 CPC MV850/1 3
    57360001-KG DSMB175 Memory Brd 4
    57520001-BZ DSCS116 Sync Comm 4
    57510001-AA DSCA114 Async Comm 4
    57330001-Y DSBB110A Dummy Brd 9
    57360001-HC DSMC112 Drive Controller 2
    5736045-N DSMD113 Floppy Drive 2
    5720001-EV DSCS140 MB300 Comm 6
    57310001-CC DSBC172 Bus Repeater 2
    48990001-FK DSSR116 24v to 5v Regulator 2
    57310001-CX DSPC155 Processor Tesselator 2
    57340001-T DSPB120 Display Processor 3
    57360001-CY DSMB133 Memory Brd 128K 2
    57360001-K DSMB151 Video Display Memory 6
    57350001-CN DSAV111 Video Generator 6
    57310255-A DSRF150 I/O Subrack 2
    57310255-AV DSRF180A Single CPU Subrack 2
    48990001-LY DSSA165 24v DC Power Supply 2
    48980002-A DSSB120 Battery Pack 4
    57520001-ER DSTC190 MB300 Connect Unit 5
    57520001-A/2 DSTC120 PLC Connect Unit 8
    57350001-A DSTV110 Connect Unit 3
    5751017-F/2 DSTC454 Fiber Modem 2
    5712289-A DSAX 452 Remote Analog I/O 5
    5735099-BA DSIH 71 Track Ball 5
    57310290-RA DSIH 72 Keyboard 5
    5735088-36 DSIM 2918 20in Monitor 6
     Part# Part Type Description Q'ty
    1 6007BG10000  Serial I/O Module 1
    2 6008BZ10000  Video Module 4
    3 6009BZ10000  D/M Module 2
    4 6026BZ10400  Processor Module, 33 Mhz 16MB 2
    5 6225BZ10000  ABB MOD 300 SC Backup Memory Extender Module
     1
    6 6230BP10830A-A  115V  50/60Hz In/Out 2
    7 6231BP10910  BLOCK 115VAC/125VDC ANALOG CRNT SRCE 4IN/2OUT 1
    8 6240BP10431A  MOD 300 I/O MODULE 24VDC 16CKT SRC(IC660TBD022) 5
    9 6240BP10431A-A  115/230V  50/60Hz  Relay output No 4
    10 6240BP10432A-A  5/12/24 VDC  Sink In/Out 1
    11 6240BP10831B-K  24/48VDC C/S IN 1
    12 6241BP10431C-K  24/VDC 16PT SRC 1
    13 6247BP10730A-B  115V  50/60Hz Input 5
    14 6248BP10831A-A  115V  50/60Hz 125VDC Isolated In/Out 12
    15 ACS601004300E1200000 Industry Oy ACS600 3Phase IP22 AC380/415V 62/47A 37KW 30KW 2
    16 BHL 20/50/300 T 2BDT00D1T001BCF0 ASERVO AMP 1
    17 CI560 3UBRC980002R0001 TRIO Field Bus Interface Module 1
    18 DI820 3BSE008512R1 Digital Input, 120 Vac 2
    19 DSAV111 57350001-CN DRIVER MODULE VIDEO DSAV-111 6
    20 DSBB110A* 57330001-Y SHIELD BOARD DSBB-110A 6
    21 DSBC172 57310001-KD BUS REPEATER MODULE CENTRAL RACK DSBC-172 0
    22 DSBC174 3BSE012211R1  4
    23 DSCA114 57510001-AA COMMUNICATIONS MODULE DSCA-114 4
    24 DSCS116 57520001-BZ PC BOARD DSCS 116 4
    25 DSCS140* 57520001-EV/10 COMMUNICATION MODULE MB 300 DSCS-140 4
    26 DSDO110 57160001-K I/O MODULE DIGITAL OUTPUT DSDO-110 2
    27 DSIH71BK01* 5735099-CJ TRACK BALL UINT  3
    28 DSIH72VR* 57310290-RB KEYBOARD 3
    29 DSMB133 57360001-CY MEMORY MODULE MP MASS DSMB-133 2
    30 DSMB151 57360001-K MEMORY MODULE VIDEO DSMB-151 1
    31 DSMB151* 57360001-K/9 MEMORY MODULE VIDEO DSMB-151 5
    32 DSMB175 57360001-KG MEMORY MODULE DYNAMIC DSMB-175 3
    33 DSMB179 57360001-MS  1
    34 DSMC112 57360001-HC DISK CONTROLLER DSMC-112 1
    35 DSMD113 5736045-N FLOPPY DRIVE 5- 1/4 INCH DSMD-113 1
    36 DSPB120 57340001-T DISPLAY PROCESSOR DSPB-120 2
    37 DSPC155 57310001-CX CPU MODULE DSPC-155 2
    38 DSPC157 57310001-GP MAIN COMPUTER BOARD EXPANDABLE DSPC-157 3
    39 DSPC171* 57310001-CC/8 PROCESSOR UNIT DSPC 171 2
    40 DSQC223 YB560103-BD/4 Robotics Digital I/O Module DSQC-223 2
    41 DSSR116* 48990001-FK/2 POWER SUPPLY UNIT DSSR-116 2
    42 DSTC120* 57520001-A/2 CONNECTION UNIT DSTC120 S2 6
    43 DSTC190* 57520001-ER/1 DSTC 190 Communications Connection Unit 4
    44 DSTV110* 57350001-A DSTV-110 Display Driver Card 3
    45 SAM11230F440  Stromberg Drives AC440V 1614A 1000HP 2
    46 TC5303BUR00011R1 T-Box for MOD 300 DCN  3
    47 TU831V1 3BSE013235R1 Module Termination Unit
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • 劉治安 在2025/7/8 16:34:00留言
  • 详细留言:安川HW9171094-A請惠予報價
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
