厦门兴锐达自动化设备有限公司
  • OVATION 备品备件
  • 发布时间:2009/10/19 16:20:54   修改时间:2009/10/19 16:20:54 浏览次数:627
  • OVATION 备品备件
    相关型号
    OVATION DCS系统产品清单
    1661D89G01 Power Supply
    MMI P/S (old version) w/ AC/DC RT301-2 brick and 3MSC7
    7380A31G01 card 115VAC 2
    1661D89G02 Power Supply
    7380A31G01 card 230VAC 2
    1661D89G03 Power Supply
    7380A31G01 card 115VAC 7
    1661D89G04 Power Supply
    1661D89G05 Power Supply
    7380A31G01 card 115VAC 13
    1661D89G06 Power Supply
    7380A31G01 card 230VAC 9
    1A51828G12 Cable Q-line card cable (angled plug) 25
    1A51829G12 Cable Q-line card cable (angled plug) 15
    1A54252G02 MMI OPR MMI KIT 1
    1A54289G06 MMI OPR MMI MOD 4A 1
    1A57252G02 MMI OPR MMI KIT 1
    1A57288G06 MMI ENG MMI M4A 1
    1B30023H01 Ovation Module Hart End Line Module 2
    1B30023H02 Ovation Module Hart End Line Module 2
    1B30035H01 Ovation Module Hart Terminal Module 10
    1C31113G01 Ovation Module +/- 20mV Analog Input Electronic Module 0
    1C31113G02 Ovation Module +/- 50mV Analog Input Electronic Module 0
    1C31113G03 Ovation Module +/- 100mV Analog Input Electronic Module 0
    1C31113G04 Ovation Module +/- 1VDC Analog Input Electronic Module 2
    1C31113G05 Ovation Module +/- 5VDC/0-20mA Analog Input Electronic Module 0
    1C31116G03 Ovation Module 0-20mA Locally Powered Analog Input Personality Module 1
    1C31122G01 Ovation Module Digital Output Electronic Module 1
    1C31125G01 Ovation Module Digital Output Personality Module 1
    1C31125G02 Ovation Module Digital Output Personality Module 1
    1C31129G01 Ovation Module 0-5VDC Analog Output Electronic Module 1
    1C31129G02 Ovation Module 0-10VDC Analog Output Electronic Module 0
    1C31129G03 Ovation Module 0-20mA Analog Output Electronic Module w/ Diagnostics 31
    1C31129G04 Ovation Module 0-20mA Analog Output Electronic Module w/o Diagnostics 0
    1C31132G01 Ovation Module Analog Outputs Personality Module 38
    1C31219G01 Ovation Module Relay Output Logic Module 5
    1C31224G01 Ovation Module Analog Input 4-20mA Module (EMOD) 51
    1C31224G02 Ovation Module Analog Input 1V Module (EMOD) 0
    1C31227G01 Ovation Module Analog Input Personality Module (PMOD) 51
    1C31227G02 Ovation Module Analog Input Personality Module (PMOD) 0
    1C31232G03 Ovation Differential DI 120VAC/DC Differential E-Mod 1
    1C31234G01 Ovation Module DI 48VDC On-Board E-Mod Contact Module 0
    1D54416G01-
    6 Power Supply Assy DPU P/S (old version) w/ AC/DC brick 0
    1D54458G01 Keyboard WDPF Operator Keyboard in Console Fixed cord 115VAC 5
    1D54458G02 Keyboard WDPF Operator Keyboard in Console Fixed cord 230VAC 5
    1D54471G02 Keyboard WDPF Mylar keyboard top Board (Older Style) 10
    1D54471G03 Keyboard WEStation Mylar keyboard top Board (new) 12
    1D54540G01 Panel AC Distribution Panel 5
    1D54544G01-
    8 Chassis WDPF Chassis (9 Slot) 19
    1D54557G03 Q Crate Q Line card cage w/ 2840A38G01 backplane 1
    1D54557G07 Q Crate Q Line card cage w/ 4256A99G02 backplane 3
    1D54557G10 Q Crate Q Line card cage w/ 4256A99G02 backplane 8
    1D54557G10 Q Crate
    Q Line card cage w/ 4256A99G02 backplane & 3A59347G01 on
    front edge 1
    1D54561G01 LIM Module LIM Assy w/ 7381A27G01 3LIM4 Dual Loop 10
    1D54561G02 LIM Module LIM Assy w/ 7381A27G01 3LIM4 Single Loop 10
    1D54574G01 Keypad LIM Assy keypad 10
    1D54579G01 Panel Distribution Interface Assy 2
    1D54580G02 Chassis MultiBus Chassis 12
    1D54581G04 Rack Tray Dual Rack tray w/ 2ea 1D54582G05 DPU P/Ss 5
    1D54582G01 Power Supply Assy DPU Power Supply Assy w/ AC SW w/ Wier brick 115VAC 2
    1D54582G02 Power Supply Assy DPU Power Supply Assy w/ AC SW w/ Wier brick 230VAC 2
    1D54582G03 Power Supply Assy
    DPU Power Supply Assy w/o AC SW & DSC G03 Ctrlr card
    115VAC/230VAC 1
    1D54582G05 Power Supply Assy DPU Power Supply Assy w/ AC SW w/ Deltron brick 115VAC 32
    DPU Power Supply Assy w/ Deltron brick & plug-in cables
    115VAC 7
    1D54582G06 Power Supply Assy DPU Power Supply Assy w/ AC SW w/ Deltron brick 230VAC 22
    1X00024H01 Power Supply MagneTek model WH1-2FF 24V Power Supply + 24V Aux, AC 0
    1X00024H03 Power Supply MagneTek model Power Supply 48V Aux, AC 0
    1X00024H04 Power Supply MagneTek model Power Supply + 24V Aux, DC 0
    1X00024H06 Power Supply MagneTek model Power Supply 48V Aux, DC 0
    1X00093H04 Switch Ethernet Switch (24 Ports) - Primary Fanout 0
    1X00093H05 Switch Ethernet Switch (24 Ports) - Partner Fanout 0
    1X00093H08 Switch Ethernet Switch (24 Ports) - Root 0
    1X00093H09 Switch Ethernet Switch (24 Ports) - Backup 0
    1X00102H01 Ovation Dist Bd Power Distribution Board MagneTek WH1-PDM 1
    1X00133H01 NIC PCI Fast Ethernet DAS NIC, W2K, XP 0
    1X00161H01 NIC Fast Ethernet NIC - Dual Port for Controller ZYNX 0
    1X00163H01 Power Supply
    Magnetek WH3A-2DF plug-in style I/O Power Supply 13/24VDC
    w/ AC input 1
    1X00163H02 Power Supply
    Magnetek WH3A-2DJ plug-in style I/O Power Supply 13/48VDC
    w/ AC input 0
    1X00163H03 Power Supply
    w/ DC input 2
    1X00163H04 Power Supply
    w/ DC input 0
    1X00185H01 Graphics SUN XVR-100 GRAPHICS card 2
    1X00377H01 Cable Mgt Bar Cable Management Bar 1
    1X00417H01 Power Supply
    PowerOne WH7A-2DF plug-in style I/O Power Supply
    13/24VDC w/ AC input 0
    1X00417H02 Power Supply
    PowerOne WH7A-2DJ plug-in style I/O Power Supply
    13/48VDC w/ AC input 0
    1X00417H03 Power Supply
    13/24VDC w/ DC input 1
    1X00417H04 Power Supply
    13/48VDC w/ DC input 0
    2000A04G01 4QTR1 QTR G01 card 1
    2380C91G03 Temp Sensor Temp Sensor 4
    2623D37G01 Module NL-1075B Comm Adapter 1
    2837A11G01 4NCH5 NCH G01 card 3
    2837A11G01 4NCH7 NCH G01 card 1
    2837A86G01 2NCI2 NCI G01 card 3
    2837A87G04 8NRC1 NRC G04 card 3
    2838A30G12 7NCB2 NCB G12 card 6
    2838A32G01 5NAC3 NAC G01 card 1
    2838A32G01 5NAC5 NAC G01 card 1
    2838A32G01 5NAC6 NAC G01 card 2
    2838A33G01 4NPL7 NPL G01 card 3
    2838A34G01 7NMA2 NMA G01 card 12
    2838A45G01 3NTD4 NTD G01 card 1
    2839A38G01 2NPD7 NPD G01 card 5
    2840A10G03 QMC QMC G03 card 0
    2840A13G01
    - G16 QDI QDI G01 - G16 (Replaced by QID G01 - G16) 0
    2840A15G01 QME QME G01 card 0
    2840A17G01 5QTO3 QTO TRIAC Output card - 115VAC 38
    2840A17G06 3QDI39 QDI G06 card (replaced by QID G06) Sub 1 1
    2840A17G06 4QDI6 QDI G06 card (replaced by QID G06) Sub 4 5
    2840A18G01 6QRO5 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 2 1
    2840A18G01 6QRO9 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 3 11
    2840A18G01 6QRO13 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 5 14
    2840A18G01 6QRO17 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 5 2
    2840A18G01 6QRO23 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 5 1
    2840A18G01 7QRO1 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 5 1
    2840A18G01
    3A99168G01 8QRO1 QRO G01 Relay Output card - 330VDC/250VAC Form A 22
    2840A18G01
    3A99168G01 8QRO7 QRO G01 Relay Output card - 330VDC/250VAC Form A 5
    2840A18G02 6QRO13 QRO G02 Relay Output card - 330VDC/250VAC Form B Sub 5 5
    2840A18G02 8QRO1 QRO G02 Relay Output card - 330VDC/250VAC Form B 5
    2840A18G03 6QRO11
    QRO G03 Relay Output card - Form A non-inductive loads Sub
    5 0
    2840A18G04 6QRO13 QRO G04 Relay Output card - Form B non-inductive loads 5
    2840A19G07 4QAI17 QAI G07 Analog Input card - 0 to +20mA 1
    2840A20G01 3QTB17 QTB G01 Time Base card - 60 Hz (+/-2 Hz input) 2
    2840A20G01 3QTB21 QTB G01 Time Base card - 60 Hz (+/-2 Hz input) 40
    2840A20G02 3QTB26 QTB G02 Time Base card - 50 Hz (+/-2 Hz input) 1
    2840A20G03 3QTB27 QTB G01 Time Base card - 60 Hz (+/-2 Hz input) 1
    2840A21G01 7QAO20 QAO G01 Analog Output card - 20mA Sub 17 6
    2840A21G01 7QAO20 QAO G01 Analog Output card - 20mA Sub 19 11
    2840A21G01 8QAO1 QAO G01 Analog Output card - 20mA Sub 20 8
    2840A21G01 8QAO20 QAO G01 Analog Output card - 20mA 30
    2840A21G01
    3A99161G01 10QAO17 QAO G01 Analog Output card - 20mA Sub 27 & 28 16
    2840A21G01
    3A99161G01 11QAO1 QAO G01 Analog Output card - 20mA Sub 29 & 30 7
    2840A21G01
    3A99161G01 11QAO9 QAO G01 Analog Output card - 20mA Sub 31 4
    2840A21G01
    1P00000G01 13QAO1 QAO G01 Analog Output card - 20mA Sub 33 1
    2840A21G01
    1P00000G01 13QAO9 QAO G01 Analog Output card - 20mA Sub 35 1
    2840A21G02 5QAO42 QAO G02 Analog Output card - 10VDC Sub 9 1
    2840A21G02 7QAO21 QAO G02 Analog Output card - 10VDC 1
    2840A21G04 4QAO38 QAO G04 Analog Output card - 5VDC 2
    2840A21G04 8QAO4 QAO G04 Analog Output card - 5VDC 1
    2840A21G05 5QAO61 QAO G05 Analog Output card - (+/-)5VDC 2
    2840A21G05 7QAO24 QAO G05 Analog Output card - (+/-)5VDC 6
    2840A21G05 7QAO32 QAO G05 Analog Output card - (+/-)5VDC 2
    2840A21G05 8QAO5 QAO G05 Analog Output card - (+/-)5VDC 1
    2840A21G05 13QAO13 QAO G05 Analog Output card - (+/-)5VDC 1
    2840A21G06 8QAO22 QAO G06 Analog Output card - (+/-)10VDC 2
    2840A21G07 5QAO37 QAO G07 Analog Output card - 20mA 1
    2840A21G08 QAO QAO G06 Analog Output card - (+/-)10VDC 0
    2840A38G01 Backplane Q-Crate Backplane 42
    2840A49G01
    404A724G01 1QEX6 QEX Q-Line Extender 1
    2840A75G01 3QSC7 QSC G01 Speed Channel card 4
    2840A75G02 3QSC8 QSC G02 Speed Channel card 10
    2840A77G02 QPP QPP G02 card 0
    2840A78G01 4QSD14 QSD Servo Driver card - (+/-)24mA output 1
    2840A79G01 3QBO21 QBO G01 Digital Output card - 60VDC @ 300mA (max) Sub 2 3
    2840A79G01 3QBO27 QBO G01 Digital Output card - 60VDC @ 300mA (max) Sub 5 18
    2840A79G01
    2840A79G81 3QBO21 QBO G01 Digital Output card - 60VDC @ 300mA (max) Sub 5 1
    2840A79G01
    3A99162G01 4QBO16 QBO G01 Digital Output card - 60VDC @ 300mA (max) 27
    2840A79G02 3QBO28
    QBO G02 Digital Output card - 60VDC @ 300mA (max) w/
    filters Sub 5 1
    2840A79G03 QBO
    QBO G03 Logic Output card - 20VDC @ 16mA (max) w/
    flashing 0
    2840A79G04 3QBO19 QBO G04 Logic Output card - 20VDC @ 16mA (max) 2
    2840A79G04 3QBO24 QBO G04 Logic Output card - 20VDC @ 16mA (max) 1
    2840A79G05 QBO
    QBO G05 Logic Output card - 20VDC @ 16mA (max) w/
    flashing, pull-up 0
    2840A80G04 6QBI4 QBI G04 Digital Input card - +24 (20 to 30)VDC 13
    2840A80G04 6QBI14 QBI G04 Digital Input card - +24 (20 to 30)VDC 4
    2840A80G06 5QBI17 QBI G06 Digital Input card - +48 (40 to 60)VDC 2
    2840A80G08 6QBI8 QBI G08 Digital Input card - +120 (100 to 150)VAC 4
    2840A80G11 6QBI11
    QBI G11 Digital Input card - +120 (100 to 150)VAC (High
    Threshold) 0
    2840A85G01 QMS QMS G01 card 0
    2840A86G05 2QAC11 QAC G05 Analog Cond. card - +120mA at +48VDC 5
    2D34347G05 Power Supply Assy
    Dual 24VDC Power Supply Assy w/2ea Advance MG24-10C
    115VAC 14
    2D34347G06 Power Supply Assy
    230VAC 14
    2D34347G07 Power Supply Assy
    Dual 48VDC Power Supply Assy w/2ea Advance MG48-5C
    115VAC 14
    2D34347G08 Power Supply Assy
    230VAC 14
    320117-05A Card Kalex SC401141-45 1
    399D915G05 Gnd Det Pnl gray rack panel 1
    3A42902H01 Printer Genicom 3410XCQ Color Printer 1
    3A43019G02 Panel 13VDC Power Supply Monitoring Panel w/ Cable 1
    3A43084G01 SBUS SBUS/MultiBUS 0
    3A56324G11 Chassis OPR MMI 1
    3A58354G02 TFR Assy
    TFR Modification Assy (same as TFR Assy 4D33764G01 but w/
    sticker on front) 1
    3A58919G12 Cable Orange Cable Assy RTD - N 12
    3A58939G15 Keyboard SUN Type 6 Keyboard and Mouse 5
    3A58945H01 Monitor 20/19" SUN CRT (19.1" LCD replacement solution) 5
    3A58992H04 Cable 3BNC RGB Video Cable for SUN Sparc5 10
    3A59104G01 VXI Kit VXI Kit 1
    3A59104G02 Card Cage
    486 WEStation Q-line Remote I/O (on front of cage w/ MRC,
    MHC, MDX cards) 11
    3A59104G04 Card Cage
    MHC, MDX cards) 6
    3A59323G01 Chassis ENGR MMI Chassis 5
    3A59323G02 Chassis ENG MMI Chassis 1
    3A59324G01 Chassis OPR MMI Chassis 4
    3A59324G02 Chassis OPR MMI Chassis 4
    3A59347G01 Q Crate
    Q-Line Remote I/O card cage w/ 4256A99G02 BP &
    1D54557G10 on cage side 1
    3A59324G11 Chassis OPR MMI Chassis 1
    3A59341G03 Interface Strip WDPF IIU Kit (Interface Strip in VME chassis) 3
    3A59351G11 Chassis OPR MMI Chassis 1
    3A59526G12 Cable Green cable out CH0 on front of VME SHC card 4
    3A59527G12 Cable Yellow cable out CH1 on front of VME SHC card 4
    3A98608G03 Port VME SCSI Serial Port Device 3
    3A98641H02 Adapter 25pin serial female to 9pin male adapter 2
    3A98643G03 Cable Ribon Cable to MRC card 5
    3A98648G32 TAP Panel
    Cluster TAP Panel w/ 2ea 5D32025G04 Ethernet TAP & 4ea
    5D32024G01 RTP 3
    3A98688G02 SCSI Cable SCSI Cable on front of VME chassis 5
    3A98688G03 SCSI Cable SCSI Cable on front of VME chassis 2
    3A98688G04 SCSI Cable SCSI Cable on front of VME chassis 1
    3A98720G18 Cable Green Cable out the front of VME Sparc 6
    3A98726G06 Cable Trackball Cable 2
    3A98768G01 Switch Switch 22
    3A98807G05 Cable Serial Model 25 pin Male 3
    3A98826H06 Trackball SUN Trackball 3
    3A98833H01 Cable SUN SCCI CABLE 2
    3A98833H03 Cable SUN SCSI CABLE 2
    3A98833H12 Cable SUN SCSI CABLE 2
    3A98833H23 Cable SUN SCSI CABLE 2
    3A98865G01 Cable Green Cable to TAP Panel Assy 6
    3A98871H01 Keyboard Engineering 101 Key Keyboard NMB RT101 116305-002 3
    3A98963G05 Keyboard WEStation Operator Membrane Keyboard 0
    3A99101G01 2QSR35 QSR G01 Servo Driver w/ Position Readback card 4DC LVDTs 3
    3A99101G02 QSR QSR G02 Servo Driver w/ Position Readback card 2AC LVDTs 0
    3A99108G01 QRS QRS G01 0
    3A99109G01 QRF QFR - 4 wire RTD Input Amplifier 0
    3A99114G03 QRD QRD G03 Module - 200 Ohm Platinum RTD 0
    3A99114G04 QRD QRD G04 Module - 200 Ohm Platinum RTD 0
    3A99116G01 4MDPS3 MDPS Board (inside 5D32191G01 MPS512-PFC power supply) 12
    3A99116G01 4MDPS9 MDPS Board 10
    3A99118G01 QCA QCA G01 card 0
    3A99118G02 QCA QCA G02 card 0
    3A99125G02 COT Board COT Fiber Optic Transmitter / Receiver card 0
    3A99125G03 COT Board COT Fiber Optic Transmitter / Receiver card 0
    3A99132G01 3PCPS04 Ovation Power Supply card 1
    3A99132G02 3PCPS05 Ovaton Power Supply card 2
    3A99141G01 Board Q-Line Interface 0
    3A99158G01 4PCRL1 Ovation Local I/O Interface 5
    3A99199G01 2ROP3 Ovation Power Supply backplane 1
    3A99200G01 5CBO5 Ovation PCI Backplane 2
    3A99211G01 1DAPS4 1DAPS4 G01 card inside 4D33913G01 and G04 power supply 10
    3A99211G02 1DAPS5 1DAPS5 G01 card inside 4D33913G02 and G05 power supply 2
    3A99220G01 2MEPS3 2MEPS3 card in 4D33916G01 Power Supply 8
    3A99229G01 3PGI1 PGI Data Highway card (for Ultras and Blades) 8
    3A99254G01 2IOPS16 IOPS Power Supply board inside 4D33865G01 P/S 4
    3A99254G03 4IOPS3 IOPS Power Supply board inside 4D33865G03 P/S 4
    3A99257G01 QOR QOR G01 Remote I/O card 0
    3A99401H01 Fan Assy Fan Assy in 486 WEStation DPU 46
    3A99403H01 Transformer AC/DC Transformer 4
    3A99410G02 Cable DIOB Ribbon Cable 10
    3A99410G06 Cable DIOB Ribbon Cable 10
    3A99419G03 Cable Ovation Cabinet Ground Cable 1
    3A99419G06 Cable Ovation Cabinet Ground Cable 1
    3A99419G12 Cable Ground Cable 10
    3A99419G19 Cable Ground Cable 10
    3A99420G19 Cable Ground Cable 10
    3A99528G23 Cable Cable w/ 406A095H03 adapter plug 1
    3A99537G01 Cable Cable Assy -GBUS 1.5 FT - GHC Enclosure to Sparc5 or Ultra5 3
    3A99537G02 Cable Cable Assy -GBUS 10 FT - GHC Enclosure to Sparc5 or Ultra5 8
    3A99544G01 Cable Cable 1
    3A99546G01 Cable DPX to DPX back plane ribbon 22
    3A99592H01 Cable Cable to Ethernet Tap Assy 5
    3A99596G01 Cable Cable from the front of the TFR to it's own back plane 22
    3A99598G02 Cable Cable from the MRC to TFR Panel (two into one) 6
    3A99598G03 Cable Cable from the MRC to TFR Panel (two into one) 6
    3A99670G01 Intel Card
    PBA510105-006 PSBC272 daugter card on Intel 4256A41G02
    board 5
    3A99678G21 Chassis WEStation MMI Kit (sticker on front edge of VME chassis) 3
    3A99688H01 Power Supply
    Deltron 11564XA-01 Power Supply brick for DPU Module
    115VAC 10
    3A99688H02 Power Supply
    Deltron 11564XA-02 Power Supply brick for DPU Module
    230VAC 5
    3A99695H01 Battery Lithium Battery for MDX card 30
    3A99719G01 Kit Weir to Deltron brick DPU Power Supply upgrade kit 12
    3A99723G01 Cable DPU Power Supply harness 6
    3A99732H03 VME Board
    Sun Sparc2 VME Board (Motherboard - becomes 4D33816G01,
    G03, G04, etc) 11
    3A99734H01 Power Supply
    PowerOne NRG4A70B4B4K0RZ108 for MMI P/S Module
    4D33613G01 10
    3A99746G01 Kit
    TODD to PowerOne NRG4A70B4B4K0RZ108 brick MMI Power
    Supply upgrade Kit 20
    3A99778G02 Monitor 20/19" Sony CRT (19.1" LCD replacement solution) 5
    3A99782H01 Graphics card TGX Graphics Card 8
    3A99795G02 Drive HP C2550T SureStore 1300t 1.3GB External Optical Disk Drive 2
    3A99795G07 Drive
    HP C1114J SureStore 5200ex 5.2GB External Optical Disk
    Drive 4
    3A99795G09 Drive KIT, OPTICAL DISK DRIVE 4
    3A99795G10 Drive HP 9100MX Optical Drive with 3ft DB50M Cable 1
    3A99795G11 Drive HP 9100MX Optical Drive with 31in MiniD50M Cable 1
    3A99795G12 Drive HP 9100MX Optical Drive with 3ft MiniD68M Cable 1
    3A99795H03 Media HP Optical Disk - Rewritable 5
    3A99795H04 Media HP Optical Disk - Write Once 5
    3A99795H10 Drive HP C1114F SureStore 2600fx 2.6GB External Optical drive 3
    3A99795H18 Media HP 5200ex Optical Disk Media 15
    3A99795H24 Drive HP 9100MX Optical Disk Drive 5
    3A99795H25 Media Optical Disk Media 5
    3A99857G04 Cable QHS-L 486 Analog - 56ACE (Q-line I/O cable) 8
    3A99859G03 Cable QHS-R 486 Digital - 56 ACE (Q-line I/O cable) 8
    3A99859G04 Cable QHS-L 486 Digital - 56ACE (Q-line I/O cable) 8
    3A99860G04 Cable Halfshell Termination Assembly/Cable 2
    3A99977G01 Cable DIOB to MDX Cable 5
    3A99989H13 Printer Genicom 3850 Color Printer 3
    3A99990H02 Memory Memory 32mb 501-2471 for SUN Sparc5 5
    3A99992H02 Sun Workstation
    Sparc20 built to your spec - all processors/options avail - w/
    SGI 6
    3D04057G01 Switch
    WDPF Engineering Console Control Stn w/ 2FILM2
    7381A59G01 card 3
    3D04058H01 Keyboard 84 key Par. Int. (Amkey 106-0004) 2
    3D04061G01 Keyboard WDPF Operator Mylar Keyboard Desk Top, Fixed cord 115VAC 12
    3D04061G02 Keyboard WDPF Operator Mylar Keyboard Desk Top, Fixed cord 230VAC 8
    3D04101G01 Panel Alarm Panel 2
    3D04101G04 Panel Alarm Panel 2
    3D04106G01 FOR Fiber Optic Repeater w/ 5FTC5 G01 115VAC 5
    3D04106G02 FOR Fiber Optic Repeater w/ 5FTC5 G01 230VAC 5
    3D04106G04 FOR Fiber Optic Repeater w/ 5FTC5 G03 115VAC 10
    3D04106G05 FOR Fiber Optic Repeater w/ 5FTC5 G03 230VAC 10
    3D04106G06 FOR Fiber Optic Repeater 115VAC 10
    3D04106G07 FOR Fiber Optic Repeater 230VAC 10
    3D04109G01 Module WDPF SBX 51 I/O Module 0
    3D04115G04-
    16 Module PC1200-1043 Module (blue plastic) 1
    3D04128G01 Line Filter Line Filter Sub 2 1
    3D04141G01 Power Supply
    Dual Power Supply Assy rack tray w/ 2ea PM2722A-1 Power
    Suplies 7
    3D04141G02 Power Supply
    Dual Power Supply Assy rack tray w/ 2ea PM2775-1-3 Power
    Suplies 3
    3D04142G02 Panel DC Pwr Distribution Panel 5
    3D04146G01 Rack Tray Dual I/O Power Supply Rack Tray w/ 2ea 405A662G01 Deltrons 10
    3D04153G01 Drive Assy w/ Seagate ST225 HD & Panasonic JU-475-5 Floppy, 115VAC 2
    3D04153G02 Drive Assy w/ Seagate ST225 HD & Floppy, 230VAC 1
    3D04153G03 Drive Assy w/ Seagate ST225 HD, 115VAC 1
    3D04153G04 Drive Assy w/ Seagate ST225 HD, 230VAC 0
    3D04153G05 Drive Assy w/ Micropolis 1325 (or Maxtor XT1085) HD, 115VAC 1
    3D04153G06 Drive Assy w/ Micropolis 1325 (or Maxtor XT1085) HD, 230VAC 0
    3D04153G07 Drive Assy w/ Micropolis 1325 (or Maxtor XT1085) HD & Floppy, 115VAC 4
    3D04153G08 Drive Assy w/ Micropolis 1325 (or Maxtor XT1085) HD & Floppy, 230VAC 2
    3D52389G02 XMC XMC Synchronizer 4
    403A986G01 Cable Ribon Cable QAA to DBK 13
    404A747G02 Switch Operator Keyboard Top Board key lock/switch 5
    404A749G03 Keyboard WDPF Operator Mylar Top Board (new) 25
    404A790H01 Floppy Drive Winchester Floppy Disk Drive 0
    404A790H27 Hard Drive Seagate ST-225 20/25MB HD 2
    404A822H03 Power Supply Pioneer Magnetics PM2924A-3 0
    404A965H01 BNC T BNC T connector 5
    405A318G01 Printer Genicom 3404C Color Printer 0
    405A357H11 Power Supply
    24V-10A Power Supply (Acme 2FA1900002A for 4D33711G01
    RIO P/S Assy) 5
    405A401G01 Cable MSE cables 15
    405A431G01 Power Supply
    Weir SMM 200 Power Supply Brick for DPU P/S Module
    115VAC 5
    405A431G02 Power Supply
    230VAC 5
    405A497H01 Graphics Generator Summa Graphics MM1103 1
    405A528G01 Chassis 12 Slot MultiBus Chassis 115VAC 1
    405A528G02 Chassis 12 Slot MultiBus Chassis 230VAC 1
    405A528G21 Chassis MOD 1
    405A528G33 Chassis MOD 1
    405A528G61 Chassis 12 Slot MultiBus Chassis 115VAC 3
    405A528G62 Chassis 12 Slot MultiBus Chassis 230VAC 3
    405A528G63 Chassis 12 Slot MultiBus Chassis 115VAC 3
    405A528G64 Chassis 12 Slot MultiBus Chassis 230VAC 3
    405A616H01 Cable WDPF Classic 3BNC RGB Coax Video Cable Assembly - 10ft 12
    405A616H02 Cable WDPF Classic 3BNC RGB Coax Video Cable Assembly - 25ft 2
    405A662G01 Power Supply
    13V I/O Power Supply Deltron 11088XA (1996 models or
    newer) 115VAC 58
    405A662G02 Power Supply
    newer) 230VAC 58
    405A672H01 Graphics card Matrox SBX-900 Graphics card 249-06-01 2
    405A672H01 Graphics card Matrox SBX-900 Graphics card 249-06-02 3
    405A672H01 Graphics card Matrox SBX-900 Graphics card 249-06-04 12
    405A675G61 Chassis 12 Slot MultiBus Chassis 115VAC 14
    405A675G62 Chassis 12 Slot MultiBus Chassis 230VAC 1
    405A675G63 Chassis 12 Slot MultiBus Chassis 115VAC 17
    405A675G64 Chassis 12 Slot MultiBus Chassis 230VAC 3
    405A685G61 Chassis 12 Slot Chassis 1
    405A689G01 SMS SMS 8007 Board 2
    405A689G03 SMS SMS 8007 Board 13
    405A689G04 SMS SMS 8007 Board 1
    405A742G01 Power Supply Power Supply for Firber Optic Repeater 115VAC 10
    405A742G02 Power Supply Power Supply for Fiber Optic Repeater 230VAC 10
    405A743H01 Tape Drive Kenedy 9600, 3200 BPI Mag Tape - Rack Mount 1
    405A824G01 Cable Cables MMI 10
    405A832H01 Track Ball CTI Model T1013K-D25F073S Desk Top model 1
    405A832H02 Track Ball CTI Model T1013K-D25F073S Console model 1
    405A856H01 Power Supply PM2722A-1 Pioneer Magnetics + 12V @ 125VDC 15
    405A857H01 Power Supply PM2775A-1-3 Pioneer Magnetics 12/12/5V @ 125VAC 10
    405A891G01 Power Supply Power Supply Card inside WDPF Drive Assy 115VAC 8
    405A891G02 Power Supply Power Supply Card inside WDPF Drive Assy 230VAC 5
    405A892H01 Hard Drive Mnemonic 85MB Hard Drive 0
    405A893G01 Floppy Drive TEAC FD55GFR 5?” floppy drive 3
    405A893H01 Floppy Drive Panasonic JU-475-5AEG 5 5?” floppy drive 3
    405A924G03 Cable Cables MMI 16
    405A924G04 Cable Cables MMI 15
    405A924G05 Cable Cables MMI 1
    405A924G06 Cable Cables MMI 1
    405A973H01 Label Label sticker for Logitech M-CU15-9F three button mouse 5
    405A975G01 Power Supply TODD MTX-403-10384 power supply brick 115VAC 1
    405A975G02 Power Supply TODD MTX-403-10384 power supply brick 230VAC 1
    406A036H01 DRE 120 OHM Nickle RTD DRE Daughter card on QRT 0
    406A054H01 Power Supply Pioneer Magnetics PM2722-1 Type 24F33-0-4-RS 0
    406A095H03 Adapter Adapter plug w/ 3A99528G23 cable 10
    406A112G16 Cable WDPF Kybd Cble / 25 pin adapter 2
    406A124G01 Monitor 20/19" CRT (DS191D 19.1" LCD replacement solution) 5
    406A124H01 Intecolor CRT Monitor Non-Touch Desktop E02038-20E 0
    406A124H15 Intecolor CRT Monitor InfraRed Touch Desktop E20FEC-WE1 1
    406A124H17 Intecolor CRT Monitor InfraRed Touch Console E20FEC-WE3 1
    406A154H01 Power Supply
    PowerOne SPL50-3200 card inside WDPF Classic DT box
    (MHC Enclosure) 8
    406A157G01 Ribbon Cable 3M FlexCat inside WDPF Classic DT box (MHC Enclosure) 10
    4625B61G01 Conduit Box Conduit box (4ea receptical box) 2
    4256A01G01 6QLC5 QLC card w/ daughter card removed 1
    4256A01G01
    772B450G01 6QLC5 QLC card w/ 1SCOM2 4256A06G01 RS232 daughter card 1
    4256A01G01
    772B450G02 6QLC5 QLC card w/ 1SCOM2 4256A06G02 RS422 daughter card 1
    4256A01G01
    772B450G01 6QLC7 QLC card w/ 1SCOM1 4256A06G01 RS232 daughter card 2
    4256A01G01
    772B450G01 6QLC9 QLC card w/ 1SCOM1 4256A06G01 RS232 daughter card 0
    4256A03G01 4KBI9 Board inside WDPF detachable cord optr keybds 115VAC 6
    4256A03G02 4KBI9 Board inside WDPF detachable cord optr keybds 230VAC 6
    4256A03G03 4KBI9 Board inside WEStation detachable cord optr keybds 115VAC 6
    4256A03G04 4KBI9 Board inside WEStation detachable cord optr keybds 230VAC 6
    4256A04G01 MCSM MCSM G01 Board (inside IBM PC) 0
    4256A04G02 2MCSM7 MCSM G02 Board (inside IBM PC) 5
    4256A05G01 2MHB1 Backplane inside MHC DT Box 8
    4256A06G01 SCOM SCOM Daughter Card on QLC RS232 1
    4256A06G02 SCOM SCOM Daughter Card on QLC RS422 1
    4256A07G01 MHR MHR Highway Controller 0
    4256A08G02 3RTP6 Remote Tap Interface cards in 5D32035G02 Cluster Tap Panel 1
    4256A08G02 3RTP6 Remote Tap Interface cards in 5D32024G01 Cluster Tap Panel 8
    4256A10G01 3MSX7 MSX 386 Processor Board 14
    4256A10G01 3MSX9 MSX 386 Processor Board 9
    4256A10G01 3MSX10 MSX 386 Processor Board 52
    4256A10G01 3MSX12 MSX 386 Processor Board 15
    4256A10G01 3MSX13 MSX 386 Processor Board 14
    4256A11G01 3SHC9 SUN Hwy Interface Board 5
    4256A11G01 3SHC10 SUN Hwy Interface Board 8
    4256A11G01 3SHC11 SUN Hwy Interface Board 1
    4256A11G01 3SHC12 SUN Hwy Interface Board 2
    4256A12G01 EHS EHS Ethernet Highway Switch 0
    4256A15G01 QDC QDC G01 - 24 VDC/AC 0
    4256A15G02 QDC QDC G02 - 48 VDC/AC 0
    4256A15G03 QDC QDC G03 - 120 VDC/AC 0
    4256A25G01
    1C31025G03 5MRC4 MRC Board for 386 processor WEStation 13
    4256A25G01
    1C31025G03 5MRC5 MRC Board for 386 processor WEStation 1
    4256A25G01
    1C31025G03 5MRC6 MRC Board for 386 processor WEStation 1
    4256A25G01
    1C31025G03 5MRC9 MRC Board for 386 processor WEStation 2
    4256A25G01
    1C31025G03 5MRC11 MRC Board for 386 processor WEStation 1
    4256A25G01
    1C31025G03 5MRC17 MRC Board for 386 processor WEStation 1
    4256A25G02
    1C31025G05 5MRC12 MRC Board for 486 processor WEStation 4
    4256A25G02
    1C31025G05 5MRC18 MRC Board for 486 processor WEStation 26
    4256A25G02
    1C31025G06 5MRC18 MRC Board for 486 processor WEStation 3
    4256A26G01 4QRC1 QRC card 3
    4256A26G01 4QRC3 QRC card 6
    4256A26G01 4QRC4 QRC card 2
    4256A26G01 4QRC5 QRC card 1
    4256A26G01
    1C31183G01 4QRC6 QRC card 23
    4256A27G01 2PQD2 DPU Power Supply plug Adapter card (quick connect) 10
    4256A41G01 Intel Processor card
    PBA511832-005 PSBC386SX02 AA510104-006 w/ Intel
    Daughter PBA100367-03 3A58926G03 prom 1
    PBA511832-006 PSBC386SX02 AA510104-007 w/ Intel
    4256A41G02 Intel Processor card
    PBA511832-007 PSBC386SX02 w/ Intel Daughters
    3A99670G01 PBA510105-006 PSBC272 & PBA115417-006
    SBX586 10
    4256A51G01 3QFR2 Cards inside TFR Panel Assy 26
    4256A51G01
    772B480G01 3QFR3 Cards inside TFR Panel Assy 38
    4256A51G01 4QFR2 Cards inside TFR Panel Assy 18
    4256A56G01 2TRC2 Channel Input card in TFR Assy 7
    4256A57G01 3WPM2 WPM card inside 4D33810G01 P/S Assy 2
    4256A58G01 2TFR1 TFR Assy back plane 39
    4256A62G01 PIC PIC Peripheral Interface card 0
    4256A64G01
    3A99163G01
    / G50 6QAX1 / 7 QAX G01 12 point AI card - 20mV w/ 12ea 4QAXD1 G01s 8
    4256A64G01
    3A99163G01
    / G50 7QAX1 / 7 QAX G01 12 point AI card - 20mV w/ 12ea 4QAXD1 G01s 1
    4256A64G02
    3A99163G50 3QAX16 / 21 QAX G02 12 point AI card - 50mV w/ 12ea 4QAXD2 G02s 14
    4256A64G02
    3A99163G02
    / G50 6QAX2 / 7 QAX G02 12 point AI card - 50mV w/ 12ea QAXD G02s 3
    4256A64G02
    3A99163G02
    / G50 6QAX2 / 7QAX7 QAX G02 12 point AI card - 50mV w/ 12ea QAXD G02s 2
    4256A64G02
    3A99163G02
    / G50 7QAX2 QAX G02 12 point AI card - 50mV w/ 12ea QAXD G02s 2
    4256A64G03 QAX QAX G03 12 point AI card - 100mV 0
    4256A64G04 QAX QAX G04 12 point AI card - 0 to 1V 0
    4256A64G05 3QAX12 QAX G05 12 point AI card - 0 to 5V 18
    4256A64G05 3QAX19
    QAX G05 12 point AI card - 0 to 5V w/ 12ea 4QAXD5
    4256A65G05s 7
    4256A64G05
    3A99163G05 6QAX5 / 7
    4256A65G05s 3
    4256A64G05
    3A99163G05
    / G50 6QAX5 / 7
    4256A65G05s 2
    4256A64G05
    3A99163G05 7QAX5 / 7
    QAX G05 12 point AI card - 0 to 5V w/ 12ea QAXD G05s
    (3A99163G50) 3
    4256A64G05
    3A99163G05
    / G50 7QAX5 / 7 QAX G05 12 point AI card - 0 to 5V w/ 12ea 6QAXD5 G05s 4
    4256A64G06 QAX QAX G06 12 point AI card - 0 to 10V 0
    4256A65G02 4QAXD2 QAXD G02 QAX Digital daughter card 0
    4256A65G03 4QAXD3 QAXD G03 QAX Digital daughter card 0
    4256A65G05 4QAXD5 QAXD G05 QAX Digital daughter card 24
    4256A65G06 4QAXD6 QAXD G06 QAX Digital daughter card 0
    4256A66G01 2DPU1 386 WS DPU Backplane 11
    4256A66G01 3DPU1 386 WS DPU Backplane 8
    4256A67G01 3MBPS13 MBPS Board inside 4D33755G01 Power Supply Assy 18
    4256A76G02 QST QST G02 4 to 20 mA Ext Volt 0
    4256A77G01 SST SST G01 Daugter card on QLC G01 0
    4256A84G03
    3A99159G03 3QID23 QID G03 24VDC/AC card 0
    4256A84G06 1QID6 QID G06 card 3
    4256A84G11 3QID11 QID G11 card 0
    4256A86G01 QAXT QAXT Terminal Block Temperature Sensing card 0
    4256A88G01 3MDX3 MDX G01 Board 2
    4256A88G01 4MDX7 MDX G01 Board 2
    4256A88G03 5MDX3 MDX G03 Board (32-bit 486 processor) Sub H 21
    4256A88G04 5MDX4 MDX G04 Board Sub H 32
    4256A88G04 7MDX1 MDX G04 Board 47
    4256A88G04 9MDX1 MDX G04 Board Sub K 55
    4256A88G04 10MDX1 MDX G04 Board 12
    4256A90G01 2SGI5 SGI Highway Communication card (for SUN Sparc systems) 15
    4256A90G02 2SGI6 SGI Highway Communication card (for GHC Enclosures) 11
    4256A91G01 3GHC12 GHC Data Highway Board 1
    4256A91G02 3GHC10 SUN VME Chassis GHC w/ 3A59504G02-08 SHC 2.3 firmware 5
    4256A91G03 4GHC3 GHC Data Highway Board 8
    4256A93G01 2IGI3 IGI Highway Communication card Sub C 2
    4256A94G01 3QVP9 QVP G01 LVDT 80 Ohm card 5
    4256A96G01 3SCPS2 SCPS Power Supply (Daughter card on GHC) 1
    4256A96G02 3SCPS4 SCPS Power Supply (Daughter card on GHC) 1
    4256A97G01 5DPX1 486 WEStation DPU Backplane 63
    4256A99G02 4DIOB1 DIOB Backplane on Q-crates 1
    4256A99G02 5DIOB1 DIOB Backplane on Q-crates 10
    4A00054H04 Monitor Intecolor E20FEC 3
    4A00030G01 Cable DPX to QBE Power Cable 10
    4A00030G03 Cable DPX to QBE Power Cable 10
    4A00081G01 Hard Drive Micropolis 1325 85MB HD 3
    4A00081H01 Hard Drive Maxtor XT1085 85MB HD 2
    4A00090G02 DAT Drive Sun (599-2107-01) DDS3 DAT drives ( 4mm 12/24GB ) 5
    4A00090G02 DAT Drive Sun (599-2350-01) DDS4 DAT drives ( 4mm 20/40GB ) 5
    4A02729G17 Cable Power Monitor Panel Assy Cable 3
    4A02733G02 Panel Power Supply Monitor Panel 3
    4A04102G01 Card Cage WEStation MMI Kit (sticker on front edge of VME chassis) 2
    4A04102G02 Card Cage
    WEStation MMI Kit (sticker on front edge of VME chassis) w/
    Serial Port Device 2
    4A05326G01 Panel Power Monitor Panel w/ cable Assy 4A02729G17 13
    4A06727G13 E-Prom Kit 4MB E-Prom Kit 1
    4A06769H01 SUN 4651 Proc VME MB SUN P# 5012055006976 1
    4A06769H01 SUN 4651 Proc VME MB SUN P# 5012015035366 1
    4A07587G01 Cable MBUS Power Cable 115VAC 20
    4D04642G01 Light Cabinet Light Assy 2
    4D33612G02 Chassis MMI Chassis 5
    4D33613G01 Power Supply
    MMI Power Supply Module w/ PowerOne
    NRG4A70B4B4K0RZ108 Brick 115VAC 32
    4D33613G02 Power Supply
    NRG4A70B4B4K0RZ108 Brick 230VAC 9
    4D33617G01 OVP Assy Module on RTE Power/Mate SW-12-K-P2956 1
    4D33644G01 Keyboard WDPF Operator Desk Top Detached cord Keyboard 115VAC 21
    4D33644G02 Keyboard WDPF Operator Desk Top Detached cord Keyboard 230VAC 5
    4D33644G03 Keyboard
    WEStation Operator Desk Top Detached cord Keyboard
    115VAC 9
    4D33644G04 Keyboard
    230VAC 0
    4D33644G05 Keyboard
    115VAC 10
    4D33644G06 Keyboard
    230VAC 1
    4D33645G01 Keyboard WDPF Operator Console Detached cord Keyboard 115VAC 6
    4D33645G02 Keyboard WDPF Operator Console Detached cord Keyboard 230VAC 0
    4D33645G04 Keyboard
    WEStation Operator Console Detached cord Keyboard
    115VAC 7
    4D33645G05 Keyboard
    230VAC 1
    4D33646G01 DT Hwy Ctrlr
    DT Hwy Controller box (supplied w/ any Multibus Highway
    Controller Bd required) 1
    4D33646G03 DT Hwy Ctrlr
    4D33646G05 DT Hwy Ctrlr
    Controller Bd required) 17
    4D33668G01 RTP Enclosure Assy RTP Enclosure Assy 7
    4D33676G01 TCU Drive Assy
    Total Control Unit w/ Hard Drive, Floppy, and power supply -
    115VAC 1
    4D33676G02 TCU Drive Assy
    230VAC 1
    4D33676G03 TCU Drive Assy
    Total Control Unit w/ HD, Floppy, and P/S mounted 2ea on a
    rack tray - 115VAC 8
    4D33676G04 TCU Drive Assy
    rack tray - 230VAC 8
    4D33710G01
    PowerDistribution
    Assy UniPower PG2233 & 3WPM2 4256A57G01 Enclosed 115VAC 6
    4D33710G02
    Power Distribution
    Assy UniPower PG2233 & 3WPM2 4256A57G01 Enclosed 230VAC 6
    4D33711G01 Power Supply Assy Acme HF-75753 12 VDC Power Supply RIO Box 0
    4D33711G02 Power Supply Assy Acme 2FA1900002A 24 VDC Power Supply RIO Box 0
    4D33711G03 Power Supply Assy Acme 48 VDC Power Supply RIO Box 0
    4D33743G01 Power Supply Assy
    SLIM Power Supply Assy with new Deltron P/S bricks -
    115VAC 3
    4D33743G02 Power Supply Assy SLIM Power Supply Assy with new Deltron P/S bricks – 3
    Multibus P/S for 386 WEStation DPUs w/ 4256A67G01
    3MBPS13 Board - 115V AC/DC 63
    4D33755G02 Power Supply Assy
    3MBPS13 Board - 230V AC/DC 36
    4D33755G03 Power Supply Assy
    Multibus P/S for 486 WS DPUs MPS512-A w/ 4256A67G01
    3MBPS13 - 115V AC/DC 7
    4D33755G04 Power Supply Assy
    3MBPS13 - 230V AC/DC 7
    4D33764G01 TFR Panel Assy
    TFR Panel RIO Box w/ 2ea 4256A51G01 3QFR2 cards &
    4256A58G01 Backplane 33
    TFR Panel RIO Box w/ 6ea 4256A51G01 3QFR2 cards &
    4256A58G01 Backplane 8
    4D33770G01 TAP Box Assy
    TAP Box Assy w/ 2ea Yellow Hwy Cables 3A59527G18, 2ea
    Green 3A59526G18, and 2ea Green 3A98720G18 cables 1
    4D33804G03 Halfshell DC Distribution Halfshell 4
    4D33804G04 Halfshell DC Distribution Halfshell 4
    4D33805G01 FOR Fiber Optic Repeater w/ 5FTC17 7381A66G03 4
    4D33810G01
    Power Distribution
    Assy UniPower PG2233 & 3WPM2 4256A57G01 Enclosed 115VAC 1
    4D33810G02
    Power Distribution
    Assy UniPower PG2233 & 3WPM2 4256A57G01 Enclosed 230VAC 1
    4D33811G01 GHC Enclosure
    DT Hwy Controller Enclosure (2GHC6 G01, 3SCPS4 G01, &
    2SGI6 G02 cards) w/ SHC 2.0 firmware 2
    DT Hwy Controller Enclosure (3GHC12 G01, 3SCPS4 G01, &
    2SGI6 G02 cards) w/ SHC 2.0 firmware 3
    DT Hwy Controller Enclosure (4GHC3 G01, 3SCPS4 G01, &
    2SGI6 G02 cards) w/ SHC 2.3 firmware 4
    4D33811G02 GHC Enclosure
    DT Hwy Controller Enclosure (3GHC20 G03, 3SCPS4 G02, &
    2SGI6 G02 cards) w/ SHC 2.3 firmware 6
    DT Hwy Controller Enclosure (4GHC3 G03, 3SCPS4 G02, &
    2SGI6 G02 cards) w/ SHC 2.3 firmware 11
    2SGI6 G02 cards) w/ SHC 2.4 firmware 20
    DT Hwy Controller Enclosure (4GHC7 G03, 3SCPS4 G02, &
    2SGI6 G02 cards) w/ SHC 2.4 firmware 1
    4D33816G01 VME Sun Sparc VME Board (3A99732H03 Motherboard) 7
    4D33816G03 VME Sun Sparc VME Board (3A99732H03 Motherboard) 1
    4D33816G04 VME Sun Sparc VME Board (3A99732H03 Motherboard) 4
    4D33864G01 Power Supply Power Supply Chassis for 2ea Plug-in I/O Power Supply Assy 2
    4D33865G01 Power Supply
    Plug-in 24V DC I/O P/S Assy - 1 Output w/ 2IOPS16
    3A99254G01 - 115/230VAC 0
    4D33865G02 Power Supply Plug-in 48V DC I/O P/S Assy - 1 Output 0
    4D33865G03 Power Supply
    Plug-in 24V DC I/O P/S Assy - 2 Output w/ 4IOPS3 3A99254G03
    - 115/230VAC 2
    4D33865G04 Power Supply Plug-in 24/48V DC I/O P/S Assy 1 Output 0
    4D33865G05 Power Supply Plug-in 48V DC I/O P/S Assy 2 Output 0
    4D33865G06 Power Supply Plug-in 24V DC I/O P/S Assy 1 Output 115/230VDC 0
    4D33888G01 Panel Ovation AC Distribution Center Panel 2
    4D33900G19 Power Supply Ovation DIN RAIL Power Supply Assy 2
    4D33913G01 Power Supply Plug-in 13V DC I/O Power Supply Assy - DAPS - w/ AC Input 2
    4D33913G02 Power Supply
    Plug-in 13/24V DC I/O Power Supply Assy - DAPS - w/ AC
    Input 6
    4D33913G03 Power Supply
    Plug-in 13/48V DC I/O Power Supply Assy - DAPS - w/ AC
    Input 0
    4D33913G04 Power Supply Plug-in 13V DC I/O Power Supply Assy - DAPS - w/ DC Input 16
    4D33913G05 Power Supply
    Plug-in 13/24V DC I/O Power Supply Assy - DAPS - w/ DC
    Input 1
    4D33913G06 Power Supply
    Plug-in 13/48V DC I/O Power Supply Assy - DAPS - w/ DC
    Input 0
    4D33914G02 Rack Assy I/O Power Supply Rack Assy 4
    4D33914G03 Rack Assy I/O Power Supply Rack Assy 1
    4D33914G05 Rack Assy I/O Power Supply Rack Assy 2
    4D33915G02 Chassis WEStation 486 Processor DPU Cabinet Assy 6
    Multibus P/S MPS512-DC Plug-in P/S 486 WS DPU w/
    3A99220G01 MEPS card 73
    4D33922G01 Panel Ovation Panel Assy Enclosure for 3A99199G01 backplane 1
    4D33935H01 Keyboard Ovation Mylar Operator Keyboard 7
    4D33942G01 Controller Ovation Controller (Chassis/Metalwork/Fan) 2
    4D33945G01 Controller Ovation Controller (Chassis/Metalwork/Fan) 2
    5870C46G02 Cabinet Ovation Cabinet (Hoffman) 1
    599C39G05-8 Halfshell Extension Halfshell Extension Assembly - Right 14
    599C39G06-8 Halfshell Extension Halfshell Extension Assembly - Left 14
    599C39G08-8 Halfshell Extension Halfshell Extension Assembly 6
    599C40G01-
    10 Halfshell Extension Halfshell Extension Assembly - Right XMTR Pwr (6 fused) 10
    599C40G02-
    10 Halfshell Extension Halfshell Extension Assembly - Left XMTR Pwr (6 fused) 8
    599C41G03-9 Halfshell Extension Halfshell Extension Assembly - Right (8 fused) 4
    599C41G04-9 Halfshell Extension Halfshell Extension Assembly - Left (8 fused) 8
    599C42G01 Halfshell Extension Halfshell Extension Assembly - Right (single fused) 8
    599C42G02 Halfshell Extension Halfshell Extension Assembly - Left (single fused) 8
    5A22138G01-
    3 Cable 9pin serial ribbon cable (attached to QVP) 4
    5A22411H01 Module Ovation Relay Module 16 Channel G2R Relay Panel 10A 2
    5A23251G09 Cabinet 486 WEStation DPU Cabinet Assy (sticker on top) 1
    5A23307H15 Sun Workstation
    Sparc5 built to your spec - all processors/options avail - w/
    SGI 27
    5A26129G01 Cable Dual AC Power Cord Cable 5
    5A26137G01 Cable Ovation Cable 1
    5A26137G03 Cable Ovation Cable 1
    5A26137G04 Cable Ovation Cable 1
    5A26141G05 Cable Ovation Cable 1
    5A26144G03 Cable Ground Cable 1
    5A26148G14 Cable Ovation Cable 1
    5A26158G01 Cable DC Power Cable 10
    5A26391H03 CPU Board PF5133HX/512 WH3M MMX CPU Board 2
    5A26397G02 GHC Kit GHC Enclosure, PGI comm card, and interface cable 10
    5A26421G01 Monitor 21/20" Mitsubishi DS200 CRT (20.1" LCD replacement) 5
    5A26430H04 Floppy Drive 370-3159 Internal 3.5" Floppy Drive for Ultra 5/10 5
    5A26430H11 CD ROM 370-3694 Internal 32x CD-ROM for Ultra 5/10 5
    5A26430H12 Hard Drive 370-3693 Internal 9.0GB Hard Drive for Ultra 5/10 5
    5A26430H13 Memory 370-3796 32mb Memory Ultra 5/10 5
    5A26430H14 Memory 370-3797 64mb Memory Ultra 5/10 5
    5A26430H15 Memory 370-3798 128mb Memory Ultra 5/10 5
    5A26430H20 Drive Internal 20GB drive Ultra5/10 3
    5A26431G05 Ultra 10 Ultra10 (configured to customer spec w/ or w/o PGI) 5
    5A26432H02 NIC Card 501-2741 NIC card for Ultra5 on Ovation 5
    5A26433H01 PCI PCI Bus SCSI Adapter 8
    5A26434H01 Graphics PCI PGX Graphics Card 3
    5A26438G01 Printer HP 5000 LaserJet Printer 3
    5A26477G01 Printer HP 2500CM Color InkJet Printer 3
    5A26481G01 Cable PCQL to Q-line Adapter ribbon cable 6
    5A26499G01 Monitor
    22/20" Mitsubishi DiamondScan 200+ CRT (20.1" LCD
    5A28137G04 Cable Cable 1
    5D32022G01 Panel Cluster Tap Panel Hwy Trans sub assys in Cluster Tap Panel 2
    5D32024G01 RTP Assy RTP Bracket Assy w/ 4256A08G02 3RTP6 8
    5D32025G04 Ethernet TAP Ethernet TAP 4
    5D32035G02 Panel Cluster TAP Panel w/ 1ea 4256A08G02 3RTP6 card 1
    5D32046G02 Drive VME Hard Drive Assy w/ 1.3GB Disk 2
    5D32052G01 VME Assy VME Assy MMI Kit Assy w/ SHC card 2
    5D32052G05 VME Frame WEStation Std 3A99678G21 2
    5D32078G03 CPU Adpater Solflower SF VME-300 3
    5D32078G04 CPU Adpater Solflower SF VME-300 7
    5D32078G07 CPU Adpater Solflower SF VME-300 1
    5D32083G02 Drive Assy VME Disk Assy w/ 2ea 2GB drives 0
    5D32083G04 Drive Assy VME Disk Assy w/ 2ea 4GB Seagate ST15150N drives 1
    5D32083G05 Drive Assy
    VME Disk Assy WDE 4360, Seagate ST12400N, and Exabyte
    HHCTS 1
    5D32046G02 Drive Assy VME Disk Assy 1.3GB Disk Assy (w/ Fugitsu drive) 4
    5D32046G08 Drive Assy VME Disk Assy 1.3GB Disk Assy (w/ Quantum 1225S drive) 3
    5D32046G09 Drive Assy
    VME Disk Assy 5.2GB Disk Assy (w/ 4ea Quantum 1225S
    drives) 1
    5D32052G01 VME Card Cage VME Card Frame (on inside, side of chassis) 4
    5D32052G05 VME Card Cage VME Card Frame (on inside, side of chassis) 3
    5D32114G01 Chassis Dual card racks of 386 WEStation DPU 18
    5D32115G01 Cabinet I/O Quad Cabinet - 486 WEStation DPU 4
    5D32122G02 Chassis
    Top bar w/ cables on 386 WEStation DPU (on 5D32114G01
    Chassis) 22
    5D32123G01 Panel AC/DC Power Distribution Panel 3
    5D32123G02 Panel AC/DC Power Distribution Panel 10
    5D32123G03 Panel AC/DC Power Distribution Panel 1
    5D32149G01 Chassis 486 WEStation DPU card cage 34
    5D32161G01 Chassis 486 WEStation DPU chassis assy 28
    5D32161G02 Chassis 486 WEStation DPU chassis assy 20
    5D32191G01 Power Supply
    MultiBus P/S MPS512-PFC for 486 WS DPU w/ 3A99116G01
    MDPS 115VAC 85
    5D32191G02 Power Supply
    MDPS 230VAC 74
    5D92481G06 Power Supply HC Power Inc HS1244-C1353 0
    5D92830G01 Relay Panel Form C, KUEP, 16 fuses (for H/S assembly) 8
    5D92848G01 Transceiver
    Ethernet 10Mbit/sec Transceiver unit (MAU) - Ethernet Tap
    Bracket Assy 20
    5X00006H12 Cartridge Travan 20GB Tape Cartridge 3
    5X00058G01 Analog Module Ovation Hart Analog Output Module 1
    5X00059G01 Analog Module Ovation Hart Analog Input Module 1
    5X00062G01 Analog Module Ovation Hart Analog Output Module 1
    5X00063G01 Analog Module Ovation Hart Analog Output Module 1
    5X00082H12 Cartridge Sony 1/2 Data Cartridge 4
    5X00105G01 Board Ovation Control Board 2
    5X00117H02 Keyboard SUN UNIX (US) Type 6 Keyboard and Mouse 5
    5X00117H03 Keyboard SUN USB Type 6 Keyboard and Mouse 5
    5X00117H04 Memory 256MB DRAM Expansion For Sun Blade 100 5
    5X00117H06 Drive Hard Disk 20GB EIDE for Sun Blade 100 5
    5X00128G01 Monitor 22/20" NEC CRT (20.1" LCD replacement solution) 5
    5X00134G01 Sun Workstation
    SUN Microsystems Blade 100 (configured to customer spec w/
    or w/o PGI) 5
    5X00134G02 Sun Workstation
    SUN Microsystems Blade 150 (configured to customer spec w/
    or w/o PGI) 5
    5X00178G01 Monitor 20.1" LCD Monitor 5
    5X00230G01
    1P00049G01 2QOL QOL G01 card 2
    5X00286H13 Mouse 2-button Optical corded USB mouse 1
    5X00290G01 Monitor 21/20" NEC CRT (20.1" LCD replacement solution) 5
    7379A06G02
    7379A06G82 2QCI13 QCI G02 Contact Closure Input card 1
    7379A06G02 3QCI1 QCI G02 Contact Closure Input card 1
    7379A06G02 3QCI3 QCI G02 Contact Closure Input card 1
    7379A06G02 4QCI2 QCI G02 Contact Closure Input card 42
    7379A06G02 4QCI3 QCI G02 Contact Closure Input card 2
    7379A06G02 4QCI4 QCI G02 Contact Closure Input card 15
    7379A06G02
    3A99160G02 6QCI1 QCI G02 Contact Closure Input card 114
    7379A13G01 QPA QPA G01 Pulse Accumulator card 0
    7379A13G04 6QPA8 QPA G04 Pulse Accumulator card 48V sub Y 4
    7379A21G01 5QAV4 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 1
    7379A21G01 5QAV9 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 1
    7379A21G01 5QAV14 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 9
    7379A21G01 5QAV19 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 10
    7379A21G01 6QAV16 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 7
    7379A21G01
    3A99164G01 8QAV1 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 7
    7379A21G02 5QAV20 QAV G02 Analog Input Point card - -12.5 to +50mVDC, 500ohm 4
    7379A21G02 6QAV12 QAV G02 Analog Input Point card - -12.5 to +50mVDC, 500ohm 18
    7379A21G02 6QAV17 QAV G02 Analog Input Point card - -12.5 to +50mVDC, 500ohm 33
    7379A21G02
    3A99164G02 8QAV2 QAV G02 Analog Input Point card - -12.5 to +50mVDC, 500ohm 75
    7379A21G02
    3A99164G02
    3A99164G50 8QAV4 QAV G02 Analog Input Point card - -12.5 to +50mVDC, 500ohm 9
    7379A21G03 5QAV21 QAV G03 Analog Input Point card - -25 to +100mVDC, 1Kohm 1
    7379A21G03
    3A99164G03
    3A99164G50 8QAV4 QAV G03 Analog Input Point card - -25 to +100mVDC, 1Kohm 0
    7379A28G02 4QAM6
    QAM G02 Auto/Manual Stn Ctrlr card - 0 to +20mA, 0 to +5VDC
    (output) 2
    7379A28G02 4QAM7
    (output) 2
    7379A29G01 3QDT1 QDT Diagnostic Test card 7
    7379A29G01 3QDT1 QDT Diagnostic Test card w/ 4256A36G01 1QDTD1 daughter 3
    7379A31G01 3QAW5 QAW G01 Analog High-Level Input Point card - 0 to +1VDC 3
    7379A31G01 5QAW7 QAW G01 Analog High-Level Input Point card - 0 to +1VDC 1
    7379A31G01
    / 6QAW13 QAW G01 Analog High-Level Input Point card - 0 to +1VDC 0
    7379A31G81
    7379A31G02 7QAW2 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 1
    7379A31G02 7QAW9 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 11
    7379A31G02 7QAW15 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 3
    7379A31G02
    3A99165G02 9QAW18 / 22 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 4
    7379A31G02
    3A99165G50 9QAW26 / 30 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 3
    7379A31G02
    3A99165G50 9QAW30 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 2
    7379A31G03 5QAW15 QAW G03 Analog High-Level Input Point card - 0 to +10VDC 2
    7379A31G03 7QAW3 QAW G03 Analog High-Level Input Point card - 0 to +10VDC 1
    7379A31G03
    3A99165G03
    3A99165G50 9QAW19 / 22
    QAW G03 Analog High-Level IP card - 0 to +10VDC w/ 6ea
    4QAXD6 G06 2
    7379A31G03
    3A99165G03
    3A99165G50 9QAW27 / 30
    4QAXD6 G06 2
    7379A31G04 3QAW8 QAW G04 Analog High-Level Input Point card - 0 to +20mA 3
    7379A31G04 5QAW10 QAW G04 Analog High-Level Input Point card - 0 to +20mA 1
    7379A31G04 7QAW11 QAW G04 Analog High-Level Input Point card - 0 to +20mA 9
    7379A31G04 7QAW17 QAW G04 Analog High-Level Input Point card - 0 to +20mA 3
    7379A31G04
    3A99165G04
    / G52 9QAW20 / 24
    QAW G04 Analog High-Level IP card - 0 to +20mA w/ 6ea
    4QAXD5 G05s 6
    7379A31G04
    3A99165G04
    / G52 9QAW32
    4QAXD5 G05s 1
    7379A31G05
    3A99165G51 9QAW29
    QAW G05 Analog High-Level Input Point card - 0 to +20mA
    (self-powered) 1
    7379A31G05
    3A99165G51 9QAW33 / 34
    (self-powered) 4
    7379A31G06 5QAW18 QAW G06 Analog High-Level Input Point card - 0 to +50mA 1
    7379A31G06 7QAW19 QAW G06 Analog High-Level Input Point card - 0 to +50mA 1
    7379A34G01 QMR QMR G01 card 0
    7379A36G01 4QAH25 QAH G01 High-Speed Analog Input Point card - (+/-) 10VDC 1
    7379A36G01 4QAH37
    Sub Q 1
    7379A36G01 4QAH49 QAH G01 High-Speed Analog Input Point card - (+/-) 10VDC 1
    7379A36G02 4QAH34 QAH G02 High-Speed Analog Input Point card - (+/-) 5VDC 1
    7379A36G03 4QAH39 QAH G03 High-Speed Analog Input Point card - 0 to 10VDC 9
    7379A36G04 QAH QAH G04 High-Speed Analog Input Point card - 0 to 5VDC 0
    7379A39G03 QAE QAE G03 card 0
    7379A47G04 QMA QMA G04 card 0
    7379A62G01 2QRT9 QRT G01 RTD Input Amp card - 10mV 1
    7379A62G01 2QRT9
    QRT G01 RTD Input Amp card - 10mV w/ 4ea 2FILM
    7379A90G06 RTD 1
    7379A62G01 4QRT1 QRT G01 RTD Input Amp card - 10mV 1
    7379A62G01 4QRT1
    QRT G01 RTD Input Amp card - 10mV w/ 4ea 1DRE
    7380A92G06 RTD 3
    7379A62G01 4QRT1
    QRT G01 RTD Input Amp card - 10mV w/ 3ea 1DRE
    7380A92G06 RTD 1
    7379A62G01 4QRT1
    7379A90G06 RTD 1
    7379A62G01 4QRT2 QRT G01 RTD Input Amp card - 10mV 1
    7379A62G01 4QRT2
    QRT G01 RTD Input Amp card - 10mV w/ 1DRE 7380A92G06
    daughters 1
    7379A62G02 2QRT1 QRT G02 RTD Input Amp card - 33mV 1
    7379A62G02 4QRT2 QRT G02 RTD Input Amp card - 33mV 1
    7379A62G02 4QRT2
    QRT G02 RTD Input Amp card - 33mV w/ 4ea 3DRE2
    7380A92G02 1
    7379A62G02 4QRT2
    QRT G02 RTD Input Amp card - 33mV w/ 4ea 3DRE3
    7380A92G03 4
    7379A62G02 4QRT2
    QRT G02 RTD Input Amp card - 33mV w/ 2ea 3DRE3
    7380A92G03 1
    7379A62G02 4QRT2
    QRT G02 RTD w/ 2ea 3DRE3 G03 & 2ea 3DRE G03 /
    9690A38G34 1
    7379A62G02 4QRT2
    QRT G02 RTD Input Amp card - 33mV w/ 3ea 3DRE2 G02 & 1ea
    3DRE4 G04 2
    7379A62G02 4QRT2
    QRT G02 RTD Input Amp card - 33mV w/ 4ea 1DRE10
    7380A92G04 9
    7379A62G02 4QRT2
    QRT G02 RTD Input Amp card - 33mV w/ 4ea 3DRE3 G01 /
    9690A38G34 4
    7379A62G02 4QRT4
    9690A38G34 9
    7379A62G02 4QRT4 QRT G02 RTD Input Amp card - 33mV 3
    7379A66G01 QMB QMB G01 card 0
    7379A70G02 2QMT5 QMT G02 M-Bus Terminator card - 13VDC monitor Sub 3 3
    7379A70G03 2QMT3 QMT G03 M-Bus Terminator card - 13VDC monitor Sub 5 9
    7379A78G01 QIA QIA G01 card 0
    7379A82G01 QSI QSI G01 card 0
    7379A84G01 3QBE5 QBE G01 Bus Extender card - DIOB discharging Sub 1 3
    7379A84G01 3QBE7 QBE G01 Bus Extender card - DIOB discharging Sub 2 10
    7379A84G01 4QBE1 QBE G01 Bus Extender card - DIOB discharging Sub 3 58
    7379A84G01 4QBE3 QBE G01 Bus Extender card - DIOB discharging Sub 4 6
    7379A84G01 4QBE5 QBE G01 Bus Extender card - DIOB discharging Sub 5 2
    7379A89G01 4MBU7 MBU Board 1
    7379A89G01 4MBU8 MBU Board 1
    7379A89G01 5MBU3 MBU Board 7
    7379A89G01 5MBU5 MBU Board 2
    7379A89G01
    772B222G01 5MBU3 MBU Board 3
    7379A89G01
    772B222G01 5MBU5 MBU Board 2
    7379A89G01
    772B222G02 5MBU3 MBU Board 1
    7379A90G06 2FILM7 FILM G06 daughter card (RTD on QRT) 4
    7379A91G02 2QAA3 QAA G02 Actuator Auto/Manual card card - Beck Dr. 13
    7379A92G02 3MBC6 MBC Board 1
    7379A92G02 4MBC8 MBC Board 13
    7379A92G03 7MBC2 MBC Board 82
    7379A93G01 2MBD14 MBD Board 4
    7379A93G01 3MBD11 MBD Board 3
    7379A93G01 3MBD17 MBD Board 2
    7379A93G01 3MBD18 MBD Board 33
    7379A94G06 2MBS14 MBS Board 3
    7380A17G01 3FILM FILM Board 1
    7380A18G01 3MBK1 MBK bd in fixed cord optr keybds 5
    7380A27H01
    772B379G01 Intel PBA 143472-004 1
    7380A29G03 Intel Intel daugter card on MSP 14
    7380A31G01 3MSC9
    MMI P/S Controller card in 4D33613G01 and/or 1661D89G05
    MMIs 5
    7380A36G01 3QSE2 QSE Sequence of Events Recorder card - 7 to 21mA 1
    7380A36G01 5QSE4 QSE Sequence of Events Recorder card - 7 to 21mA Sub J 2
    7380A36G01 5QSE6 QSE Sequence of Events Recorder card - 7 to 21mA 1
    7380A36G01 7QSE1 QSE Sequence of Events Recorder card - 7 to 21mA 3
    7380A36G01 7QSE5 QSE Sequence of Events Recorder card - 7 to 21mA Sub X 7
    7380A37G01 3DCS17 DPU P/S Controller card in 1D54582G01 and/or G05 10
    7380A37G03 3DCS23 DPU P/S Controller card in 1D54582G03 3
    7380A43G01 4MVP7 PC Bd 1
    7380A43G02 MVP PC Bd 0
    7380A51G01 MPP 1
    7380A67G01 2DBK2 WDPF DBK daughter card (on QAA) 5
    7380A70G02 4MBT6 MBT Board 39
    7380A72G01 1SBA2 SBA daugter card on MSP 14
    7380A78G01 3DPU1 DPU back plane (9 slot) 25
    7380A84H01 Extender Multibus Card Extender PBA 1000280-03 4
    7380A92G01 3DRE1 DRE G01 daughter card for QRT card (Copper) 108
    7380A92G02 1DRE8 DRE G02 daughter card for QRT card (Platinum) 6
    7380A92G03 1DRE9 DRE G03 daughter card for QRT card (120 Ohm Nickle) 13
    7380A92G03 3DRE3 DRE G03 daughter card for QRT card (120 Ohm Nickle) 3
    7380A92G04 1DRE10 DRE G04 daughter card for QRT card (100 Ohm Platinum) 22
    7380A92G06 1DRE DRE G06 daughter card for QRT card (100 Ohm Copper) 8
    7381A01G01
    772B388G01 3MSP32 Multibus Shared Processor Board 1
    7381A01G01
    772B388G01 5MSP13 Multibus Shared Processor Board 1
    7381A01G01
    772B388G02 3MSP32 Multibus Shared Processor Board 2
    7381A01G01
    772B388G02 6MSP25 Multibus Shared Processor Board 1
    7381A01G01
    772B388G10 3MSP3 Multibus Shared Processor Board 1
    7381A01G01
    772B388G10 3MSP32 MSP Board w/ 7380A71G01 2SBG1 daughter 1
    7381A01G01
    772B388G25 8MSP1 Multibus Shared Processor Board 5
    7381A01G01
    772B388G25 8MSP11 Multibus Shared Processor Board 3
    7381A01G01
    772B388G25 8MSP13 Multibus Shared Processor Board 1
    7381A01G01
    772B388G26 8MSP1 Multibus Shared Processor Board 3
    7381A01G01
    772B388G26 8MSP9 Multibus Shared Processor Board 1
    7381A01G01
    772B388G26 8MSP11 Multibus Shared Processor Board 3
    7381A01G01
    772B388G26 8MSP13 Multibus Shared Processor Board 1
    7381A01G01
    772B388G26 8MSP11 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 1
    7381A01G02
    / 8MSP2 Multibus Shared Processor Board 1
    772B388G24
    7381A01G02
    773B388G21 3MSP33 Multibus Shared Processor Board 2
    7381A01G03 8MSP21 Multibus Shared Processor Board 1
    7381A01G03
    772B388G29 6MSP21 Multibus Shared Processor Board 1
    7381A01G03
    772B388G29 6MSP27 Multibus Shared Processor Board 1
    7381A01G03
    772B388G29 8MSP3 Multibus Shared Processor Board 2
    7381A01G03
    772B388G29 8MSP7 Multibus Shared Processor Board 13
    7381A01G03
    772B388G29 8MSP12 Multibus Shared Processor Board 7
    7381A01G03
    772B388G29 8MSP15 Multibus Shared Processor Board 3
    7381A01G03
    772B388G29 8MSP21 Multibus Shared Processor Board 2
    7381A01G03
    772B388G29 8MSP7 MSP Board + 2ea 1SBA2 daughters 7380A72G01 1
    7381A01G03
    772B388G30 8MSP7 Multibus Shared Processor Board 1
    7381A01G03
    772B388G30 8MSP15 Multibus Shared Processor Board 1
    7381A01G03
    772B388G38 8MSP10 Multibus Shared Processor Board 1
    7381A01G03
    772B388G38 8MSP7 Multibus Shared Processor Board 1
    7381A01G03
    772B388G38 8MSP7 MSP Board w/ Intel PBA 146040-001 daughter 1
    7381A01G03
    772B388G38 8MSP12 Multibus Shared Processor Board 1
    7381A01G03
    772B388G38 8MSP6 MSP Board w/ Intel PBA 146040-001 daughter 1
    7381A01G03
    772B388G48 8MSP3 MSP Board w/ 249-06-01 Matrox MSBX-900 daughter 1
    7381A01G03
    772B388G48 8MSP7 MSP Board w/ 249-06-02 Matrox MSBX-900 daughter 2
    7381A01G03
    772B388G48 8MSP7 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 1
    7381A01G03
    772B388G53 8MSP3 Multibus Shared Processor Board 1
    7381A01G03
    772B388G53 8MSP7 Multibus Shared Processor Board 2
    7381A01G03
    772B388G53 8MSP3 MSP Board w/ 249-06-01 Matrox MSBX-900 daughter 2
    7381A01G03
    772B388G53 8MSP3 MSP Board w/ 249-06-02 Matrox MSBX-900 daughter 1
    7381A01G03
    772B388G53 8MSP7 MSP Board w/ 249-06-02 Matrox MSBX-900 daughter 3
    7381A01G03
    772B388G53 8MSP7 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 1
    7381A01G03
    772B388G53 8MSP12 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 1
    7381A01G03
    772B388G54 8MSP12 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 4
    7381A01G03
    772B388G54 8MSP15 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 2
    7381A01G03
    772B388G54 8MSP21 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 2
    7381A01G03
    7381A01G04
    772B388G16 6MSP22 Multibus Shared Processor Board 1
    7381A01G04
    772B388G16 8MSP8 Multibus Shared Processor Board 3
    7381A01G04
    772B388G37 6MSP22 Multibus Shared Processor Board 1
    7381A01G04
    772B388G50 8MSP4 MSP Board + 2ea 1SBA2 daughters 7380A72G01 3
    7381A01G04
    772B388G50 8MSP8 MSP Board + 2ea 1SBA2 daughters 7380A72G01 4
    7381A01G04
    772B388G50 8MSP8 Multibus Shared Processor Board 2
    7381A01G04
    772B388G51 8MSP4 Multibus Shared Processor Board 1
    7381A01G04
    772B388G51 8MSP8 Multibus Shared Processor Board 4
    7381A01G04
    772B388G55 8MSP8 Multibus Shared Processor Board 2
    7381A01G04
    772B388G55 8MSP8 MSP Board + 2ea 1SBA2 daughters 7380A72G01 17
    7381A01G04
    772B388G55 8MSP16 MSP Board + 2ea 1SBA2 daughters 7380A72G01 2
    7381A01G04
    772B388G55 8MSP22 MSP Board + 2ea 1SBA2 daughters 7380A72G01 1
    7381A01G04
    772B388G56 8MSP8 Multibus Shared Processor Board 10
    7381A01G04
    772B388G56 8MSP16 Multibus Shared Processor Board 1
    7381A01G04
    772B388G56 8MSP22 Multibus Shared Processor Board 1
    7381A01G04
    772B388G56 8MSP8 MSP Board + 2ea 1SBA2 daughters 7380A72G01 4
    7381A01G04
    772B388G56 8MSP16 MSP Board + 2ea 1SBA2 daughters 7380A72G01 1
    7381A01G04
    772B388G57 8MSP8 MSP Board + 2ea 1SBA2 daughters 7380A72G01 1
    7381A01G04
    772B388G57 8MSP8 Multibus Shared Processor Board 9
    7381A01G04
    772B388G57 8MSP8 MSP Board w/ 249-06-02 Matrox MSBX-900 daughter 1
    7381A01G04
    772B388G57 8MSP8 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 15
    7381A01G04
    772B388G57 8MSP8
    MSP Board w/ 249-06-04 Matrox MSBX-900 & Intel PBA
    146040-001 Dtrs 7
    7381A01G04
    772B388G57 8MSP16 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 5
    7381A01G04
    772B388G57 8MSP22 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 1
    7381A01G06
    772B388G52 8MSP6 MSP Board w/ Intel PBA 146040-001 daughter 2
    7381A01G06
    772B388G59 8MSP6 Multibus Shared Processor Board 3
    7381A01G06
    772B388G59 8MSP24 Multibus Shared Processor Board 1
    7381A06G01 3MUA7 MUA Board PC terminated 9
    7381A06G02 3MUA8 MUA Board PC terminated 1
    7381A06G02 3MUA9 MUA Board PC terminated 2
    7381A08G01 6MSL9 Multibus Sequential Logic Board 3
    7381A08G01 6MSL16 Multibus Sequential Logic Board 4
    7381A08G01 6MSL19 Multibus Sequential Logic Board 1
    7381A08G01 6MSL24 Multibus Sequential Logic Board 1
    7381A08G01 8MSL5 Multibus Sequential Logic Board 6
    7381A08G01
    772B400G04 6MSL18 Multibus Sequential Logic Board 1
    7381A08G01
    772B400G04 8MSL5 Multibus Sequential Logic Board 6
    7381A09G01 3MSM35 Multibus Shared Memory Board 1
    7381A09G01 3MSM36 Multibus Shared Memory Board 1
    7381A09G03 3MSM37 Multibus Shared Memory Board 1
    7381A10G01 3QLI32 QLI G01 10V card 1
    7381A10G01 3QLI47 QLI G01 10V card 1
    7381A10G02 3QLI60 QLI G02 5V card 1
    7381A10G03 3QLI18 QLI G03 20mA card 4
    7381A10G03 3QLI27 QLI G03 20mA card Sub K 7
    7381A10G03 3QLI28 QLI G03 20mA card 1
    7381A10G03 3QLI31 QLI G03 20mA card 2
    7381A10G03 3QLI37 QLI G03 20mA card 1
    7381A10G03 3QLI49 QLI G03 20mA card 5
    7381A10G03 3QLI51 QLI G03 20mA card 1
    7381A10G03 3QLI64 QLI G03 20mA card 1
    7381A10G03 3QLI76 QLI G03 20mA card 1
    7381A26G01 1FILM2 FILM MMI back plane dtr card 2
    7381A26G02 1FILM3 FILM MMI back plane dtr card 3
    7381A27G01 3LIM5 LIM Board inside LIM Station 4
    7381A28G02 4MBR18 MBR Board 1
    7381A29G01 3MSQ23 MSQ G01 Board 10
    7381A29G01 5MSQ7 MSQ G01 Board 7
    7381A29G01 5MSQ25 MSQ G01 Board 9
    7381A29G05 5MSQ10 MSQ G05 Board 6
    7381A30H02
    772B398G02 PBA card PBA 152185-005 INTEL card 1
    7381A34G01 4MME11 Multibus Memory Extended Board 23
    7381A34G02 4MME12 Multibus Memory Extended Board 16
    7381A46G01 2MVAQ1 WDPF Adapter Board 2
    7381A59G01 2FILM2 FILM Board inside 3D04057G01 Ctrl Stn 1
    7381A61G01 4MBB2 Back Plane MMI 0
    7381A61G02 2MBB2 Back Plane MMI 2
    7381A61G02 3MBB2 Back Plane MMI 1
    7381A61G02 4MBB2 Back Plane MMI 2
    7381A66G01 FTC Board FTC in FOR G01 5
    7381A66G03 FTC Board FTC in FOR G04 5
    7381A73G01 2QSS5 QSS Speed Sensor card sub F 5
    7381A73G01 2QSS7 QSS Speed Sensor card sub K 13
    7381A81G01 5MDM4 MDM Board 1
    7381A81G01 5MDM2 MDM Board w/ 7381A88G01 2MDMD1 dtr 1
    7381A81G01 5MDM4 MDM Board w/ 7381A88G01 2MDMD1 dtr 1
    7381A81G01
    772B452G01 5MDM2 MDM Board w/ 7381A88G02 2MDMD1 dtr 4
    7381A81G01
    772B452G01 5MDM4 MDM Board w/ 7381A88G01 2MDMD1 dtr 15
    7381A81G01
    772B452G01 5MDM4 Multibus DM Board 1
    7381A81G01
    772B452G01 5MDM8 MDM Board w/ 7381A88G01 2MDMD1 dtr 2
    7381A81G01
    772B452G01 5MDM9 Multibus DM Board 1
    7381A81G01
    772B452G02 5MDM2 Multibus DM Board 1
    7381A81G01
    772B452G02 5MDM4 Multibus DM Board 1
    7381A81G01
    772B452G02 5MDM2 MDM Board w/ 7381A88G01 2MDMD1 dtr 2
    7381A81G01
    772B452G02 5MDM4 MDM Board w/ 7381A88G01 2MDMD1 dtr 3
    7381A81G01
    772B452G02 5MDM4 Multibus DM Board 5
    7381A81G01
    772B452G02 5MDM8 Multibus DM Board 1
    7381A81G01
    772B452G03 5MDM4 Multibus DM Board 2
    7381A81G01
    772B452G04 5MDM8 Multibus DM Board 1
    7381A81G01
    772B452G05 5MDM2 Multibus DM Board 2
    7381A81G01
    772B452G05 5MDM4 Multibus DM Board 2
    7381A81G01
    772B452G05 5MDM8 Multibus DM Board 1
    7381A83G01 MSE Multibus Shared Extended Memory Board 0
    7381A83G02 4MSE10 Multibus Shared Extended Memory Board 31
    7381A83G02 4MSE12 Multibus Shared Extended Memory Board 34
    7381A83G02 4MSE14 Multibus Shared Extended Memory Board 24
    7381A86G01 Module NL-1032 120VAC Module (in blue plastic) 4
    7381A87G01 Module NL-1062 120VAC Module (in blue plastic) 3
    7381A88G01 2MDMD1 MDMD Dtr card on MDM Board 20
    7381A93G01 4MHC9 Multibus Highway Controller Board 7
    7381A93G01 4MHC13 Multibus Highway Controller Board 3
    7381A93G01 4MHC15 Multibus Highway Controller Board 9
    7381A93G01 4MHC17 Multibus Highway Controller Board 1
    7381A93G01 4MHC19 Multibus Highway Controller Board 3
    7381A93G01 4MHC31 Multibus Highway Controller Board 5
    7381A93G01 4MHC35 Multibus Highway Controller Board 2
    7381A93G01 7MHC5 Multibus Highway Controller Board 8
    7381A93G03
    4D33737G03 4MHC29 Multibus Highway Controller Board 1
    7381A93G03
    4D33737G03 4MHC31 Multibus Highway Controller Board 8
    7381A93G03
    4D33737G03 4MHC35 Multibus Highway Controller Board 17
    7381A93G03 7MHC9 Multibus Highway Controller Board 26
    7381A93G03 7MHC12 Multibus Highway Controller Board 1
    7381A93G03 7MHC18 Multibus Highway Controller Board 6
    7381A93G03 7MHC22 Multibus Highway Controller Board 30
    7381A93G03 9MHC4 Multibus Highway Controller Board 1
    7381A93G03
    / 11MHC1 Multibus Highway Controller Board 6
    3A99166G03
    7381A93G03
    3A99166G05 11MHC1 Multibus Highway Controller Board 1
    7381A93G05 7MHC24 Multibus Highway Controller Board 31
    7381A93G05 7MHC27 Multibus Highway Controller Board 35
    7381A93G05 9MHC6 Multibus Highway Controller Board 2
    7381A93G05
    3A99166G05 11MHC3 Multibus Highway Controller Board 83
    7412C33G01 Fan Assy Dual Fan Assy in 486 WEStation Cabinets (Bottom) 6
    7412C33G02 Fan Assy Dual Fan Assy in 486 WEStation Cabinets (Top) 6
    772B217G01 PBA card PBA 152148-001 INTEL card ISBC254S 1
    772B217G02 PBA card PBA 152148-001 INTEL card ISBC254S 1
    772B246G03 SMS SMS 8006 Board 0
    772B246G04 SMS SMS 8006 Board 0
    772B379G01
    7380A27H01 SBC SBC card Intel PBA134422-004 1
    772B379G01 SBC SBC card Intel PBA134422-005 1
    772B379G01 SBC SBC card Intel PBA134422-006 1
    772B379G01 SBC SBC card Intel PBA134422-007 4
    772B379G01 SBC SBC card Intel PBA143472-004 1
    772B387G01 Tapemaster card CIPRICO Tapemaster card 4
    772B398G01 Memtech Memtech card 2
    82402025 Card BIT 3 Corp Model 464-202 card 4
    8580A64G03 Power Supply Power Supply Module with TODD MDT-164-2415R 2
    9052A91H01 Tool Crimper Tool 0
    9052A91H02 Tool Crimper Tool 0
    9052A91H03 Tool Crimper Tool 0
    9115A09G12 Cable Q-line card cable (straight plug) 22
    9115A20G16 Cable MBU to QBE cable 6
    9115A23G06 Cable Ribbon cable off Transition panel 10
    9115A23G16 Cable MSL to TCP ribbon cable 10
    9115A25G04 Cable QBE to QBE cable 10
    9115A25G29 Cable Long, Wide 25pin ribbon (new) 4
    9339A37H01 Power Supply Pioneer Magnetics PM2497 4VF +12V 60A 2
    9690A38G34 RTD Card 3DRE 7380A92G03s on a 4QRT2 G02 (9690A38G34 on sticker) 2
    9690A38G38 RTD Card RTD Daughter 0
    9705A14H16 Card Grant Continuity Card (Digital 5016679 01) 2
    9705A33G01 Plug Black Plug on QBO card 4
    9942A27G05 Cable Data Hwy to MHC card cable 4
    9942A27G06 Cable Data Hwy to MHC card cable 3
    9942A27G07 Cable Data Hwy to MHC card cable 3
    9942A27G12 Cable Data Hwy to MHC card cable 10
    9942A29G04 Cable Ribbon Cable to MRC card 5
    9942A34G17 Cable 13v Power Supply Cable 3
    9942A49G06 Cable Mouse Cable 3
    D903900G06 Cabinet DPU Cabinet Assy 1
    D903900G07 Cabinet DPU Cabinet Assy 1
    Video card TurboxGx Video Card 13W3 270-2325 10
    SCSI card SCSI Interface Card 270-2919 5
    CD ROM 48x CD ROM 270-2919 6
    Power Supply Power Supply Sparc5 300-1279 10
    Hard Drive 1Gig (1080mb) Hard Drive SCSI 370-2168 5
    Power Supply Power Supply Ultra5 370-3162 10
    Card DIGITAL M7504-DEQNA 5016028-01 card 1
    Card PCI Card 370-3196 5
    Video card Raptor GFX Video Card 370-3753 5
    Hard Drive 8.6gig Hard Drive 370-3863 5
    Power Supply Power Supply Ultra5 370-4326 MITAC MPV-200REF 5
    Hard Drive 20Gb Hard Drive 370-4327 5
    Sun Workstation Ultra1 (configured to customer spec w/ or w/o SGI card) 3
    Sun Workstation Ultra5 (configured to customer spec w/ or w/o PGI card) 8
    Keyboard SUN Type 5c Keyboard and Mouse 5
    Backplane Sparc5/20 Hard Drive Backplane 501-2461 5
    Backplane Sparc5/20 Hard Drive Backplane 501-2462 5
    Memory Memory 32mb 501-2653 10
    SCSI card SCSI Card (PCI) 501-2741 5
    MotherBoard Sparc5 MotherBoard 501-2778 / 2779 5
    MotherBoard Ultra5 360MHz Processor 501-5148 5
    SCSI Card SCSI Card 501-5656 5
    Display 17 to 23" LCD Replacements for Sun Systems call
    Black Box Black Box model 5W090A 5
    Drive Hard Drive - 4.1GB 10K RPM F/W SCSI Drive 2
    Media
    External 6 Bay Multipack w/3 x 4.1GB 10K RPM F/W SCSI
    Drives 1
    Drive Unipack UltraSCSI 9.1GB External Disk Drive 599-2325-01 1
    Drive Unipack UltraSCSI 18.2GB External Disk Drive 599-2326-01 3
    Tape Drive QIC2000 2.5GB External Tape Drive 599-2042-02 3
    Tape Drive Model 411 4/8GB External DAT 4mm Tape Drive 595-3096-01 2
    CD ROM Model 411 External SCSI CD ROM Drive 595-3225-01 2
    Hard Drive Model 911 External Quad 3.5HD Drive 595-3286-01 2
    P/S Fan Fan for Deltron 11088XA (new) 20
    P/S Fan Fan for Deltron 11564XA-01 (new) 23
    Power Supply
    PowerOne HTAA-16W-A power supply inside operator
    keyboard 6
    Power Supply Elco KMC15U-1 power supply inside operator keyboard 2
    Power Supply Sorensen QSB28-2 24VDC P/S 2
    Rack P/S SOLA C VDC 5
    Speed Transmitter DYNALCO Type SS2000-410 4
    Sun Workstation SunBlade 100 w/ 3PGI1 card 4
    Sun Workstation SunBlade 150 w/ 3PGI1 card 4
    IBM CPU IBM Industrial Rack-mount PC Type 7546 5
    IBM IBM TECLADO 1394946 5
    Keyboard Keyboard model 3201233-01 3
    Reader SUN Reader 595-1711-04 1
    Trackball ITAC Sys B-SUNMD Trackball (White) 5
    Trackball ITAC Sys B-SUNID Trackball (Black) 5
    Mouse Logitech M-CU15-9F three button mouse 5
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • 劉治安 在2025/7/8 16:34:00留言
  • 详细留言:安川HW9171094-A請惠予報價
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
