厦门兴锐达自动化设备有限公司
  • 供应ALSTOM(MOTOROLA)
  • 发布时间:2009/10/19 15:49:01   修改时间:2009/7/27 16:37:26 浏览次数:753
    Produits au standard VME
    ICV107/20     CARTE VME MAITRE ACQUISITION RAPIDE 16MHz 2048K. mesures/s
    ICV108        CARTE VME MAITRE ACQUISITION RAPIDE 64 BITS Buffers de 2M. mesures/s
    ICV110/IBC   CARTE COUPLEUR ICV150 48 E.ANA. ISOLEES BOUCLE DE COURANT R="250Ohms"
    ICV110/ID    CARTE COUPLEUR ICV150 48 E.ANA. ISOLEES DIFFERENTIELLES
    ICV117/BU    CARTE COUPLEUR /ICV150 16 E. ANA. FILTRE BUTHERWORTH; 32 E/S DIGITALES
    ICV118/HC     M10V/FC=80H CARTE COUPLEUR ICV10x 32 ENTREES ANA. 16 bits ±10 V HAUT MODE COMMUN FC="80Hz" ACQ. 50μs
    ICV118/RTD-CEA     CARTE COUPLEUR ICV10x 16 ENTREES ANA. 16 bits SONDE DE PLATINE
    ICV118/VLL     CARTE COUPLEUR ICV10x 32 ENTREES ANA. 16 bits ±10.24 mVolts
    ICV120/D-12/4/106-I    CARTE COUPLEUR ICV10x 48 E.ANA. ISOLEES 12 bits G1 à 8 100K.ACQ./s ±0.05 % PE
    ICV120/D-12/4/206-I    CARTE COUPLEUR ICV10x 48 E.ANA. ISOLEES 12 bits G1 à 8 50K.ACQ./s ± 0.03 % PE
    ICV120/D-14/4/256-I    CARTE COUPLEUR ICV10x 48 E. ANA.ISOLEES 14 bits G1 à 8 40K.ACQ./s ± 0.016% PE
    ICV120/D-16/4/336-I    CARTE COUPLEUR ICV10x 48 E. ANA.ISOLEES 16bits G1 à 8 30K.ACQ./s ±0.008% PE
    ICV120/       OPTION-BC OPTION BOUCLE DE COURANT POUR ICV120
    ICV122/8/20 C    ARTE COUPLEUR ICV10x 8 E. ANA. S/H ADC EN TETE 12 bits/0,5μs (2MHz)
    ICV126/05      CARTE VME ET COUPLEUR ICV10x 4 E. ANA.ISOLEES 16 bits 500K.éch./s.
    ICV128-E      CARTE VME ET COUPLEUR ICV10x 16 E. ANA. ISOLEES 16 bits G1 à 8 200K.acq. / voie
    ICV132      CARTE VME MAITRE 32 Entrées DIFF. Isochrones 16 bits 200 Kech./s /voie
    ICV138-E/16/BU      CARTE VME ET COUPLEUR ICV10x 8 E. ANA. ISOLEES 16bits G1 à 8 200K.acq./voie +FLT. BUTH.
    ICV140-E/BU      CARTE VME ET COUPLEUR ICV10x 4 E. ANA. ISOLEES 16 bits 200K.acq./voie +FLT. BUTH. SPGA
    ICV148-E/BU      CARTE VME ET COUPLEUR ICV10x 8 E. ANA. ISOLEES 16 bits 200K.acq./voie +FLT. BUTH. SPGA
    ICV150/D-12/4/106-I    CARTE VME 32 E. DIFFERENTIELLES ISO. 12 bits G1 à 8 100K.acq./s ±0.05% PE
    ICV150/D-12/4/206-I     CARTE VME 32 E. DIFFERENTIELLES ISO. 12 bits G1 à 8 50K.acq./s ±0.03% PE
    ICV150/D-14/4/256-I     CARTE VME 32 E.DIFFERENTIELLES ISO 14 bits G1 à 8 40K.acq./s ±0.016% PE
    ICV150/D-16/4/336-I    CARTE VME 32 E. DIFFERENTIELLES ISO. 16 bits G1 à 8 30K.acq./s ±0.008% PE
    ICV178     CARTE VME ET COUPLEUR ICV108 8 E. ANA. ISOLEES 16 bits 1,2MSPS SIGMA DELTA ADCs
    ICV196     CARTE VME ENTREES SORTIES DIGITALES Protégées 70V / 100mA
    ICV248/A     CARTE VME 48 ENTREES ISOLEES VIn 5 VOLTS
    ICV248/B    CARTE VME 48 ENTREES ISOLEES VIn 12 VOLTS
    ICV248/C    CARTE VME 48 ENTREES ISOLEES VIn 24 VOLTS
    ICV264     CARTE VME AVEC SYNCHRO ET FIFOS 64 ENTREES/SORTIES DIGITALES
    ICV296    CARTE VME ET COUPLEUR ICV10x 96 ENTREES/SORTIES DIGITALES
    ICV307      6 ISOLATED, HIGH SPEED 32-BIT COUNTER CHANNELS
    ICV320/RB     CARTE VME 32 SORTIES RELAIS 1RT 125V / 2A
    ICV320/SB      CARTE VME 32 SORTIES RELAIS STATIQUES 1T 60V / 0,5A
    ICV440/A/SB     CARTE VME 24 ENTREES Vin 5 VOLTS 16 SORTIES RELAIS 1T 60V / 0,5A
    ICV440/C/RB     CARTE VME 24 ENTREES Vin 24V 16 SORTIES RELAIS 1RT 125V / 0,5A
    ICV440/C/SB     CARTE VME 24 ENTREES Vin 24 VOLTS 16 SORTIES RELAIS 1T 60V / 0,5A
    ICV440/D/RB     CARTE VME 24 ENTREES Vin 48V 16 SORTIES RELAIS 1RT 125V / 0,5A
    ICV502      CARTE VME BASE DE TEMPS ET SYNCHRONISATION
    ICV701     CARTE VME SORTIE ANA. 1 VOIE ISOLEE 18 bits ± 0,0008% PE ; ±10V;±1V;±100mA
    ICV704/B/1    CARTE VME SORTIE ANA. 4 VOIES ISOLEES BIPOLAIRE 16 BITS FIFOS DE 1K
    ICV706    CARTE VME SORTIE ANA. 4 VOIES ISOLEES BIPOLAIRE 16 BITS RAM DE 512 MOTS PAR VOIES
    ICV714     CARTE VME SORTIE ANA. 16 VOIES ISOLEES 12 BITS 0/5V;0/10V;±5V;±10V
    ICV714/BC    CARTE VME SORTIE ANA. 16 VOIES ISOLEES 12 BITS
    0/5V;0/10V;±5V;±10V;0/20 4/20mA
    ICV716      CARTE VME SORTIE ANA. 8 VOIES 16 BITS 0/10V;±10V
    ICV716/BC     CARTE VME SORTIE ANA. 8 VOIES 16 BITS 0/10V;±10V BOUCLE DE COURANT
    ICV726      CARTE VME SORTIE ANA. 24 VOIES 12 OU 14 BITS ±10V
    ICV914       CARTE VME 4 VOIES DE COMMANDE D'AXES
    PVV900     PASSERELLE VME --> VME COMPOSEE DE 1 EMETTEUR EV900+1 RECEPTEUR RV900
    VP2/10x/02     BUS P2 2 SLOTS POUR CARTE ICV10x
    VP2/10x/03     BUS P2 3 SLOTS POUR CARTE ICV10x
    VP2/10x/04     BUS P2 4 SLOTS POUR CARTE ICV10x
    VP2/10x/05     BUS P2 5 SLOTS POUR CARTE ICV10x
    VP2/10x/06     BUS P2 6 SLOTS POUR CARTE ICV10x
    VP2/10x/07     BUS P2 7 SLOTS POUR CARTE ICV10x
    VP2/10x/08     BUS P2 8 SLOTS POUR CARTE ICV10x
    VP2/10x/09     BUS P2 9 SLOTS POUR CARTE ICV10x
    VP2/150/02     BUS P2 2 SLOTS POUR CARTE ICV150
    VP2/150/03     BUS P2 3 SLOTS POUR CARTE ICV150
    VP2/150/04     BUS P2 4 SLOTS POUR CARTE ICV150
    VP2/150/05     BUS P2 5 SLOTS POUR CARTE ICV150
    CCV04   RACK VME 4 SLOTS 2U 19" p=425mm ALIM 250W +5V/35A;+12V/8A ; -12V/8A
    CCV07   RACKVME 7 SLOTS 4U 19" p=420mm ALIM 300W +5V/25A;+12V/10A ; -12V/1A
    CCV12   RACK VME 12 SLOTS 9U 19" p=480mm ALIM 600W +5V/120A;+/-12V/10A
    CCV16   RACK VME 16 SLOTS 9U 19" p=480mm ALIM 600W +5V/120A;+/-12V/10A
    CCV20   RACK VME 20 SLOTS 9U 19" p=480mm ALIM 600W +5V/120A;+/-12V/10A
    DEFLECTEUR-19" DEFLECTEUR VENTILATION CHASSIS 19" 1U
    INT-1-MEDIA INTEGRATION DANS UN CHASSIS DE 1 MEDIA FOURNI PAR VOS SOINS.
    RCV-20/20   RACK 19" 7U P1=20 SLOTS / P2=20SLOTS ALIM 600W (5V/120A ;
                                                            Produits au standard PCI
    PCI102/05   CARTE PCI GESTION D'ACQUISITION RAPIDE 20 Méga échantillons/s ; 512K. mesures
    PCI102/20   CARTE PCI GESTION D'ACQUISITION RAPIDE 20 Méga échantillons/s 2048K. mesures
    PCI150   CARTE PCI 32 E.DIFF. 64 E. UNI. ISO 12 14 16 bits G1 à 8 100K.acq./s MAX
    PCI160   CARTE PCI 16 E. ANA. 32 E/S TTL 8 S ANA. 16 bits G1 200K.acq. / voie
    PCI220/D   CARTE PCI 32E.DIFF.ISOLEES 12/14/16 bits G1 à 8 100K à 30K.acq./s
    PCI220/S   CARTE PCI 64E.UNI.ISOLEES 12/14/16 bits G1 à 8 100K à 30K.acq./s
    PCI224   CARTE PCI 32 E.DIFF 12 14 16 bits G1 à 8 100K.acq./s MAX
    PCI228   CARTE PCI 16 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie
    PCI238/BE   CARTE PCI 8 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie +FLT.BESSEL
    PCI238/BU   CARTE PCI 8 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie +FLT.BUTH.
    PCI264   CARTE PCI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA μD68 PINS
    PCI307   CARTE PCI 4 VOIES DE COMPTAGE ISOLEES 32 BITS μD68 PINS
    PCI744   CARTE PCI 16 SORTIES ANALOGIQUES ± 10 VOLTS 14 bits μD68 PINS
    PCI786   CARTE PCI 8 SORTIES ANALOGIQUES ISOLEES ± 10 VOLTS 16 bits μD68 PINS
    PCIDX6   CARTE CPU POUR LE TEMPS REEL
    BLA102/02   BUS LOCAL 2 SLOTS POUR PCI102 ET CARTES COUPLEURS
    BLA102/03   BUS LOCAL 3 SLOTS POUR PCI102 ET CARTES COUPLEURS
    BLA102/04   BUS LOCAL 4 SLOTS POUR PCI102 ET CARTES COUPLEURS
    BLA102/05   BUS LOCAL 5 SLOTS POUR PCI102 ET CARTES COUPLEURS
    BLA102/06   BUS LOCAL 6 SLOTS POUR PCI102 ET CARTES COUPLEURS
    BLA102/07   BUS LOCAL 7 SLOTS POUR PCI102 ET CARTES COUPLEURS
    BLA102/09   BUS LOCAL 9 SLOTS POUR PCI102 ET CARTES COUPLEURS
    Produits au standard CPCI – PXI
    CPCI1150   CARTE PXI 32 E. DIFFERENTIELLES ISO. 12 14 16 bits G1 à 8 100K.acq./s MAX
    CPCI1228   CARTE PXI 16 E. ANA. 32 E/S TTL 16 bits G1 200K.acq. / voie
    CPCI1264   CARTE PXI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA AVEC POSITION DE REPLIS
    CPCI1786   CARTE PXI 8 SORTIES ANALOGIQUES ± 10 VOLTS 16 bits
    CPCI228    CARTE CPCI 16 E. ANA. 32 E/S DIGITALES ECHANTILLONNAGE SUMULTANE 250 kHz
    CPCI264   CARTE CPCI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA
    CPCI307   CARTE CPCI 4 VOIES DE COMPTAGE ISOLEES 32 BITS
    CPCI412   CARTE CPCI 3U 4 entrées analogiques 12 bits /22MHz 4Mech/voies
    CPCI744   CARTE CPCI 16 SORTIES ANALOGIQUES ± 10 VOLTS 14 bits
    CPCISYN   CARTE FORMAT CPCI POUR SYNCHRONISATION INTER CHASSIS
                                                 Produits au standard LMC
    LMC-429   MODULE COUPLEUR LIAISONS ARINC 429
    LMC-ADC   MODULE 8D / 16S ENTREES ANALOGIQUES 14 bits ±10.24Volts
    LMC-CAN   MODULE GESTIONNAIRE DE RESEAU CAN
    LMC-DAC   MODULE 8 SORTIES ANALOGIQUES 14 bits ; ± 10V
    LMC-DDS   MODULE 8 SORTIES ANALOGIQUES DDS / SYNTHE
    LMC-DIO   MODULE 16 ENTREES / SORTIES TOR ISOLEES
    LMC-ESCC/16   MODULE INTEL 2 LIAISONS SERIES MULTI- PROTOCOLES GEREES PAR DSP à 16 MHz
    LMC-ESCC/20   MODULE INTEL. 2 LIAISONS SERIES MULTI- PROTOCOLES GEREES PAR DSP à 20MHz
    LMC-SSI   MODULE GESTIONNAIRE DE 4 LIAISONS SYNCHRONES 24 à 32 BITS
    104-LMC CARTE PC104 SUPPORT DE 1 MODULE LMC
    CPCI-LMC   CARTE COMPACT PCI 3U SUPPORT DE 2 MODULES LMCS VIA DMC
    CPCI-LMC-D    CARTE COMPACT PCI 3U SUPPORT DE 2 MODULES LMCS HD44pts
    ICV-LMC    CARTE VME SUPPORT DE 3 MODULES LMCS
    PCI-LMC    CARTE PCI SUPPORT DE 2 MODULES LMCS SUBD HD44PTS
    UCV-DIO    CARTE VME 3U 32 ENTREES / SORTIES DIGITALES ISOLEES + 2 SUPPORTS LMCS
    UCV-LMC    CARTE VME 3U SUPPORT DE 2 MODULES LMCS
    Borniers conditionneurs industriels BCI
    BCI128- BNC   BORNIER 8 PRISES BNC POUR ICV128 / ICV138 / ICV148
    BCI138       BORNIER PASSIF 8 VOIES POUR ICV138 ET MODULE MAL
    BCI140/C     BORNIER 16 ENTREES DIGITALES ISOLEES Vin="24Volts"
    BCI140/D     BORNIER 16 ENTREES DIGITALES ISOLEES Vin="48Volts"
    BCI146      BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 64 PTS
    BCI148      BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 48 PTS
    BCI160/RB    BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A
    BCI160/SB    BORNIER 16 SORTIES RELAIS STATIQUES 1T 60V DC /0.5A
    BCI160/SH    BORNIER 16 SORTIES RELAIS STATIQUES 1T 400V DC/0.1A
    BCI168      BORNIER 8 SORTIES ANALOGIQUES ISOLEES TENSION/COURANT
    BCI184/XX/YY   BORNIER COND. 8 E ANA. HAUT MODE COMMUN VERSION A DEFINIR
    BCI100-PB   PLAQUE DE BOUCHAGE 6U 5TE
    BCI100-RACK-9U   RACK 9U POUR RECEVOIR 16 BCI SERIE 100 ALIM 250W +5V/35A;+12V/8A ; -12V/8A
    BCI300-PRL   CARTE DE PROLONGATION POUR BCI SERIE 300
    BCI300-VISU   BORNIER DE RECOPIE 16 VOIES
    BCI314/ALPF   BORNIER 8 ENTREES ANALOGIQUES CONDITIONNEES POLYVALENT FILTRE PASSE BAS AJUSTABLE
    BCI314/SF    BORNIER 8 ENTREES ANALOGIQUES CONDITIONNEES POLYVALENT SANS FILTRE
    BCI328-5/037/BU    BORNIER 8 ENTREES ANALOGIQUES FILTREES FC A DEFINIR
    BCI328-5/037/BU-TEDS    BORNIER 8 ENTREES ANALOGIQUES FILTREES GESTION DES CAPTEURS TEDS
    BCI360-5/RB/INV    BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A LOGIQUE
    INVERSEE BCI364-5/B72    BORNIER 4 SORTIES ANALOGIQUES ISOLEES Vout = ±72 Volts FAV 5TE
    BCI368-5    BORNIER 8 SORTIES ANALOGIQUES ISOLEES Vout = ±10 Volts FAV 5TE
    BCI382-5/XX    BORNIER COD. 8 E ANALOGIQUES ISOLEES 5 TE (version à préciser)
    BCISIN    BORNIER COND. 4 E ANALOGIQUES ISOLEES DEPHASEUR
    BCI300-PB-5TE    PLAQUE DE BOUCHAGE 6U 5TE
    BCI300-PB-6T   E PLAQUE DE BOUCHAGE 6U 6TE
    BCI300-RACK     RACK 9U POUR RECEVOIR 12 BCI SERIE 300 EQUIPE D'UNE ALIMENTATION 24V/12A
    BCI300-RACK-16    RACK 9U POUR RECEVOIR 16 BCI SERIE 300 5Te EQUIPE D'UNE ALIMENTATION 24V/12A
    Borniers industriels STB
    STB-SSI    BORNIER D'INTERFACE FILAIRE POUR 1 LMC VERS ICVLMC
    STB306   TERMINAL BLOCK FOR INCREMENTAL ENCODERS
    STB306/ISO/A    BORNIER INTERFACE ISOLE POUR CARTES ICV307 PCI307 (Vnom=5V ; I="8mA")
    STB306/ISO/AS   BORNIER INTERFACE ISOLE POUR CARTES ICV307 PCI307 (Vnom=5V ; I="15mA")
    STB306/ISO/B    BORNIER INTERFACE ISOLE POUR CARTES ICV307 PCI307 (Vnom=12V ; I="5mA")
    STB306/ISO/C    BORNIER INTERFACE ISOLE POUR CARTES ICV307 PCI307 (Vnom=24V ; I="5mA")
    STB504    BORNIER CONDITIONNEUR DE NIVEAU 4 VOIES DE COMPTAGE
    STB512    BORNIER INTERFACE PASSAGE DE 1x32 VOIES à 2x16 VOIES
    STB514    BORNIER INTERFACE PASSAGE DE 1x64 VOIES à 4x16 VOIES
    STB516    BORNIER 16 ENTREES SORTIES DIGITALES MODULAIRES
    STB520/8SB/24RB    BORNIER 32 SORTIES RELAIS 0à7-->SB 8à31-->RB
    STB520/RB    BORNIER 32 SORTIES RELAIS 1RT 220V DC/2A
    STB520/SB    BORNIER 32 SORTIES RELAIS STATIQUES 1T 60V DC/0,5A
    STB520/SH    BORNIER 32 SORTIES RELAIS STATIQUES 1T 400V DC/0,5A
    STB524 32    SORTIES POWER SWITCH
    STB525    BORNIER INTERFACE POUR PASSAGE DE 1 MICRO 68 PTS VERS 2 HE501 25 PTS
    STB532/A    BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 5 Volts
    STB532/B    BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 12Volts
    STB532/C    32 ISOLATED DIGITAL INPUTS TERMINAL BLOCK
    STB532/E    BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 115Volts
    STB532/F    BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 220Volts
    STB534    BORNIER INTERFACE PASSAGE DE 2x32 VOIES à 1x64 VOIES
    STB540/C    BORNIER 16 ENTREES DIG. ISO. AC/DC Vin="24Volts"
    STB542    BORNIER INTERFACE CARTE SORTIES ANA. 8 CANAUX
    STB544    BORNIER D'INTERFACE FILAIRE POUR 2 LMCS
    STB546    BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 68 PTS
    STB548/F1    BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX DIFFERENTIELS FILTRES FC =10Hz
    STB550   BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 50 PTS
    STB552   BORNIER INTERFACE ENTREES / SORTIES 32 CANAUX UNIFILAIRES
    STB554    BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX DIFFERENTIELS
    STB554/BC/0250    BORNIER INTERFACE CARTE ENTREES ANA. 16 VOIES BOUCLE DE COURANT R="250Ohms"
    STB556    BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX POUR ENTREES THERMOCOUPLES
    STB560/RB    BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A
    STB560/SB    BORNIER 16 SORTIES RELAIS STATIQUES 1T 60V DC/0,5A
    STB560/SH    BORNIER 16 SORTIES RELAIS STATIQUES 1T 400V DC/0,5A
    STB562    BORNIER 16 SORTIES RELAIS 1RT 380V DC/5A
    ACM/IN/xx/RMS    MODULE D'ENTREE POUR STB658 STB6x2 STB4ACM VERSION RMS
    ACM/INxx    MODULE D'ENTREE POUR STB658 STB6x2 STB4ACM
    RELAIS-EDC1    MODULE D'ENTREE 10 à 32 Vdc
    RELAIS-SDC    1 MODULE DE SORTIE 60 Vdc 3 Amp
    STB/LA55P/XX     MODULE TRANSDUCER 10A
    STB/SHUNT-XX    SHUNT POUR STB R="0".010 OHM ±1%
    STB4ACM     BORNIER D'INTERFACE POUVANT RECEVOIR 4 MODULES ADAS
    STB658     BORNIER D'INTERFACE POUVANT RECEVOIR 16 MODULES ADAS
    STB6x2 ANALOG    CONDITIONING MODULES 8 CHANNELS BACK PANEL
    Produits durcis SACHA, SARI et CAD
    ACCR    COFFRET CONDITIONNEUR CAD
    ACHB    CARTE ACCR HN ET BN
    ACPJ    CARTE ACCR 4 VOIES PONT DE JAUGES
    ACSG    CARTE ACCR 8 VOIES PONT DE JAUGES
    ACTG   CARTE ACCR 16 VOIES TOPS GROS
    ACTP    CARTE ACCR THERMO PT100 ET POT
        Autres produits
    MAL-15D80     MODULE ALIMENTATION ±15VOLTS 80WATTS
    MAL-24S10     MODULE ALIMENTATION 24VOLTS 10WATTS
    MAL-RACK16     RACK POUR MODULE ALIMENTATION 16 SLOTS
    PAM-905     MODULE AMPLIFICATEUR DE PUISSANCE Vout = ±45 Volts 5W FAV 3U 5TE
    PAM-RACK16    RACK POUR 16 MODULES AMPLIFICATEUR DE PUISSANCE
    PUS08A     MODULE DE PRIORITE 8 VOIES ANALOGIQUES (POUR PRODUITS ADAS EXCLUSIVEMENT)
    PUS16D     MODULE DE PRIORITE 16 VOIES DIGITALES (POUR PRODUITS ADAS EXCLUSIVEMENT)
    SVI105 Very high accuracy source 18 bits ± 0,0008% PE ; ±10V;±1V;±100mA
    Cables
    WF245/300     CABLE ROND BLINDE 3 m SUBD-HD 44P VERS SUBD-HD 44S
    WR205/300     NAPPE RONDE BLINDEE 3,00 m SUBD 50P VERS HE10 50S
    WR212/050     NAPPE RONDE BLINDEE 0 m 50 HE10 50S VERS HE10 50S
    WR212/300     NAPPE RONDE BLINDEE 3 m HE10 50S VERS HE10 50S
    WR214/300     NAPPE RONDE BLINDEE 3 m HE10 50S VERS 2 HE10 26S
    WR215/300     NAPPE RONDE BLINDEE 3 m SUBD 50P VERS 2 HE10 26S
    WR228/300     NAPPE RONDE BLINDEE 3m00 SUBD 50P VERS SUBD 50P
    WR233/300     NAPPE RONDE BLINDEE 3 m SUBD 25P VERS SUBD 25P
    WR235/300     NAPPE RONDE BLINDEE 3 m SUBD 25S VERS SUBD 25S
    WR2XX-METRE-SUP.     METRE DE NAPPE SUPPLEMENTAIRE
    WR368/100     MICRO NAPPE BLINDEE 68PTS μSUBD 1m00
    WR368/180     MICRO NAPPE BLINDEE 68PTS μSUBD 1m80
    WR368/300     MICRO NAPPE BLINDEE 68PTS μSUBD 3m00
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • 劉治安 在2025/7/8 16:34:00留言
  • 详细留言:安川HW9171094-A請惠予報價
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
