OVATION DCS系统产品清单
1661D89G01 Power Supply
MMI P/S (old version) w/ AC/DC RT301-2 brick and 3MSC7
7380A31G01 card 115VAC 2
1661D89G02 Power Supply
7380A31G01 card 230VAC 2
1661D89G03 Power Supply
7380A31G01 card 115VAC 7
1661D89G04 Power Supply
1661D89G05 Power Supply
7380A31G01 card 115VAC 13
1661D89G06 Power Supply
7380A31G01 card 230VAC 9
1A51828G12 Cable Q-line card cable (angled plug) 25
1A51829G12 Cable Q-line card cable (angled plug) 15
1A54252G02 MMI OPR MMI KIT 1
1A54289G06 MMI OPR MMI MOD 4A 1
1A57252G02 MMI OPR MMI KIT 1
1A57288G06 MMI ENG MMI M4A 1
1B30023H01 Ovation Module Hart End Line Module 2
1B30023H02 Ovation Module Hart End Line Module 2
1B30035H01 Ovation Module Hart Terminal Module 10
1C31113G01 Ovation Module +/- 20mV Analog Input Electronic Module 0
1C31113G02 Ovation Module +/- 50mV Analog Input Electronic Module 0
1C31113G03 Ovation Module +/- 100mV Analog Input Electronic Module 0
1C31113G04 Ovation Module +/- 1VDC Analog Input Electronic Module 2
1C31113G05 Ovation Module +/- 5VDC/0-20mA Analog Input Electronic Module 0
1C31116G03 Ovation Module 0-20mA Locally Powered Analog Input Personality Module 1
1C31122G01 Ovation Module Digital Output Electronic Module 1
1C31125G01 Ovation Module Digital Output Personality Module 1
1C31125G02 Ovation Module Digital Output Personality Module 1
1C31129G01 Ovation Module 0-5VDC Analog Output Electronic Module 1
1C31129G02 Ovation Module 0-10VDC Analog Output Electronic Module 0
1C31129G03 Ovation Module 0-20mA Analog Output Electronic Module w/ Diagnostics 31
1C31129G04 Ovation Module 0-20mA Analog Output Electronic Module w/o Diagnostics 0
1C31132G01 Ovation Module Analog Outputs Personality Module 38
1C31219G01 Ovation Module Relay Output Logic Module 5
1C31224G01 Ovation Module Analog Input 4-20mA Module (EMOD) 51
1C31224G02 Ovation Module Analog Input 1V Module (EMOD) 0
1C31227G01 Ovation Module Analog Input Personality Module (PMOD) 51
1C31227G02 Ovation Module Analog Input Personality Module (PMOD) 0
1C31232G03 Ovation Differential DI 120VAC/DC Differential E-Mod 1
1C31234G01 Ovation Module DI 48VDC On-Board E-Mod Contact Module 0
1D54416G01-
6 Power Supply Assy DPU P/S (old version) w/ AC/DC brick 0
1D54458G01 Keyboard WDPF Operator Keyboard in Console Fixed cord 115VAC 5
1D54458G02 Keyboard WDPF Operator Keyboard in Console Fixed cord 230VAC 5
1D54471G02 Keyboard WDPF Mylar keyboard top Board (Older Style) 10
1D54471G03 Keyboard WEStation Mylar keyboard top Board (new) 12
1D54540G01 Panel AC Distribution Panel 5
1D54544G01-
8 Chassis WDPF Chassis (9 Slot) 19
1D54557G03 Q Crate Q Line card cage w/ 2840A38G01 backplane 1
1D54557G07 Q Crate Q Line card cage w/ 4256A99G02 backplane 3
1D54557G10 Q Crate Q Line card cage w/ 4256A99G02 backplane 8
1D54557G10 Q Crate
Q Line card cage w/ 4256A99G02 backplane & 3A59347G01 on
front edge 1
1D54561G01 LIM Module LIM Assy w/ 7381A27G01 3LIM4 Dual Loop 10
1D54561G02 LIM Module LIM Assy w/ 7381A27G01 3LIM4 Single Loop 10
1D54574G01 Keypad LIM Assy keypad 10
1D54579G01 Panel Distribution Interface Assy 2
1D54580G02 Chassis MultiBus Chassis 12
1D54581G04 Rack Tray Dual Rack tray w/ 2ea 1D54582G05 DPU P/Ss 5
1D54582G01 Power Supply Assy DPU Power Supply Assy w/ AC SW w/ Wier brick 115VAC 2
1D54582G02 Power Supply Assy DPU Power Supply Assy w/ AC SW w/ Wier brick 230VAC 2
1D54582G03 Power Supply Assy
DPU Power Supply Assy w/o AC SW & DSC G03 Ctrlr card
115VAC/230VAC 1
1D54582G05 Power Supply Assy DPU Power Supply Assy w/ AC SW w/ Deltron brick 115VAC 32
DPU Power Supply Assy w/ Deltron brick & plug-in cables
115VAC 7
1D54582G06 Power Supply Assy DPU Power Supply Assy w/ AC SW w/ Deltron brick 230VAC 22
1X00024H01 Power Supply MagneTek model WH1-2FF 24V Power Supply + 24V Aux, AC 0
1X00024H03 Power Supply MagneTek model Power Supply 48V Aux, AC 0
1X00024H04 Power Supply MagneTek model Power Supply + 24V Aux, DC 0
1X00024H06 Power Supply MagneTek model Power Supply 48V Aux, DC 0
1X00093H04 Switch Ethernet Switch (24 Ports) - Primary Fanout 0
1X00093H05 Switch Ethernet Switch (24 Ports) - Partner Fanout 0
1X00093H08 Switch Ethernet Switch (24 Ports) - Root 0
1X00093H09 Switch Ethernet Switch (24 Ports) - Backup 0
1X00102H01 Ovation Dist Bd Power Distribution Board MagneTek WH1-PDM 1
1X00133H01 NIC PCI Fast Ethernet DAS NIC, W2K, XP 0
1X00161H01 NIC Fast Ethernet NIC - Dual Port for Controller ZYNX 0
1X00163H01 Power Supply
Magnetek WH3A-2DF plug-in style I/O Power Supply 13/24VDC
w/ AC input 1
1X00163H02 Power Supply
Magnetek WH3A-2DJ plug-in style I/O Power Supply 13/48VDC
w/ AC input 0
1X00163H03 Power Supply
w/ DC input 2
1X00163H04 Power Supply
w/ DC input 0
1X00185H01 Graphics SUN XVR-100 GRAPHICS card 2
1X00377H01 Cable Mgt Bar Cable Management Bar 1
1X00417H01 Power Supply
PowerOne WH7A-2DF plug-in style I/O Power Supply
13/24VDC w/ AC input 0
1X00417H02 Power Supply
PowerOne WH7A-2DJ plug-in style I/O Power Supply
13/48VDC w/ AC input 0
1X00417H03 Power Supply
13/24VDC w/ DC input 1
1X00417H04 Power Supply
13/48VDC w/ DC input 0
2000A04G01 4QTR1 QTR G01 card 1
2380C91G03 Temp Sensor Temp Sensor 4
2623D37G01 Module NL-1075B Comm Adapter 1
2837A11G01 4NCH5 NCH G01 card 3
2837A11G01 4NCH7 NCH G01 card 1
2837A86G01 2NCI2 NCI G01 card 3
2837A87G04 8NRC1 NRC G04 card 3
2838A30G12 7NCB2 NCB G12 card 6
2838A32G01 5NAC3 NAC G01 card 1
2838A32G01 5NAC5 NAC G01 card 1
2838A32G01 5NAC6 NAC G01 card 2
2838A33G01 4NPL7 NPL G01 card 3
2838A34G01 7NMA2 NMA G01 card 12
2838A45G01 3NTD4 NTD G01 card 1
2839A38G01 2NPD7 NPD G01 card 5
2840A10G03 QMC QMC G03 card 0
2840A13G01
- G16 QDI QDI G01 - G16 (Replaced by QID G01 - G16) 0
2840A15G01 QME QME G01 card 0
2840A17G01 5QTO3 QTO TRIAC Output card - 115VAC 38
2840A17G06 3QDI39 QDI G06 card (replaced by QID G06) Sub 1 1
2840A17G06 4QDI6 QDI G06 card (replaced by QID G06) Sub 4 5
2840A18G01 6QRO5 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 2 1
2840A18G01 6QRO9 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 3 11
2840A18G01 6QRO13 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 5 14
2840A18G01 6QRO17 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 5 2
2840A18G01 6QRO23 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 5 1
2840A18G01 7QRO1 QRO G01 Relay Output card - 330VDC/250VAC Form A Sub 5 1
2840A18G01
3A99168G01 8QRO1 QRO G01 Relay Output card - 330VDC/250VAC Form A 22
2840A18G01
3A99168G01 8QRO7 QRO G01 Relay Output card - 330VDC/250VAC Form A 5
2840A18G02 6QRO13 QRO G02 Relay Output card - 330VDC/250VAC Form B Sub 5 5
2840A18G02 8QRO1 QRO G02 Relay Output card - 330VDC/250VAC Form B 5
2840A18G03 6QRO11
QRO G03 Relay Output card - Form A non-inductive loads Sub
5 0
2840A18G04 6QRO13 QRO G04 Relay Output card - Form B non-inductive loads 5
2840A19G07 4QAI17 QAI G07 Analog Input card - 0 to +20mA 1
2840A20G01 3QTB17 QTB G01 Time Base card - 60 Hz (+/-2 Hz input) 2
2840A20G01 3QTB21 QTB G01 Time Base card - 60 Hz (+/-2 Hz input) 40
2840A20G02 3QTB26 QTB G02 Time Base card - 50 Hz (+/-2 Hz input) 1
2840A20G03 3QTB27 QTB G01 Time Base card - 60 Hz (+/-2 Hz input) 1
2840A21G01 7QAO20 QAO G01 Analog Output card - 20mA Sub 17 6
2840A21G01 7QAO20 QAO G01 Analog Output card - 20mA Sub 19 11
2840A21G01 8QAO1 QAO G01 Analog Output card - 20mA Sub 20 8
2840A21G01 8QAO20 QAO G01 Analog Output card - 20mA 30
2840A21G01
3A99161G01 10QAO17 QAO G01 Analog Output card - 20mA Sub 27 & 28 16
2840A21G01
3A99161G01 11QAO1 QAO G01 Analog Output card - 20mA Sub 29 & 30 7
2840A21G01
3A99161G01 11QAO9 QAO G01 Analog Output card - 20mA Sub 31 4
2840A21G01
1P00000G01 13QAO1 QAO G01 Analog Output card - 20mA Sub 33 1
2840A21G01
1P00000G01 13QAO9 QAO G01 Analog Output card - 20mA Sub 35 1
2840A21G02 5QAO42 QAO G02 Analog Output card - 10VDC Sub 9 1
2840A21G02 7QAO21 QAO G02 Analog Output card - 10VDC 1
2840A21G04 4QAO38 QAO G04 Analog Output card - 5VDC 2
2840A21G04 8QAO4 QAO G04 Analog Output card - 5VDC 1
2840A21G05 5QAO61 QAO G05 Analog Output card - (+/-)5VDC 2
2840A21G05 7QAO24 QAO G05 Analog Output card - (+/-)5VDC 6
2840A21G05 7QAO32 QAO G05 Analog Output card - (+/-)5VDC 2
2840A21G05 8QAO5 QAO G05 Analog Output card - (+/-)5VDC 1
2840A21G05 13QAO13 QAO G05 Analog Output card - (+/-)5VDC 1
2840A21G06 8QAO22 QAO G06 Analog Output card - (+/-)10VDC 2
2840A21G07 5QAO37 QAO G07 Analog Output card - 20mA 1
2840A21G08 QAO QAO G06 Analog Output card - (+/-)10VDC 0
2840A38G01 Backplane Q-Crate Backplane 42
2840A49G01
404A724G01 1QEX6 QEX Q-Line Extender 1
2840A75G01 3QSC7 QSC G01 Speed Channel card 4
2840A75G02 3QSC8 QSC G02 Speed Channel card 10
2840A77G02 QPP QPP G02 card 0
2840A78G01 4QSD14 QSD Servo Driver card - (+/-)24mA output 1
2840A79G01 3QBO21 QBO G01 Digital Output card - 60VDC @ 300mA (max) Sub 2 3
2840A79G01 3QBO27 QBO G01 Digital Output card - 60VDC @ 300mA (max) Sub 5 18
2840A79G01
2840A79G81 3QBO21 QBO G01 Digital Output card - 60VDC @ 300mA (max) Sub 5 1
2840A79G01
3A99162G01 4QBO16 QBO G01 Digital Output card - 60VDC @ 300mA (max) 27
2840A79G02 3QBO28
QBO G02 Digital Output card - 60VDC @ 300mA (max) w/
filters Sub 5 1
2840A79G03 QBO
QBO G03 Logic Output card - 20VDC @ 16mA (max) w/
flashing 0
2840A79G04 3QBO19 QBO G04 Logic Output card - 20VDC @ 16mA (max) 2
2840A79G04 3QBO24 QBO G04 Logic Output card - 20VDC @ 16mA (max) 1
2840A79G05 QBO
QBO G05 Logic Output card - 20VDC @ 16mA (max) w/
flashing, pull-up 0
2840A80G04 6QBI4 QBI G04 Digital Input card - +24 (20 to 30)VDC 13
2840A80G04 6QBI14 QBI G04 Digital Input card - +24 (20 to 30)VDC 4
2840A80G06 5QBI17 QBI G06 Digital Input card - +48 (40 to 60)VDC 2
2840A80G08 6QBI8 QBI G08 Digital Input card - +120 (100 to 150)VAC 4
2840A80G11 6QBI11
QBI G11 Digital Input card - +120 (100 to 150)VAC (High
Threshold) 0
2840A85G01 QMS QMS G01 card 0
2840A86G05 2QAC11 QAC G05 Analog Cond. card - +120mA at +48VDC 5
2D34347G05 Power Supply Assy
Dual 24VDC Power Supply Assy w/2ea Advance MG24-10C
115VAC 14
2D34347G06 Power Supply Assy
230VAC 14
2D34347G07 Power Supply Assy
Dual 48VDC Power Supply Assy w/2ea Advance MG48-5C
115VAC 14
2D34347G08 Power Supply Assy
230VAC 14
320117-05A Card Kalex SC401141-45 1
399D915G05 Gnd Det Pnl gray rack panel 1
3A42902H01 Printer Genicom 3410XCQ Color Printer 1
3A43019G02 Panel 13VDC Power Supply Monitoring Panel w/ Cable 1
3A43084G01 SBUS SBUS/MultiBUS 0
3A56324G11 Chassis OPR MMI 1
3A58354G02 TFR Assy
TFR Modification Assy (same as TFR Assy 4D33764G01 but w/
sticker on front) 1
3A58919G12 Cable Orange Cable Assy RTD - N 12
3A58939G15 Keyboard SUN Type 6 Keyboard and Mouse 5
3A58945H01 Monitor 20/19" SUN CRT (19.1" LCD replacement solution) 5
3A58992H04 Cable 3BNC RGB Video Cable for SUN Sparc5 10
3A59104G01 VXI Kit VXI Kit 1
3A59104G02 Card Cage
486 WEStation Q-line Remote I/O (on front of cage w/ MRC,
MHC, MDX cards) 11
3A59104G04 Card Cage
MHC, MDX cards) 6
3A59323G01 Chassis ENGR MMI Chassis 5
3A59323G02 Chassis ENG MMI Chassis 1
3A59324G01 Chassis OPR MMI Chassis 4
3A59324G02 Chassis OPR MMI Chassis 4
3A59347G01 Q Crate
Q-Line Remote I/O card cage w/ 4256A99G02 BP &
1D54557G10 on cage side 1
3A59324G11 Chassis OPR MMI Chassis 1
3A59341G03 Interface Strip WDPF IIU Kit (Interface Strip in VME chassis) 3
3A59351G11 Chassis OPR MMI Chassis 1
3A59526G12 Cable Green cable out CH0 on front of VME SHC card 4
3A59527G12 Cable Yellow cable out CH1 on front of VME SHC card 4
3A98608G03 Port VME SCSI Serial Port Device 3
3A98641H02 Adapter 25pin serial female to 9pin male adapter 2
3A98643G03 Cable Ribon Cable to MRC card 5
3A98648G32 TAP Panel
Cluster TAP Panel w/ 2ea 5D32025G04 Ethernet TAP & 4ea
5D32024G01 RTP 3
3A98688G02 SCSI Cable SCSI Cable on front of VME chassis 5
3A98688G03 SCSI Cable SCSI Cable on front of VME chassis 2
3A98688G04 SCSI Cable SCSI Cable on front of VME chassis 1
3A98720G18 Cable Green Cable out the front of VME Sparc 6
3A98726G06 Cable Trackball Cable 2
3A98768G01 Switch Switch 22
3A98807G05 Cable Serial Model 25 pin Male 3
3A98826H06 Trackball SUN Trackball 3
3A98833H01 Cable SUN SCCI CABLE 2
3A98833H03 Cable SUN SCSI CABLE 2
3A98833H12 Cable SUN SCSI CABLE 2
3A98833H23 Cable SUN SCSI CABLE 2
3A98865G01 Cable Green Cable to TAP Panel Assy 6
3A98871H01 Keyboard Engineering 101 Key Keyboard NMB RT101 116305-002 3
3A98963G05 Keyboard WEStation Operator Membrane Keyboard 0
3A99101G01 2QSR35 QSR G01 Servo Driver w/ Position Readback card 4DC LVDTs 3
3A99101G02 QSR QSR G02 Servo Driver w/ Position Readback card 2AC LVDTs 0
3A99108G01 QRS QRS G01 0
3A99109G01 QRF QFR - 4 wire RTD Input Amplifier 0
3A99114G03 QRD QRD G03 Module - 200 Ohm Platinum RTD 0
3A99114G04 QRD QRD G04 Module - 200 Ohm Platinum RTD 0
3A99116G01 4MDPS3 MDPS Board (inside 5D32191G01 MPS512-PFC power supply) 12
3A99116G01 4MDPS9 MDPS Board 10
3A99118G01 QCA QCA G01 card 0
3A99118G02 QCA QCA G02 card 0
3A99125G02 COT Board COT Fiber Optic Transmitter / Receiver card 0
3A99125G03 COT Board COT Fiber Optic Transmitter / Receiver card 0
3A99132G01 3PCPS04 Ovation Power Supply card 1
3A99132G02 3PCPS05 Ovaton Power Supply card 2
3A99141G01 Board Q-Line Interface 0
3A99158G01 4PCRL1 Ovation Local I/O Interface 5
3A99199G01 2ROP3 Ovation Power Supply backplane 1
3A99200G01 5CBO5 Ovation PCI Backplane 2
3A99211G01 1DAPS4 1DAPS4 G01 card inside 4D33913G01 and G04 power supply 10
3A99211G02 1DAPS5 1DAPS5 G01 card inside 4D33913G02 and G05 power supply 2
3A99220G01 2MEPS3 2MEPS3 card in 4D33916G01 Power Supply 8
3A99229G01 3PGI1 PGI Data Highway card (for Ultras and Blades) 8
3A99254G01 2IOPS16 IOPS Power Supply board inside 4D33865G01 P/S 4
3A99254G03 4IOPS3 IOPS Power Supply board inside 4D33865G03 P/S 4
3A99257G01 QOR QOR G01 Remote I/O card 0
3A99401H01 Fan Assy Fan Assy in 486 WEStation DPU 46
3A99403H01 Transformer AC/DC Transformer 4
3A99410G02 Cable DIOB Ribbon Cable 10
3A99410G06 Cable DIOB Ribbon Cable 10
3A99419G03 Cable Ovation Cabinet Ground Cable 1
3A99419G06 Cable Ovation Cabinet Ground Cable 1
3A99419G12 Cable Ground Cable 10
3A99419G19 Cable Ground Cable 10
3A99420G19 Cable Ground Cable 10
3A99528G23 Cable Cable w/ 406A095H03 adapter plug 1
3A99537G01 Cable Cable Assy -GBUS 1.5 FT - GHC Enclosure to Sparc5 or Ultra5 3
3A99537G02 Cable Cable Assy -GBUS 10 FT - GHC Enclosure to Sparc5 or Ultra5 8
3A99544G01 Cable Cable 1
3A99546G01 Cable DPX to DPX back plane ribbon 22
3A99592H01 Cable Cable to Ethernet Tap Assy 5
3A99596G01 Cable Cable from the front of the TFR to it's own back plane 22
3A99598G02 Cable Cable from the MRC to TFR Panel (two into one) 6
3A99598G03 Cable Cable from the MRC to TFR Panel (two into one) 6
3A99670G01 Intel Card
PBA510105-006 PSBC272 daugter card on Intel 4256A41G02
board 5
3A99678G21 Chassis WEStation MMI Kit (sticker on front edge of VME chassis) 3
3A99688H01 Power Supply
Deltron 11564XA-01 Power Supply brick for DPU Module
115VAC 10
3A99688H02 Power Supply
Deltron 11564XA-02 Power Supply brick for DPU Module
230VAC 5
3A99695H01 Battery Lithium Battery for MDX card 30
3A99719G01 Kit Weir to Deltron brick DPU Power Supply upgrade kit 12
3A99723G01 Cable DPU Power Supply harness 6
3A99732H03 VME Board
Sun Sparc2 VME Board (Motherboard - becomes 4D33816G01,
G03, G04, etc) 11
3A99734H01 Power Supply
PowerOne NRG4A70B4B4K0RZ108 for MMI P/S Module
4D33613G01 10
3A99746G01 Kit
TODD to PowerOne NRG4A70B4B4K0RZ108 brick MMI Power
Supply upgrade Kit 20
3A99778G02 Monitor 20/19" Sony CRT (19.1" LCD replacement solution) 5
3A99782H01 Graphics card TGX Graphics Card 8
3A99795G02 Drive HP C2550T SureStore 1300t 1.3GB External Optical Disk Drive 2
3A99795G07 Drive
HP C1114J SureStore 5200ex 5.2GB External Optical Disk
Drive 4
3A99795G09 Drive KIT, OPTICAL DISK DRIVE 4
3A99795G10 Drive HP 9100MX Optical Drive with 3ft DB50M Cable 1
3A99795G11 Drive HP 9100MX Optical Drive with 31in MiniD50M Cable 1
3A99795G12 Drive HP 9100MX Optical Drive with 3ft MiniD68M Cable 1
3A99795H03 Media HP Optical Disk - Rewritable 5
3A99795H04 Media HP Optical Disk - Write Once 5
3A99795H10 Drive HP C1114F SureStore 2600fx 2.6GB External Optical drive 3
3A99795H18 Media HP 5200ex Optical Disk Media 15
3A99795H24 Drive HP 9100MX Optical Disk Drive 5
3A99795H25 Media Optical Disk Media 5
3A99857G04 Cable QHS-L 486 Analog - 56ACE (Q-line I/O cable) 8
3A99859G03 Cable QHS-R 486 Digital - 56 ACE (Q-line I/O cable) 8
3A99859G04 Cable QHS-L 486 Digital - 56ACE (Q-line I/O cable) 8
3A99860G04 Cable Halfshell Termination Assembly/Cable 2
3A99977G01 Cable DIOB to MDX Cable 5
3A99989H13 Printer Genicom 3850 Color Printer 3
3A99990H02 Memory Memory 32mb 501-2471 for SUN Sparc5 5
3A99992H02 Sun Workstation
Sparc20 built to your spec - all processors/options avail - w/
SGI 6
3D04057G01 Switch
WDPF Engineering Console Control Stn w/ 2FILM2
7381A59G01 card 3
3D04058H01 Keyboard 84 key Par. Int. (Amkey 106-0004) 2
3D04061G01 Keyboard WDPF Operator Mylar Keyboard Desk Top, Fixed cord 115VAC 12
3D04061G02 Keyboard WDPF Operator Mylar Keyboard Desk Top, Fixed cord 230VAC 8
3D04101G01 Panel Alarm Panel 2
3D04101G04 Panel Alarm Panel 2
3D04106G01 FOR Fiber Optic Repeater w/ 5FTC5 G01 115VAC 5
3D04106G02 FOR Fiber Optic Repeater w/ 5FTC5 G01 230VAC 5
3D04106G04 FOR Fiber Optic Repeater w/ 5FTC5 G03 115VAC 10
3D04106G05 FOR Fiber Optic Repeater w/ 5FTC5 G03 230VAC 10
3D04106G06 FOR Fiber Optic Repeater 115VAC 10
3D04106G07 FOR Fiber Optic Repeater 230VAC 10
3D04109G01 Module WDPF SBX 51 I/O Module 0
3D04115G04-
16 Module PC1200-1043 Module (blue plastic) 1
3D04128G01 Line Filter Line Filter Sub 2 1
3D04141G01 Power Supply
Dual Power Supply Assy rack tray w/ 2ea PM2722A-1 Power
Suplies 7
3D04141G02 Power Supply
Dual Power Supply Assy rack tray w/ 2ea PM2775-1-3 Power
Suplies 3
3D04142G02 Panel DC Pwr Distribution Panel 5
3D04146G01 Rack Tray Dual I/O Power Supply Rack Tray w/ 2ea 405A662G01 Deltrons 10
3D04153G01 Drive Assy w/ Seagate ST225 HD & Panasonic JU-475-5 Floppy, 115VAC 2
3D04153G02 Drive Assy w/ Seagate ST225 HD & Floppy, 230VAC 1
3D04153G03 Drive Assy w/ Seagate ST225 HD, 115VAC 1
3D04153G04 Drive Assy w/ Seagate ST225 HD, 230VAC 0
3D04153G05 Drive Assy w/ Micropolis 1325 (or Maxtor XT1085) HD, 115VAC 1
3D04153G06 Drive Assy w/ Micropolis 1325 (or Maxtor XT1085) HD, 230VAC 0
3D04153G07 Drive Assy w/ Micropolis 1325 (or Maxtor XT1085) HD & Floppy, 115VAC 4
3D04153G08 Drive Assy w/ Micropolis 1325 (or Maxtor XT1085) HD & Floppy, 230VAC 2
3D52389G02 XMC XMC Synchronizer 4
403A986G01 Cable Ribon Cable QAA to DBK 13
404A747G02 Switch Operator Keyboard Top Board key lock/switch 5
404A749G03 Keyboard WDPF Operator Mylar Top Board (new) 25
404A790H01 Floppy Drive Winchester Floppy Disk Drive 0
404A790H27 Hard Drive Seagate ST-225 20/25MB HD 2
404A822H03 Power Supply Pioneer Magnetics PM2924A-3 0
404A965H01 BNC T BNC T connector 5
405A318G01 Printer Genicom 3404C Color Printer 0
405A357H11 Power Supply
24V-10A Power Supply (Acme 2FA1900002A for 4D33711G01
RIO P/S Assy) 5
405A401G01 Cable MSE cables 15
405A431G01 Power Supply
Weir SMM 200 Power Supply Brick for DPU P/S Module
115VAC 5
405A431G02 Power Supply
230VAC 5
405A497H01 Graphics Generator Summa Graphics MM1103 1
405A528G01 Chassis 12 Slot MultiBus Chassis 115VAC 1
405A528G02 Chassis 12 Slot MultiBus Chassis 230VAC 1
405A528G21 Chassis MOD 1
405A528G33 Chassis MOD 1
405A528G61 Chassis 12 Slot MultiBus Chassis 115VAC 3
405A528G62 Chassis 12 Slot MultiBus Chassis 230VAC 3
405A528G63 Chassis 12 Slot MultiBus Chassis 115VAC 3
405A528G64 Chassis 12 Slot MultiBus Chassis 230VAC 3
405A616H01 Cable WDPF Classic 3BNC RGB Coax Video Cable Assembly - 10ft 12
405A616H02 Cable WDPF Classic 3BNC RGB Coax Video Cable Assembly - 25ft 2
405A662G01 Power Supply
13V I/O Power Supply Deltron 11088XA (1996 models or
newer) 115VAC 58
405A662G02 Power Supply
newer) 230VAC 58
405A672H01 Graphics card Matrox SBX-900 Graphics card 249-06-01 2
405A672H01 Graphics card Matrox SBX-900 Graphics card 249-06-02 3
405A672H01 Graphics card Matrox SBX-900 Graphics card 249-06-04 12
405A675G61 Chassis 12 Slot MultiBus Chassis 115VAC 14
405A675G62 Chassis 12 Slot MultiBus Chassis 230VAC 1
405A675G63 Chassis 12 Slot MultiBus Chassis 115VAC 17
405A675G64 Chassis 12 Slot MultiBus Chassis 230VAC 3
405A685G61 Chassis 12 Slot Chassis 1
405A689G01 SMS SMS 8007 Board 2
405A689G03 SMS SMS 8007 Board 13
405A689G04 SMS SMS 8007 Board 1
405A742G01 Power Supply Power Supply for Firber Optic Repeater 115VAC 10
405A742G02 Power Supply Power Supply for Fiber Optic Repeater 230VAC 10
405A743H01 Tape Drive Kenedy 9600, 3200 BPI Mag Tape - Rack Mount 1
405A824G01 Cable Cables MMI 10
405A832H01 Track Ball CTI Model T1013K-D25F073S Desk Top model 1
405A832H02 Track Ball CTI Model T1013K-D25F073S Console model 1
405A856H01 Power Supply PM2722A-1 Pioneer Magnetics + 12V @ 125VDC 15
405A857H01 Power Supply PM2775A-1-3 Pioneer Magnetics 12/12/5V @ 125VAC 10
405A891G01 Power Supply Power Supply Card inside WDPF Drive Assy 115VAC 8
405A891G02 Power Supply Power Supply Card inside WDPF Drive Assy 230VAC 5
405A892H01 Hard Drive Mnemonic 85MB Hard Drive 0
405A893G01 Floppy Drive TEAC FD55GFR 5?” floppy drive 3
405A893H01 Floppy Drive Panasonic JU-475-5AEG 5 5?” floppy drive 3
405A924G03 Cable Cables MMI 16
405A924G04 Cable Cables MMI 15
405A924G05 Cable Cables MMI 1
405A924G06 Cable Cables MMI 1
405A973H01 Label Label sticker for Logitech M-CU15-9F three button mouse 5
405A975G01 Power Supply TODD MTX-403-10384 power supply brick 115VAC 1
405A975G02 Power Supply TODD MTX-403-10384 power supply brick 230VAC 1
406A036H01 DRE 120 OHM Nickle RTD DRE Daughter card on QRT 0
406A054H01 Power Supply Pioneer Magnetics PM2722-1 Type 24F33-0-4-RS 0
406A095H03 Adapter Adapter plug w/ 3A99528G23 cable 10
406A112G16 Cable WDPF Kybd Cble / 25 pin adapter 2
406A124G01 Monitor 20/19" CRT (DS191D 19.1" LCD replacement solution) 5
406A124H01 Intecolor CRT Monitor Non-Touch Desktop E02038-20E 0
406A124H15 Intecolor CRT Monitor InfraRed Touch Desktop E20FEC-WE1 1
406A124H17 Intecolor CRT Monitor InfraRed Touch Console E20FEC-WE3 1
406A154H01 Power Supply
PowerOne SPL50-3200 card inside WDPF Classic DT box
(MHC Enclosure) 8
406A157G01 Ribbon Cable 3M FlexCat inside WDPF Classic DT box (MHC Enclosure) 10
4625B61G01 Conduit Box Conduit box (4ea receptical box) 2
4256A01G01 6QLC5 QLC card w/ daughter card removed 1
4256A01G01
772B450G01 6QLC5 QLC card w/ 1SCOM2 4256A06G01 RS232 daughter card 1
4256A01G01
772B450G02 6QLC5 QLC card w/ 1SCOM2 4256A06G02 RS422 daughter card 1
4256A01G01
772B450G01 6QLC7 QLC card w/ 1SCOM1 4256A06G01 RS232 daughter card 2
4256A01G01
772B450G01 6QLC9 QLC card w/ 1SCOM1 4256A06G01 RS232 daughter card 0
4256A03G01 4KBI9 Board inside WDPF detachable cord optr keybds 115VAC 6
4256A03G02 4KBI9 Board inside WDPF detachable cord optr keybds 230VAC 6
4256A03G03 4KBI9 Board inside WEStation detachable cord optr keybds 115VAC 6
4256A03G04 4KBI9 Board inside WEStation detachable cord optr keybds 230VAC 6
4256A04G01 MCSM MCSM G01 Board (inside IBM PC) 0
4256A04G02 2MCSM7 MCSM G02 Board (inside IBM PC) 5
4256A05G01 2MHB1 Backplane inside MHC DT Box 8
4256A06G01 SCOM SCOM Daughter Card on QLC RS232 1
4256A06G02 SCOM SCOM Daughter Card on QLC RS422 1
4256A07G01 MHR MHR Highway Controller 0
4256A08G02 3RTP6 Remote Tap Interface cards in 5D32035G02 Cluster Tap Panel 1
4256A08G02 3RTP6 Remote Tap Interface cards in 5D32024G01 Cluster Tap Panel 8
4256A10G01 3MSX7 MSX 386 Processor Board 14
4256A10G01 3MSX9 MSX 386 Processor Board 9
4256A10G01 3MSX10 MSX 386 Processor Board 52
4256A10G01 3MSX12 MSX 386 Processor Board 15
4256A10G01 3MSX13 MSX 386 Processor Board 14
4256A11G01 3SHC9 SUN Hwy Interface Board 5
4256A11G01 3SHC10 SUN Hwy Interface Board 8
4256A11G01 3SHC11 SUN Hwy Interface Board 1
4256A11G01 3SHC12 SUN Hwy Interface Board 2
4256A12G01 EHS EHS Ethernet Highway Switch 0
4256A15G01 QDC QDC G01 - 24 VDC/AC 0
4256A15G02 QDC QDC G02 - 48 VDC/AC 0
4256A15G03 QDC QDC G03 - 120 VDC/AC 0
4256A25G01
1C31025G03 5MRC4 MRC Board for 386 processor WEStation 13
4256A25G01
1C31025G03 5MRC5 MRC Board for 386 processor WEStation 1
4256A25G01
1C31025G03 5MRC6 MRC Board for 386 processor WEStation 1
4256A25G01
1C31025G03 5MRC9 MRC Board for 386 processor WEStation 2
4256A25G01
1C31025G03 5MRC11 MRC Board for 386 processor WEStation 1
4256A25G01
1C31025G03 5MRC17 MRC Board for 386 processor WEStation 1
4256A25G02
1C31025G05 5MRC12 MRC Board for 486 processor WEStation 4
4256A25G02
1C31025G05 5MRC18 MRC Board for 486 processor WEStation 26
4256A25G02
1C31025G06 5MRC18 MRC Board for 486 processor WEStation 3
4256A26G01 4QRC1 QRC card 3
4256A26G01 4QRC3 QRC card 6
4256A26G01 4QRC4 QRC card 2
4256A26G01 4QRC5 QRC card 1
4256A26G01
1C31183G01 4QRC6 QRC card 23
4256A27G01 2PQD2 DPU Power Supply plug Adapter card (quick connect) 10
4256A41G01 Intel Processor card
PBA511832-005 PSBC386SX02 AA510104-006 w/ Intel
Daughter PBA100367-03 3A58926G03 prom 1
PBA511832-006 PSBC386SX02 AA510104-007 w/ Intel
4256A41G02 Intel Processor card
PBA511832-007 PSBC386SX02 w/ Intel Daughters
3A99670G01 PBA510105-006 PSBC272 & PBA115417-006
SBX586 10
4256A51G01 3QFR2 Cards inside TFR Panel Assy 26
4256A51G01
772B480G01 3QFR3 Cards inside TFR Panel Assy 38
4256A51G01 4QFR2 Cards inside TFR Panel Assy 18
4256A56G01 2TRC2 Channel Input card in TFR Assy 7
4256A57G01 3WPM2 WPM card inside 4D33810G01 P/S Assy 2
4256A58G01 2TFR1 TFR Assy back plane 39
4256A62G01 PIC PIC Peripheral Interface card 0
4256A64G01
3A99163G01
/ G50 6QAX1 / 7 QAX G01 12 point AI card - 20mV w/ 12ea 4QAXD1 G01s 8
4256A64G01
3A99163G01
/ G50 7QAX1 / 7 QAX G01 12 point AI card - 20mV w/ 12ea 4QAXD1 G01s 1
4256A64G02
3A99163G50 3QAX16 / 21 QAX G02 12 point AI card - 50mV w/ 12ea 4QAXD2 G02s 14
4256A64G02
3A99163G02
/ G50 6QAX2 / 7 QAX G02 12 point AI card - 50mV w/ 12ea QAXD G02s 3
4256A64G02
3A99163G02
/ G50 6QAX2 / 7QAX7 QAX G02 12 point AI card - 50mV w/ 12ea QAXD G02s 2
4256A64G02
3A99163G02
/ G50 7QAX2 QAX G02 12 point AI card - 50mV w/ 12ea QAXD G02s 2
4256A64G03 QAX QAX G03 12 point AI card - 100mV 0
4256A64G04 QAX QAX G04 12 point AI card - 0 to 1V 0
4256A64G05 3QAX12 QAX G05 12 point AI card - 0 to 5V 18
4256A64G05 3QAX19
QAX G05 12 point AI card - 0 to 5V w/ 12ea 4QAXD5
4256A65G05s 7
4256A64G05
3A99163G05 6QAX5 / 7
4256A65G05s 3
4256A64G05
3A99163G05
/ G50 6QAX5 / 7
4256A65G05s 2
4256A64G05
3A99163G05 7QAX5 / 7
QAX G05 12 point AI card - 0 to 5V w/ 12ea QAXD G05s
(3A99163G50) 3
4256A64G05
3A99163G05
/ G50 7QAX5 / 7 QAX G05 12 point AI card - 0 to 5V w/ 12ea 6QAXD5 G05s 4
4256A64G06 QAX QAX G06 12 point AI card - 0 to 10V 0
4256A65G02 4QAXD2 QAXD G02 QAX Digital daughter card 0
4256A65G03 4QAXD3 QAXD G03 QAX Digital daughter card 0
4256A65G05 4QAXD5 QAXD G05 QAX Digital daughter card 24
4256A65G06 4QAXD6 QAXD G06 QAX Digital daughter card 0
4256A66G01 2DPU1 386 WS DPU Backplane 11
4256A66G01 3DPU1 386 WS DPU Backplane 8
4256A67G01 3MBPS13 MBPS Board inside 4D33755G01 Power Supply Assy 18
4256A76G02 QST QST G02 4 to 20 mA Ext Volt 0
4256A77G01 SST SST G01 Daugter card on QLC G01 0
4256A84G03
3A99159G03 3QID23 QID G03 24VDC/AC card 0
4256A84G06 1QID6 QID G06 card 3
4256A84G11 3QID11 QID G11 card 0
4256A86G01 QAXT QAXT Terminal Block Temperature Sensing card 0
4256A88G01 3MDX3 MDX G01 Board 2
4256A88G01 4MDX7 MDX G01 Board 2
4256A88G03 5MDX3 MDX G03 Board (32-bit 486 processor) Sub H 21
4256A88G04 5MDX4 MDX G04 Board Sub H 32
4256A88G04 7MDX1 MDX G04 Board 47
4256A88G04 9MDX1 MDX G04 Board Sub K 55
4256A88G04 10MDX1 MDX G04 Board 12
4256A90G01 2SGI5 SGI Highway Communication card (for SUN Sparc systems) 15
4256A90G02 2SGI6 SGI Highway Communication card (for GHC Enclosures) 11
4256A91G01 3GHC12 GHC Data Highway Board 1
4256A91G02 3GHC10 SUN VME Chassis GHC w/ 3A59504G02-08 SHC 2.3 firmware 5
4256A91G03 4GHC3 GHC Data Highway Board 8
4256A93G01 2IGI3 IGI Highway Communication card Sub C 2
4256A94G01 3QVP9 QVP G01 LVDT 80 Ohm card 5
4256A96G01 3SCPS2 SCPS Power Supply (Daughter card on GHC) 1
4256A96G02 3SCPS4 SCPS Power Supply (Daughter card on GHC) 1
4256A97G01 5DPX1 486 WEStation DPU Backplane 63
4256A99G02 4DIOB1 DIOB Backplane on Q-crates 1
4256A99G02 5DIOB1 DIOB Backplane on Q-crates 10
4A00054H04 Monitor Intecolor E20FEC 3
4A00030G01 Cable DPX to QBE Power Cable 10
4A00030G03 Cable DPX to QBE Power Cable 10
4A00081G01 Hard Drive Micropolis 1325 85MB HD 3
4A00081H01 Hard Drive Maxtor XT1085 85MB HD 2
4A00090G02 DAT Drive Sun (599-2107-01) DDS3 DAT drives ( 4mm 12/24GB ) 5
4A00090G02 DAT Drive Sun (599-2350-01) DDS4 DAT drives ( 4mm 20/40GB ) 5
4A02729G17 Cable Power Monitor Panel Assy Cable 3
4A02733G02 Panel Power Supply Monitor Panel 3
4A04102G01 Card Cage WEStation MMI Kit (sticker on front edge of VME chassis) 2
4A04102G02 Card Cage
WEStation MMI Kit (sticker on front edge of VME chassis) w/
Serial Port Device 2
4A05326G01 Panel Power Monitor Panel w/ cable Assy 4A02729G17 13
4A06727G13 E-Prom Kit 4MB E-Prom Kit 1
4A06769H01 SUN 4651 Proc VME MB SUN P# 5012055006976 1
4A06769H01 SUN 4651 Proc VME MB SUN P# 5012015035366 1
4A07587G01 Cable MBUS Power Cable 115VAC 20
4D04642G01 Light Cabinet Light Assy 2
4D33612G02 Chassis MMI Chassis 5
4D33613G01 Power Supply
MMI Power Supply Module w/ PowerOne
NRG4A70B4B4K0RZ108 Brick 115VAC 32
4D33613G02 Power Supply
NRG4A70B4B4K0RZ108 Brick 230VAC 9
4D33617G01 OVP Assy Module on RTE Power/Mate SW-12-K-P2956 1
4D33644G01 Keyboard WDPF Operator Desk Top Detached cord Keyboard 115VAC 21
4D33644G02 Keyboard WDPF Operator Desk Top Detached cord Keyboard 230VAC 5
4D33644G03 Keyboard
WEStation Operator Desk Top Detached cord Keyboard
115VAC 9
4D33644G04 Keyboard
230VAC 0
4D33644G05 Keyboard
115VAC 10
4D33644G06 Keyboard
230VAC 1
4D33645G01 Keyboard WDPF Operator Console Detached cord Keyboard 115VAC 6
4D33645G02 Keyboard WDPF Operator Console Detached cord Keyboard 230VAC 0
4D33645G04 Keyboard
WEStation Operator Console Detached cord Keyboard
115VAC 7
4D33645G05 Keyboard
230VAC 1
4D33646G01 DT Hwy Ctrlr
DT Hwy Controller box (supplied w/ any Multibus Highway
Controller Bd required) 1
4D33646G03 DT Hwy Ctrlr
4D33646G05 DT Hwy Ctrlr
Controller Bd required) 17
4D33668G01 RTP Enclosure Assy RTP Enclosure Assy 7
4D33676G01 TCU Drive Assy
Total Control Unit w/ Hard Drive, Floppy, and power supply -
115VAC 1
4D33676G02 TCU Drive Assy
230VAC 1
4D33676G03 TCU Drive Assy
Total Control Unit w/ HD, Floppy, and P/S mounted 2ea on a
rack tray - 115VAC 8
4D33676G04 TCU Drive Assy
rack tray - 230VAC 8
4D33710G01
PowerDistribution
Assy UniPower PG2233 & 3WPM2 4256A57G01 Enclosed 115VAC 6
4D33710G02
Power Distribution
Assy UniPower PG2233 & 3WPM2 4256A57G01 Enclosed 230VAC 6
4D33711G01 Power Supply Assy Acme HF-75753 12 VDC Power Supply RIO Box 0
4D33711G02 Power Supply Assy Acme 2FA1900002A 24 VDC Power Supply RIO Box 0
4D33711G03 Power Supply Assy Acme 48 VDC Power Supply RIO Box 0
4D33743G01 Power Supply Assy
SLIM Power Supply Assy with new Deltron P/S bricks -
115VAC 3
4D33743G02 Power Supply Assy SLIM Power Supply Assy with new Deltron P/S bricks – 3
Multibus P/S for 386 WEStation DPUs w/ 4256A67G01
3MBPS13 Board - 115V AC/DC 63
4D33755G02 Power Supply Assy
3MBPS13 Board - 230V AC/DC 36
4D33755G03 Power Supply Assy
Multibus P/S for 486 WS DPUs MPS512-A w/ 4256A67G01
3MBPS13 - 115V AC/DC 7
4D33755G04 Power Supply Assy
3MBPS13 - 230V AC/DC 7
4D33764G01 TFR Panel Assy
TFR Panel RIO Box w/ 2ea 4256A51G01 3QFR2 cards &
4256A58G01 Backplane 33
TFR Panel RIO Box w/ 6ea 4256A51G01 3QFR2 cards &
4256A58G01 Backplane 8
4D33770G01 TAP Box Assy
TAP Box Assy w/ 2ea Yellow Hwy Cables 3A59527G18, 2ea
Green 3A59526G18, and 2ea Green 3A98720G18 cables 1
4D33804G03 Halfshell DC Distribution Halfshell 4
4D33804G04 Halfshell DC Distribution Halfshell 4
4D33805G01 FOR Fiber Optic Repeater w/ 5FTC17 7381A66G03 4
4D33810G01
Power Distribution
Assy UniPower PG2233 & 3WPM2 4256A57G01 Enclosed 115VAC 1
4D33810G02
Power Distribution
Assy UniPower PG2233 & 3WPM2 4256A57G01 Enclosed 230VAC 1
4D33811G01 GHC Enclosure
DT Hwy Controller Enclosure (2GHC6 G01, 3SCPS4 G01, &
2SGI6 G02 cards) w/ SHC 2.0 firmware 2
DT Hwy Controller Enclosure (3GHC12 G01, 3SCPS4 G01, &
2SGI6 G02 cards) w/ SHC 2.0 firmware 3
DT Hwy Controller Enclosure (4GHC3 G01, 3SCPS4 G01, &
2SGI6 G02 cards) w/ SHC 2.3 firmware 4
4D33811G02 GHC Enclosure
DT Hwy Controller Enclosure (3GHC20 G03, 3SCPS4 G02, &
2SGI6 G02 cards) w/ SHC 2.3 firmware 6
DT Hwy Controller Enclosure (4GHC3 G03, 3SCPS4 G02, &
2SGI6 G02 cards) w/ SHC 2.3 firmware 11
2SGI6 G02 cards) w/ SHC 2.4 firmware 20
DT Hwy Controller Enclosure (4GHC7 G03, 3SCPS4 G02, &
2SGI6 G02 cards) w/ SHC 2.4 firmware 1
4D33816G01 VME Sun Sparc VME Board (3A99732H03 Motherboard) 7
4D33816G03 VME Sun Sparc VME Board (3A99732H03 Motherboard) 1
4D33816G04 VME Sun Sparc VME Board (3A99732H03 Motherboard) 4
4D33864G01 Power Supply Power Supply Chassis for 2ea Plug-in I/O Power Supply Assy 2
4D33865G01 Power Supply
Plug-in 24V DC I/O P/S Assy - 1 Output w/ 2IOPS16
3A99254G01 - 115/230VAC 0
4D33865G02 Power Supply Plug-in 48V DC I/O P/S Assy - 1 Output 0
4D33865G03 Power Supply
Plug-in 24V DC I/O P/S Assy - 2 Output w/ 4IOPS3 3A99254G03
- 115/230VAC 2
4D33865G04 Power Supply Plug-in 24/48V DC I/O P/S Assy 1 Output 0
4D33865G05 Power Supply Plug-in 48V DC I/O P/S Assy 2 Output 0
4D33865G06 Power Supply Plug-in 24V DC I/O P/S Assy 1 Output 115/230VDC 0
4D33888G01 Panel Ovation AC Distribution Center Panel 2
4D33900G19 Power Supply Ovation DIN RAIL Power Supply Assy 2
4D33913G01 Power Supply Plug-in 13V DC I/O Power Supply Assy - DAPS - w/ AC Input 2
4D33913G02 Power Supply
Plug-in 13/24V DC I/O Power Supply Assy - DAPS - w/ AC
Input 6
4D33913G03 Power Supply
Plug-in 13/48V DC I/O Power Supply Assy - DAPS - w/ AC
Input 0
4D33913G04 Power Supply Plug-in 13V DC I/O Power Supply Assy - DAPS - w/ DC Input 16
4D33913G05 Power Supply
Plug-in 13/24V DC I/O Power Supply Assy - DAPS - w/ DC
Input 1
4D33913G06 Power Supply
Plug-in 13/48V DC I/O Power Supply Assy - DAPS - w/ DC
Input 0
4D33914G02 Rack Assy I/O Power Supply Rack Assy 4
4D33914G03 Rack Assy I/O Power Supply Rack Assy 1
4D33914G05 Rack Assy I/O Power Supply Rack Assy 2
4D33915G02 Chassis WEStation 486 Processor DPU Cabinet Assy 6
Multibus P/S MPS512-DC Plug-in P/S 486 WS DPU w/
3A99220G01 MEPS card 73
4D33922G01 Panel Ovation Panel Assy Enclosure for 3A99199G01 backplane 1
4D33935H01 Keyboard Ovation Mylar Operator Keyboard 7
4D33942G01 Controller Ovation Controller (Chassis/Metalwork/Fan) 2
4D33945G01 Controller Ovation Controller (Chassis/Metalwork/Fan) 2
5870C46G02 Cabinet Ovation Cabinet (Hoffman) 1
599C39G05-8 Halfshell Extension Halfshell Extension Assembly - Right 14
599C39G06-8 Halfshell Extension Halfshell Extension Assembly - Left 14
599C39G08-8 Halfshell Extension Halfshell Extension Assembly 6
599C40G01-
10 Halfshell Extension Halfshell Extension Assembly - Right XMTR Pwr (6 fused) 10
599C40G02-
10 Halfshell Extension Halfshell Extension Assembly - Left XMTR Pwr (6 fused) 8
599C41G03-9 Halfshell Extension Halfshell Extension Assembly - Right (8 fused) 4
599C41G04-9 Halfshell Extension Halfshell Extension Assembly - Left (8 fused) 8
599C42G01 Halfshell Extension Halfshell Extension Assembly - Right (single fused) 8
599C42G02 Halfshell Extension Halfshell Extension Assembly - Left (single fused) 8
5A22138G01-
3 Cable 9pin serial ribbon cable (attached to QVP) 4
5A22411H01 Module Ovation Relay Module 16 Channel G2R Relay Panel 10A 2
5A23251G09 Cabinet 486 WEStation DPU Cabinet Assy (sticker on top) 1
5A23307H15 Sun Workstation
Sparc5 built to your spec - all processors/options avail - w/
SGI 27
