厦门兴锐达自动化设备有限公司
  • 供应MODICON
  • 发布时间:2009/7/27 16:16:36   修改时间:2009/7/27 16:16:36 浏览次数:957
    MODICON库存表
    MFR.
    PART NUMBER
    DESCRIPTION
    MODICON
    A205-000
    END CAP
    MODICON
    A984-145
    186 BASED COMPACT CTRLR 8K MEM EXTMEM 10K 256 I/O
    MODICON
    ADU211
    ANALOG INPUT MODULE 8 POINT TC,RTD,MV,4-20MA,+/-MA
    MODICON
    AM0CAV001V003
    LXM17 PC CABLE 9PIN .3M
    MODICON
    AMC-916-100
    16 BIT CPU MODULE
    MODICON
    AMC-916-120
    CPU MODULE
    MODICON
    AMC-921-100
    COMMUNICATION PROCESSOR MODULE
    MODICON
    AMC-924-000
    CPU MODULE 24 BIT
    MODICON
    AMM-907-101
    200 I/O MEMORY MODULE 16K
    MODICON
    AMM-907-121
    800 I/O MEM MOD 16 BIT 800I/O MEM MDL 16BIT 16K
    MODICON
    AMM-907-122
    800I/O MDL MEM 16BIT 32K
    MODICON
    AMM-909-001
    MEMORY MODULE 32K 200I/O
    MODICON
    AMM-909-022
    800I/O MDL MEM 24BIT 64K
    MODICON
    AMS-901-100
    200 I/O PROCESSOR MODULE
    MODICON
    AMS-908-011
    800 I/O MODULE PROC SNGL CHANNEL
    MODICON
    AMS-908-021
    MDL PROC DUAL CHAN 800I/O
    MODICON
    AMS-911-000
    HOT STANDBY MODULE ASSEMBLY
    MODICON
    AMS-911-003
    HOT STANDBY PROCESSOR
    MODICON
    AMS-929-001
    8K 984X MOP MODULE ASSEMBLY
    MODICON
    AMS-985-022
    MODBUSPLUS OPTION 984A/S908
    MODICON
    AMS-985-032
    MB+ OPTION 984B/S901
    MODICON
    AMS-985-042
    MODBUS+OPTION 984B/S908 NETWORK ADAPTER
    MODICON
    AMS-985-800
    NETWORK ADAPTER BUS ASSEMBLY S985MODULE (C)
    MODICON
    AMSA-850-00
    MODBUS+ NETWORK ADAPTOR
    MODICON
    AMSA-850-30
    MODBUS+ NETWORK ADAPTER SINGLE CABLE FOR IBM P
    MODICON
    AS184-B000
    PROGRAMMABLE CONTROLLER MAINFRAME
    MODICON
    AS-212-P020
    ASCII PROM&PCB ASSEMBLY (K)
    MODICON
    AS-280-2000
    INTERFACE MODULE CPU TO P102/112 (G)
    MODICON
    AS-384-A000
    384A MAINFRAME ASSY (D)
    MODICON
    AS-384-A004
    MODICON
    AS-384-A104
    MODICON
    AS-384-B000
    CHASSIS W/M224,C31X +C32X
    MODICON
    AS-384-B204
    MODICON
    AS-483-0000
    CONTROL PANEL ASSEMBLY (J1)
    MODICON
    AS-506-PF32
    PROM/PCB ASSEMBLY (J)
    MODICON
    AS-516-P002
    PCB & PROM ASSEMBLY CPU
    MODICON
    AS-521-P004
    PROM & PCB ASSEMBLY
    MODICON
    AS-521-P008
    PROM & PCB ASSEMBLY IOP
    MODICON
    AS-521-P010
    PCB & PROM ASSEMBLY, IOP
    MODICON
    AS-528-4001
    LITHIUM BATTERY PACK ASSEMBLY
    MODICON
    AS-528-4002
    BATTERY PACK ASSY (ALKALINE)
    MODICON
    AS-537-8002
    MODICON
    AS-548-4002
    BATTERY BACK UP ASSEMBLY LITHIUM
    MODICON
    AS-584-A034
    LEVEL316KCMOS 16BIT W/DX
    MODICON
    AS-584-A042
    LEVEL 432K CMOS 24BIT W/DX
    MODICON
    AS-584-A340
    LEVEL3 16K 3CARD CHASSIS
    MODICON
    AS-584-A341
    LEVEL3 16K 4CARD CHASS W/O DCC (AD)
    MODICON
    AS-584-A450
    LEVEL4 32K 3CARD CHASSIS
    MODICON
    AS-584-L121
    MAIN FRAME ASSMEBLY
    MODICON
    AS-584-L231
    584L MAINFRAME ASSEMBLY
    MODICON
    AS-584-M220
    ASSEMBLY MAINFRAME 584M
    MODICON
    AS-584-M240
    ASSEMBLY SYSTEM MAINFRAME 584M
    MODICON
    AS-5B31-002A
    ISOLATED VOLTAGE INPUT MODULE 0-+5V 4HZ BANDWIDTH
    MODICON
    AS-5B41-002A
    ISOLATED VOLTAGE INPUT MODULE 0-+5V 10KHZ BANDWIDT
    MODICON
    AS-5B47-J01A
    THERMOCOUPLE INPUT MODULE 0-760C 4HZ BANDWIDTH
    MODICON
    AS-5B47-J02A
    THERMOCOUPLE INPUT MODULE -100 TO +300C 4HZ BANDWI
    MODICON
    AS-5B47-K04A
    TYPE K THERMOCOUPLE MODULE 0TO +1000C 4HZ BANDWID
    MODICON
    AS-680-904
    EXECUTIVE CARTRIDGE
    MODICON
    AS-853-3002
    MODICON ANALOG CONNECTOR SET
    MODICON
    AS-853-3003
    MODICON
    AS-8534
    LOW DENSITY CONNECTOR SET
    MODICON
    AS-853-4000
    MODICON
    AS-853-5000
    H-DENSITY MODULE CONNECTOR (40 PINS)
    MODICON
    AS-871-3000
    AC OUTPUT MODULE 115VAC 1A/PT 32 POINT
    MODICON
    AS-884-A101
    CONTROL 2K W/REMOTE I/O
    MODICON
    AS-884-A201
    CONTROL 3.5K W/REMOTE I/O MODULE
    MODICON
    AS-884-A211
    CONTROL 3.5K W/MBUS PORT & RIO
    MODICON
    AS-884-A301
    CONTROL 8K W/REMOTE I/O
    MODICON
    AS-884-A311
    CONTROL 8K W/MBUS PORT AND RIO
    MODICON
    AS-908-110
    REMOTE I/O
    MODICON
    AS-911-TKIT
    HOT STANDBY KIT INLINE TERMINAL
    MODICON
    AS-948-5001
    984 EXECUTIVE CARTRIDGE
    MODICON
    AS-948-7002
    984-380 ENHANCED EXEC CART
    MODICON
    AS-948-7004
    MEMORY CARTRIDGE ASSY
    MODICON
    AS-949-0004
    MEMORY MODULE
    MODICON
    AS-949-0006
    MEMORY MODULE
    MODICON
    AS-949-1002
    MEMORY MODULE
    MODICON
    AS-949-1003
    MEMORY MODULE
    MODICON
    AS-949-2001
    MEMORY MODULE
    MODICON
    AS-953-6000
    800 SER PRIM HSG 11SLT, 984-38X,48X,68X,78X 27IN
    MODICON
    AS-959-3000
    EXEC CART
    MODICON
    AS-964-6001
    MEMORY MODULE
    MODICON
    AS-966-0000
    MEMORY MODULE
    MODICON
    AS-984-A815
    ASSY PWR SUPP 115/230VAC 4CARD
    MODICON
    AS-984-A816
    CHASSIS
    MODICON
    AS-984-X008
    RACK 120/240VAC 1.0/5.0 AMPS 50/60HZ 8K 984X (E)
    MODICON
    AS-B100-000
    AC I/O MODULE
    MODICON
    AS-B109-000
    AC I/O MODULE
    MODICON
    AS-B130
    230V AC MODULE
    MODICON
    AS-B131-000
    CONTROL AC 115V
    MODICON
    AS-B224-001
    OUTPUT MODULE 24VDC TRUE HIGH (U)
    MODICON
    AS-B225-000
    INPUT MODULE 24VDC
    MODICON
    AS-B225-001
    INPUT MODULE 24VDC TRUE HIGH
    MODICON
    AS-B226-501
    REED RELAY MODULE
    MODICON
    AS-B230-000
    OUTPUT MODULE 16 POINT 115VAC
    MODICON
    AS-B230-101
    MODICON
    AS-B230-102
    OUTPUT MODULE 115VAC (S)
    MODICON
    AS-B230-501
    OUTPUT MODULE 115VAC 4 POINT
    MODICON
    AS-B231-000
    INPUT MODULE 16 POINT 115VAC (Z)
    MODICON
    AS-B231-001
    MODICON
    AS-B231-500
    INPUT MODULE 115VAC (U)
    MODICON
    AS-B231-501
    MODICON
    AS-B232-000
    OUTPUT MODULE 24VDC
    MODICON
    AS-B232-501
    OUTPUT MODULE ASSEMBLY 24VDC (U)
    MODICON
    AS-B233-000
    INPUT MODULE 24VDC 16 POINT (Z)
    MODICON
    AS-B233-001
    MODICON
    AS-B233-501
    INPUT MODULE ASSEMBLY (S)
    MODICON
    AS-B236-000
    OUTPUT MODULE 5V TTL 16 POINT (Z)
    MODICON
    AS-B236-001
    MODICON
    AS-B236-501
    OUTPUT MODULE 16 POINT 5V TTL
    MODICON
    AS-B237
    INPUT MODULE 16 POINT 5V TTL (AB)
    MODICON
    AS-B237-000
    MODICON
    AS-B237-001
    MODICON
    AS-B239-000
    COUNTER MODULE HIGH SPEED 0-30KHZ (S)
    MODICON
    AS-B239-001
    MODICON
    AS-B240-000
    RACK ASSEMBLY HOUSING B200 184/384 4 HI (AM)
    MODICON
    AS-B241-000
    I/O HOUSING
    MODICON
    AS-B243-105
    A/D CONVERTER MODULE 4POINT 1-5VDC OR 4-20MA (T)
    MODICON
    AS-B243-110
    ANALOG INPUT MODULE A/D CONVERT 10VDC (S)
    MODICON
    AS-B246-001
    OUTPUT MODULE 115V ISOLATED
    MODICON
    AS-B246-501
    OUTPUT MODULE 115VAC ISOLATED
    MODICON
    AS-B247-001
    INPUT MODULE 115V 8 POINT ISOLATED (X)
    MODICON
    AS-B248-000
    OUTPUT MODULE 10-60VDC (V)
    MODICON
    AS-B248-001
    MODICON
    AS-B248-501
    OUTPUT MODULE ASSEMBLY 10-60VDC 2.5AMP (Y)
    MODICON
    AS-B258-000
    ANALOG MODULE MUX DRY RELAY 0-10V (L)
    MODICON
    AS-B258-001
    MODICON
    AS-B258-101
    ANALOG MODULE MER RELAY 0-10V W/CONN (Y)
    MODICON
    AS-B260-005
    D/A CONVERTER + VOLTAGE
    MODICON
    AS-B262-000
    ANALOG OUTPUT 4 CHANNEL 4-20MA (N)
    MODICON
    AS-B262-001
    MODICON
    AS-B266-000
    REED RELAY MODULE
    MODICON
    AS-B266-501
    INPUT MODULE 10-60VDC (S)
    MODICON
    AS-B273-001
    INPUT MODULE INTRINSICALLY SAFE 12V (X)
    MODICON
    AS-B275-501
    MODICON
    AS-B350-001
    MODICON
    AS-B351-001
    INPUT MODULE 115VAC
    MODICON
    AS-B352-001
    I/O MODULE 24VDC
    MODICON
    AS-B353-000
    INPUT MODULE TRUE LOW 24VDC
    MODICON
    AS-B353-001
    MODICON
    AS-B354-000
    OUTPUT MODULE
    MODICON
    AS-B354-001
    OUTPUT MODULE
    MODICON
    AS-B355-001
    I/O MODULE
    MODICON
    AS-B356-001
    OUTPUT MODULE TRUE HI 24VDC
    MODICON
    AS-B357-001
    INPUT MODULE 24VDC TRU-HI
    MODICON
    AS-B359-001
    INPUT MODULE 24VAC
    MODICON
    AS-B360-001
    OUTPUT MODULE 6 POINT RELAY
    MODICON
    AS-B371-001
    BCD MUX REG INPUT MODULE ASSEMBLY
    MODICON
    AS-B373-000
    ANALOG INPUT
    MODICON
    AS-B375-001
    ANALOG INPUT MODULE 4-20MA
    MODICON
    AS-B428-000
    ANALOG OUTPUT MODULE
    MODICON
    AS-B428-501
    ANALOG OUTPUT MODULE DC V
    MODICON
    AS-B460-000
    I/O MODULE
    MODICON
    AS-B521-001
    RTD INPUT MODULE
    MODICON
    AS-B531-001
    INPUT MODULE 5-28V LAT DC
    MODICON
    AS-B545-000
    I/O HOUSING
    MODICON
    AS-B545-001
    I/O HOUSING
    MODICON
    AS-B546-000
    I/O HOUSING - 4 SLOT
    MODICON
    AS-B548-000
    INPUT MODULE 1-5V ANALOG
    MODICON
    AS-B550-000
    OUTPUT MODULE 115VAC ASSY (G12)
    MODICON
    AS-B550-001
    MODICON
    AS-B550-101
    MODICON
    AS-B551-000
    115VAC INPUT PCB ASSEMBLY (D6)
    MODICON
    AS-B551-001
    INPUT MODULE 115VAC
    MODICON
    AS-B552-000
    OUTPUT MODULE 9-56VDC
    MODICON
    AS-B552-001
    OUTPUT MODULE 10-48VDC
    MODICON
    AS-B553-001
    INPUT MODULE 10-48VDC (Z)
    MODICON
    AS-B556-001
    MODULE 5V TTL OUTPUT (N)
    MODICON
    AS-B556-101
    MODICON
    AS-B557-000
    MODICON
    AS-B557-001
    MODICON
    AS-B558-000
    MODICON
    AS-B558-001
    MODICON
    AS-B559-000
    INPUT MODULE 9-56VDC
    MODICON
    AS-B559-001
    INPUT MODULE 10-48VDC 4 POINT
    MODICON
    AS-B570-001
    MULTIPLEXER MODULE 16 REGULATED OUTPUT
    MODICON
    AS-B573-015
    ANALOG INPUT MODULE -10 TO +10 8 POINT
    MODICON
    AS-B574-001
    ANALOG OUTPUT MODULE 4-20MA
    MODICON
    AS-B592-000
    115VAC REED RELAY MODULE
    MODICON
    AS-B680-101
    ASCII MODULE 115V CUR-LOOP (N3)
    MODICON
    AS-B800-003
    POWER SUPPLY
    MODICON
    AS-B801-000
    SINGLE SLOT FILLER PLATE 800 SERIES
    MODICON
    AS-B802-000
    MODICON
    AS-B803-008
    INPUT MODULE 800IO 115VAC 8 POINT
    MODICON
    AS-B804-000
    MODICON
    AS-B804-016
    MODICON
    AS-B804-116
    OUTPUT MODULE 16 POINT 115VAC 2AMP DISCRETE Q"ty:19
    MODICON
    AS-B805-000
    MODICON
    AS-B805-016
    OUTPUT MODULE 16 POINT 115VAC (Q"ty:27)
    MODICON
    AS-B805-115
    MODICON
    AS-B806-032
    MODICON
    AS-B807-032
    INPUT MODULE 120VAC 32PT
    MODICON
    AS-B807-132
    INPUT MODULE 115VAC 32 POINT
    MODICON
    AS-B810-000
    OUTPUT MODULE 8 POINT ISOLATED
    MODICON
    AS-B810-008
    MODICON
    AS-B814-001
    OUTPUT MODULE 115V N/O RELAY
    MODICON
    AS-B814-002
    115V N/C RELAY OUTPUT MOD (P)
    MODICON
    AS-B814-108
    OUTPUT MODULE RELAY NO/NC 5A/30VDC4A/230VAC 8 PT
    MODICON
    AS-B817-116
    INPUT MODULE 115VAC ISOLATED 16 POINT
    MODICON
    AS-B820-000
    MODICON
    AS-B820-008
    800IO 10-60VDC TRU HI OUT 8PT
    MODICON
    AS-B821-000
    MODICON
    AS-B821-001
    I/O MODULE
    MODICON
    AS-B821-008
    THERMOCOUPLE INPUT MODULE 10-60VDC (V)
    MODICON
    AS-B824-000
    I/O MODULE
    MODICON
    AS-B824-016
    OUTPUT MODULE TRUE HIGH 2A/PT 16 POINT (Q"ty:1)
    MODICON
    AS-B825-000
    INPUT MODULE 800I/O 24VDC TRU HI IN16 POINT
    MODICON
    AS-B825-016
    MODICON
    AS-B826-032
    OUTPUT MODULE 32 POINT
    MODICON
    AS-B827-032
    INPUT MODULE 32 POINT 24VDC (Q"ty:3)
    MODICON
    AS-B828-016
    MODICON
    AS-B829-000
    I/O MODULE
    MODICON
    AS-B829-116
    INPUT MODULE 5V TTL FAST RESPONSE 16 POINT (Q"ty:2)
    MODICON
    AS-B832-000
    INPUT MODULE 24 VDC TRU LO IN 16 POINT
    MODICON
    AS-B832-016
    MODICON
    AS-B833-000
    I/O MODULE
    MODICON
    AS-B833-016
    INPUT MODULE 16 POINT 800IO 24VDC TRUE LOW (Q"ty:1)
    MODICON
    AS-B836-016
    OUTPUT MODULE 12-250VDC TRUE HIGH16 POINT
    MODICON
    AS-B837-016
    I/O MODULE 24VAC/DC IN 16 POINT
    MODICON
    AS-B838-032
    OUTPUT MODULE DISCRETE 32 POINT24VDC .5AMP
    MODICON
    AS-B840-000
    RELAY OUTPUT
    MODICON
    AS-B840-002
    RELAY OUTPUT
    MODICON
    AS-B840-106
    OUTPUT MODULE 8 POINT REED RELAY
    MODICON
    AS-B840-108
    OUTPUT MODULE 8 POINT REED RELAY (Q"ty:1)
    MODICON
    AS-B846-001
    ANALOG MULTIPLEXER VOLTAGE MODULE
    MODICON
    AS-B846-002
    ANAOLG MULTIPLEXER CURRENT MODULE
    MODICON
    AS-B855-016
    800 INPUT MODULE 12VDC INTRINSICALLY SAFE 16 POINT
    MODICON
    AS-B862-001
    OUTPUT MODULE CANNEL REGISTER
    MODICON
    AS-B863-001
    INPUT MODULE 4 POINT REGISTER INPUT MODULE
    MODICON
    AS-B864-001
    MODICON
    AS-B865-001
    MODICON
    AS-B872-000
    800 SERIES ANALOG OUTPUT MODULE
    MODICON
    AS-B872-002
    800 SERIES ANAL OUT,0-10+-,-10TO10,0-5,-5TO+5 4 CH (Q"ty:1)
    MODICON
    AS-B872-011
    ANALOG OUTPUT MODULE W/CONNECTOR (S)
    MODICON
    AS-B872-100
    ANALOG OUTPUT MODULE 4-20 MA 4 CHANNEL (Q"ty:1)
    MODICON
    AS-B872-200
    800 SERIES ANALOG OUTPUT VOLTAGE 4 POINT (Q"ty:1)
    MODICON
    AS-B873-001
    800 SERIES ANALOG INPUTR MODULE4-20MA 4 POINT
    MODICON
    AS-B873-011
    800 SERIES ANL INPUT MOD 0-10V 4-20MA4 POINT (AK)
    MODICON
    AS-B875-001
    800 ANALOG INPUT MODULE 4-20MA 8 POINT W/CONN (AR)
    MODICON
    AS-B875-002
    800 SERIES ANALOG INPUT MODULE 4-20MA 8 POINT
    MODICON
    AS-B875-011
    ANALOG INPUT MODULE 0-10V 8 POINTW/CONNECTOR (AR)
    MODICON
    AS-B875-012
    800 SERIES ANALOG INPUT MODULE0-10V 8 POINT
    MODICON
    AS-B875-101
    MODICON
    AS-B875-102
    800 SERIES ANALOG INPUT MODULE HI SPEED 8 POINT
    MODICON
    AS-B875-111
    ANAOLG INPUT MOD 4-20MA,1-5,-10TO+10,0-20MA,-5TO+5 (Q"ty:2)
    MODICON
    AS-B875-200
    800 SERIES ANALOG INPUT MOD CONFIGURABLE8 POINT
    MODICON
    AS-B881-108
    800IO 115VAC PROT OUT 8PT
    MODICON
    AS-B882-239
    HIGH SPEED COUNTER MODULE 2 POINT 115VA
    MODICON
    AS-B883-001
    HIGH SPEED COUNTER MODULE 2 CHANNEL
    MODICON
    AS-B883-101
    800IO CAM EMULATOR MODULE
    MODICON
    AS-B883-200
    TC INPUT MODULE B,E,J,K,R,S,T, OR LINEAR MV, 10 PT
    MODICON
    AS-B883-201
    800 SERIES TRD INPUT MODULE 8 POINT
    MODICON
    AS-B884-002
    PID MODULE 2 LOOP
    MODICON
    AS-B885-002
    800 SERIES ASCII/BASIC MODULE 2 PORT
    MODICON
    AS-B984-100
    800 SERIES HIGH SPEED LOGIC SOLVER
    MODICON
    AS-BADU-204
    ANALOG 4 INPUT TEMP PT100,+-500MV MODULE 12BIT
    MODICON
    AS-BADU-205
    ANALOG INPUT MODULE 4 POINT +-10V,+-20MA
    MODICON
    AS-BADU-206
    ANALOG INPUT MODULE 3 POINT
    MODICON
    AS-BADU-211
    MODICON
    AS-BADU-214
    ANLG 8 IN 0-5,0-10,+-5,+-10,4-20MA,+-20MA,RTD MOD
    MODICON
    AS-BADU-216
    A120 INPUT MODULE TC 8 POINT
    MODICON
    AS-BDA0-216
    OUTPUT MODULE DC 16 POINT
    MODICON
    AS-BDAO-216
    MODICON
    AS-BDAP-204
    4 POINT RELAY 2A OUT MOD, 24-110VDC/24-230VAC
    MODICON
    AS-BDAP-208
    OUTPUT MODULE 8 POINT RELAY 2A
    MODICON
    AS-BDAP-209
    AC OUTPUT LKA 120
    MODICON
    AS-BDAP-210
    OUTPUT MODULE 8 POINT ISOLATED 24-120VAC-230VAC 1A
    MODICON
    AS-BDAP-212
    A120 INPUT MODULE 4 POINT 8-24VDC 2A RELAY
    MODICON
    AS-BDAP-216
    OUTPUT MODULE DC 16 POINT 24VDC
    MODICON
    AS-BDAP-216N
    A120 IO DC OUT 16PT 24VDC
    MODICON
    AS-BDAP-217
    A120 OUT MOD 16 POINT 5-24VDC TRUE LOW 3A ISOLATED
    MODICON
    AS-BDAP-218
    A120 OUT MOD 16 POINT 24-240VAC .5AISOLATED
    MODICON
    AS-BDAP-220
    I/O MODULE DC 8 IN / 8 OUT
    MODICON
    AS-BDAU-202
    ANALOG 2 OUT +-10,+-20MA MODULE 11 BIT + SIGN,ISOL
    MODICON
    AS-BDAU-204
    ANALOG OUTPUT MODULE 4 POINT
    MODICON
    AS-BDAU-205
    ANALOG INPUT MODULE 4 INPUT
    MODICON
    AS-BDAU-208
    ANALOG 8 OUTPUTS +-10V MODULE11 BIT +SIGN, ISOLAT
    MODICON
    AS-BDEO-216
    A120 IO DC IN 16PT 24VDC
    MODICON
    AS-BDEP-208
    MODICON
    AS-BDEP-209
    INPUT MODULE
    MODICON
    AS-BDEP-210
    INPUT MODULE 8 POINT 120VAC ISOLATED
    MODICON
    AS-BDEP-211
    INPUT MODULE 8 POINT ISOLATED
    MODICON
    AS-BDEP-216
    INPUT MODULE 16 POINT 24VDC TRUE HIGH
    MODICON
    AS-BDEP-217
    INPUT MODULE 16 POINT 24VDC TRUE LOW A120
    MODICON
    AS-BDEP-218
    INPUT MODULE 16 POINT 115VAC ISOLATED
    MODICON
    AS-BDEP-220
    INPUT MODULE 16 POINT 24VDC FAST
    MODICON
    AS-BM0T-202
    MOTION MODULE FOR COMPACT PLC WITH ENCODER/RESOLVE
    MODICON
    AS-BNUL-200
    I/O MODULE A120 PRE WIRED DUMMYMODULE
    MODICON
    AS-BZAE-201
    HIGH SPEED COUNTER 50KHZ AT 24 OR 5VDC RLY OUTPUT
    MODICON
    AS-BZAE-204
    HIGH SPEED COUNTER MODULE 4 CHANNEL 1KHZ
    MODICON
    AS-C384-104
    MAINFRAME 1PCB 1M/W (J)
    MODICON
    AS-C484-005
    484 CHASIS ASSEMBLY
    MODICON
    AS-C484-012
    484 CHASIS ASSEMBLY
    MODICON
    AS-C484-065
    CONTROL 115V 60HZ 4096W (S) (Y1)
    MODICON
    AS-C484-163
    CONTROL 115V 60HZ 1024W (E) (Y1)
    MODICON
    AS-C484-164
    CONTROL 115V 60HZ 2048W (E) (Y1)
    MODICON
    AS-C484-165
    CONTROL 115V 60HZ 4096W (E) (Y1)
    MODICON
    AS-C484-263
    CONTROLLER 115V 60HZ 1024W E/COM (Y1)
    MODICON
    AS-C484-265
    CONTROLLER ENH2 4K, 115V 60HZ, 4096W
    MODICON
    AS-C484-266
    CONTROL 115V 60HZ 8192W E/COM (Y1)
    MODICON
    AS-C916
    CPU CARD
    MODICON
    AS-C916-000
    CPU CARD
    MODICON
    AS-C924-000
    CPU MODULE
    MODICON
    ASC-IIDAP
    ASC II DAP CABLE STYLE 2464
    MODICON
    AS-D908-110
    984-8 DIST CONTROL PROCESSOR SINGLE CBLL
    MODICON
    AS-DAV-202
    ANALOG MODULE
    MODICON
    AS-DEP-209
    INPUT MOD
    MODICON
    AS-E380-902
    MODICON
    AS-E381-902
    EXEC CARTRIDGE ASSY
    MODICON
    AS-E385-904
    ENHANCED EXEC CART 385
    MODICON
    AS-E485-904
    984-480 ENHANCED EXECUTIVE CARTRIDGE
    MODICON
    AS-E680-904
    984-680 ENHANCED EXEC CARTRIDGE ASSEMBLY
    MODICON
    AS-E685-904
    ENHANCED EXEC CARTRIDGE 685
    MODICON
    AS-E785-904
    EXEC CARTRIDGE ASSY 785
    MODICON
    AS-E902-141
    984B EXECUTIVE CARTRIDGE ASSEMBLY
    MODICON
    AS-E908-016
    S908 EXECUTIVE CARTRIDGE 16 DROPS
    MODICON
    AS-E908-031
    S908 REM I/OPROC EXEC CRTRGD 31DROP 512BITSIN&OU
    MODICON
    AS-H810-100
    800 SERIES HOUSING SECONDARY 10 INCH
    MODICON
    AS-H810-208
    984 HOUSING PRIMARY 10 INCH
    MODICON
    AS-H819-000
    I/O HOUSING
    MODICON
    AS-H819-007
    I/O HOUSING RACK
    MODICON
    AS-H819-100
    SECONDARY HOUSING 7 SLOT 19 INCH
    MODICON
    AS-H819-103
    800 SER PRIMARY HOUSING 7 SLOT 19 INCH
    MODICON
    AS-H819-107
    I/O RACK
    MODICON
    AS-H819-209
    800 SER PRIM HSG 7SLT 984,38X,48X,68X,78X,P89X,RIO
    MODICON
    AS-H827-000
    I/O HOUSING
    MODICON
    AS-H827-003
    I/O HOUSING
    MODICON
    AS-H827-007
    RACK
    MODICON
    AS-H827-100
    800 SERIES SECONDARY HOUSING 11 SLOT 27 INCH (Q"ty:5)
    MODICON
    AS-H827-103
    800 SERIES PRIMARY HOUSING 11 SLOT 27 INCH
    MODICON
    AS-H827-107
    800 SERIES HOUSING
    MODICON
    AS-H827-205
    I/O HOUSING
    MODICON
    AS-H827-209
    800 SER PRIM HSG 11SLT, 984-38X,48X,68X,78X 27IN (Q"ty:2)
    MODICON
    AS-HDTA-200
    RACK
    MODICON
    AS-HDTA-201
    RACK
    MODICON
    AS-J146-000
    INTERFACEUPP MULTI NODE PANEL (K)
    MODICON
    AS-J200-001
    LOCAL I/O INTERFACE EXPANDER
    MODICON
    AS-J291-010
    INTERFACE
    MODICON
    AS-J375-001
    ADAPTER
    MODICON
    AS-J375-010
    MODBUS ADAPTER
    MODICON
    AS-J378-000
    MODEM ASSEMBLY (P1)
    MODICON
    AS-J470-000
    ADAPTER
    MODICON
    AS-J471-500
    DISCRETE I/O EXPANDER
    MODICON
    AS-J471-600
    I/O EXPANDER
    MODICON
    AS-J471-601
    I/O EXPANDER
    MODICON
    AS-J478-010
    STAND ALONE MODEM 110V
    MODICON
    AS-J540-000
    ADAPTER 184/384 (L1)
    MODICON
    AS-J540-001
    ADAPTER ASSY
    MODICON
    AS-J810-000
    S901 RIO INTF SNGL CH (Q"ty:1)
    MODICON
    AS-J810-001
    MODICON
    AS-J812-000
    INTERFACE SINGLE CHANNELL
    MODICON
    AS-J871-008
    INDEPENDENT THERMO MODULE (J)
    MODICON
    AS-J878-000
    MODEM ASSEMBLY
    MODICON
    AS-J890-001
    REMOTE I/O INTERFACE SINGLE CHANNEL 984/800
    MODICON
    AS-J890-002
    800 SERIES REMOTE I/O INTERFACE
    MODICON
    AS-J890-101
    MODICON
    AS-J890-102
    MODICON
    AS-J892-001
    ASCII MODULE 984/800 RI/O INTERFACE SIN
    MODICON
    AS-J892-101
    INTERFACE
    MODICON
    AS-M380-004
    MODICON
    AS-M380-006
    MODICON
    AS-M480-008
    MEMORY CARTRIDGE
    MODICON
    AS-M680-008
    MEMORY CART
    MODICON
    AS-M680-108
    ASSY PCB MEM CART 8K
    MODICON
    AS-M680-116
    ASSEMBLY PCB MEMORY CARTRIDGE 16K
    MODICON
    AS-M780-032
    MODICON
    AS-M84A-001
    MICRO CONTROLLER
    MODICON
    AS-M84A-002
    MICRO 84 CONTROLLER 64 BIT 84/32
    MODICON
    AS-M84K-001
    END CAPS
    MODICON
    AS-M84K-002
    BRACKETS
    MODICON
    AS-M84K-003
    BRACKETS
    MODICON
    AS-M84K-004
    PLASTIC CLIPS
    MODICON
    AS-M84K-006
    KEY SET
    MODICON
    AS-M84K-010
    PANEL LABELS
    MODICON
    AS-M84K-011
    ON/OFF LABELS
    MODICON
    AS-M84K-012
    MICRO 84 CONTROL LABELS
    MODICON
    AS-M84K-015
    LOAD CONTROL LABELS
    MODICON
    AS-M907-122
    MEMORY MODULE
    MODICON
    AS-M984A-230
    PROGRAMABLE CONTROLLER
    MODICON
    AS-MBKT-085
    MB+ TERMINATOR CONNECTOR KIT - 1 PC
    MODICON
    AS-MBKT-185
    MB+ TERMINATOR CONNECTOR KIT - 2 PCS
    MODICON
    AS-MBPL-001
    MODBUS + CONNECTOR ASSEMBLY TOOL
    MODICON
    AS-MEEP-000
    COMP. 984 MEM BRD EEPROM 32
    MODICON
    AS-P105
    PROGRAMMING CHIP
    MODICON
    AS-P120-000
    POWER SUPPLY MODULE AC 105...240VAC IN,24VDC 1A O
    MODICON
    AS-P120-125
    COMPACT PWR SPLY 105...150VDC IN,24VDC 1.5A OUT
    MODICON
    AS-P180-010
    PROGRAM CRT 115V 50/60HZ (AD)
    MODICON
    AS-P190-112
    TERMINAL FOR 484, 584, 884, AND MICRO 84
    MODICON
    AS-P190-212
    PROGRAMMER
    MODICON
    AS-P370-000
    PROGRAMMER MICRO 84
    MODICON
    AS-P370-001
    PROGRAM TERMINAL
    MODICON
    AS-P371-001
    MEMORY
    MODICON
    AS-P371-002
    PROGRAM MODULE
    MODICON
    AS-P420-000
    POWER SUPPLY
    MODICON
    AS-P420-001
    POWER SUPPLY
    MODICON
    AS-P420-510
    POWER SUPPLY 115VAC 60HZ
    MODICON
    AS-P420-61M
    POWER SUPPLY 120V 60HZ
    MODICON
    AS-P421-000
    AUXILARY POWER SUPPLY MODULE 50/60HZ 120V
    MODICON
    AS-P421-010
    MODICON
    AS-P421-112
    AUXILLARY POWER SUPPLY W/ W602
    MODICON
    AS-P451-522
    REMOTE I/O PWR SUPP 50HZ
    MODICON
    AS-P451-622
    REMOTE I/O POWER SUPPLY 60HZ
    MODICON
    AS-P451-681
    ASSY REM I/O PWR SUPPLY
    MODICON
    AS-P452-012
    CHAN 3&4 DECODER W/CABLE
    MODICON
    AS-P453-611
    REMOTE INTERFACE ASSEMBLY ASCII (AE) 60HZ I/O 1M
    MODICON
    AS-P453-612
    REMOTE INTERFACE ASCII MODULE
    MODICON
    AS-P453-621
    REMOTE INTERFACE ASSEMBLY 60HZ ASCII 0 I/O 1M (AE)
    MODICON
    AS-P453-622
    POWER SUPPLY
    MODICON
    AS-P453-631
    POWER SUPPLY
    MODICON
    AS-P453-632
    MODICON
    AS-P464
    KEYPAD
    MODICON
    AS-P464-002
    PROGRAM TERMINAL/MONITOR W/ CONTROL (S)
    MODICON
    AS-P484-600
    POWER SUPPLY ASSEMBLY 60HZ (AG2)
    MODICON
    AS-P530-0MA
    POWER SUPPLY 50/60HZ 110/220VAC (A1)
    MODICON
    AS-P800-003
    POWER SUPPLY MODULE 884 SERIES 115-230V
    MODICON
    AS-P801-001
    POWER SUPPLY
    MODICON
    AS-P804-001
    POWER SUPPLY PRE/AUX 115/230VAC
    MODICON
    AS-P805-001
    POWER SUPPLY
    MODICON
    AS-P810-000
    POWER SUPPLY PRE/AUX 115/230VAC(Q"ty"2)
    MODICON
    AS-P810-001
    PWRSUP 884 RI/O W/KYSW
    MODICON
    AS-P830-000
    800IO AC POWER SUPPLY (Q"ty:1)
    MODICON
    AS-P840-000
    POWER SUPPLY MODULE 800IO AC PRIM/AUX HI PWR
    MODICON
    AS-P864-001
    POWER SUPPLY
    MODICON
    AS-P865-001
    POWER SUPPLY
    MODICON
    AS-P884-001
    884 PWR SUPP 170WATTS
    MODICON
    AS-P884-A10
    POWER SUPPLY
    MODICON
    AS-P890-000
    800 SERIES REMOTE I/O ADAPTOR PWR SPLY 24VDC
    MODICON
    AS-P892-000
    S908 RIO INTF/PS SNGL CH ASCII
    MODICON
    AS-P930-000
    POWER SUPPLY
    MODICON
    AS-P930-007
    CHASSIS
    MODICON
    AS-P930-204
    MODICON
    AS-P933-000
    POWER SUPPLY ASSY (OBS)
    MODICON
    AS-P933-001
    984 HI POWER SUPPLY
    MODICON
    AS-P964-000
    DATA ACCESS PANEL
    MODICON
    AS-P965-000
    PROD SPEC P965 MBUS DAP PANEL DATA LINK
    MODICON
    AS-PM84A-002
    MODICON
    AS-S378-002
    MODULE
    MODICON
    AS-S470-000
    EIA ADAPTER PCB ASSY (B27)
    MODICON
    AS-S480-207
    CPU PROM DAUGHTER ENCO 8K EXEC
    MODICON
    AS-S481-100
    BASIC EXEC PROM ASSY PCB
    MODICON
    AS-S484-200
    POWER SUPPLY PCB (F12)
    MODICON
    AS-S540-004
    MODULE
    MODICON
    AS-S901-100
    REMOTE I/O INTFC PCB ASSY (A20)
    MODICON
    AS-S902-111
    MDL ASSY EXEC PLUG IN
    MODICON
    AS-S902-131
    MODICON
    AS-S902-141
    EXEC PCB ASSY CART PLUG IN
    MODICON
    AS-S902-161
    ASSY PCB 984B EXEC CART PLUGIN
    MODICON
    AS-S908-000
    800 I/O PROCESSOR MODULE
    MODICON
    AS-S908-001
    CONTROLLER
    MODICON
    AS-S908-011
    I/O MODULE
    MODICON
    AS-S908-012
    PROCESSOR MODULE SINGLE CABLE
    MODICON
    AS-S908-110
    MODICON
    AS-S908-120
    PROCESSOR MODULE 984-8 S908 DUAL CABLE
    MODICON
    AS-S911-000
    HOT STANDBY MODULE
    MODICON
    AS-S911-003
    MODICON
    AS-S911-800
    HOT STANDBY MODULE
    MODICON
    AS-S911-801
    HOT STANDBY MODULE
    MODICON
    AS-S985-800
    HOT STANDBY MODULE
    MODICON
    AS-SM884-A002
    HOT STANDBY MODULE
    MODICON
    AS-T190-000
    TAPE
    MODICON
    AS-T190-001
    TAPE
    MODICON
    AS-T190-301
    TAPE
    MODICON
    AS-T190-401
    BLANK P190 TAPE ASSY (U3)
    MODICON
    AS-T484-001
    TAPE
    MODICON
    AS-T584-002
    TAPE
    MODICON
    AS-T584-004
    TAPE
    MODICON
    AS-T884-001
    TAPE
    MODICON
    AS-T884-003
    TAPE
    MODICON
    AS-T984-301
    TAPE
    MODICON
    AS-T984-304
    TAPE
    MODICON
    AS-W180-025
    CABLE ASSY P180 COMM
    MODICON
    AS-W190-025
    CABLE P190/584 MF 25 FT
    MODICON
    AS-W510-004
    NOW BUS CABLE
    MODICON
    AS-W510-006
    CABLE ASSEMBLY I/O BUS 6 HOUSING
    MODICON
    AS-W510-008
    CABLE ASSEMBLY I/O BUS 8HSGCM
    MODICON
    AS-W600-006
    CABLE 6 FEET CPU TO CHAN ONE
    MODICON
    AS-W600-009
    CABLE 9'CPU TO CHAN ONE
    MODICON
    AS-W600-012
    CHANNEL 1 M/F I/O CABLE ASSEMBLY
    MODICON
    AS-W801-001
    SIGNAL CABLE
    MODICON
    AS-W801-002
    REMOTE I/O SIGNAL CABLE 1.5FT
    MODICON
    AS-W801-006
    SIGNAL CABLE 6 FEET
    MODICON
    AS-W801-012
    800 SERIES REMOTE I/O CABLE 3.6M 12FEET
    MODICON
    AS-W802-012
    800IO POWER CABLE 12 FEET
    MODICON
    AS-W804-002
    I/O POWER EXTENDER CABLE 1.5 FT
    MODICON
    AS-W804-012
    I/O PWR EXTENDER CABLE
    MODICON
    AS-W808-002
    800 SERIES I/O CABLE
    MODICON
    AS-W808-006
    800IO POWER CABLE 6 FEET
    MODICON
    AS-W885-003
    CABLE MOT MOD TO BRKOUT BOX
    MODICON
    AS-W907-025
    984/P190 CABLE ASSY 25FT
    MODICON
    AS-W911-006
    HOT STANDBY DATA LINK CABLE 6 FT
    MODICON
    AS-W952-012
    CABLE COMPACT PROGRAMMING IBMPC-AT RS232
    MODICON
    AS-W953-012
    CABLE ASSEMBLY
    MODICON
    AS-WBXT-201
    COMPACT SUB RACK BUS EXTENSION CABLE
      TSX QUANTUM 140-CPS-114-00 AC PS 115/230V 8AMP  1 pcs
                                             MODECON SERVO MOTOR   ASAI
    Model No. S77C-E00-P010       Style CGP 37
    Rated:5.7HP,4.26kW,19.8A,1500RPM
    Stall:316.4  In.Lb 35.8  Nm 26.1A
    Max. Cont:2222RPM
    L-L Res:0.26 Ohms
    Rated Ambient:40℃
    Brake Stall:N/A
    M477-CESO-ONOE   REV E  1983-0005  BP
      AEG MODICON DAP208 8 DIG O RELAY 2A REV 3  0pcs
      AEG Modicon DEP-218 16-Pt. Input Module 115VAC  0pcs
      AEG Modicon PC-E984-685 Processor Module PCE984685 2pcs
      Schneider Gould Modicon AS-BDEP-216 Discrete Input  5pcs
      MODICON PC-A984-145 CPU MODULE  1pcs
      Schneider Modicon TSX Quantum 140 CPU 113 02 CPU Module  1pcs
    98.03.06
    Part# Description Q"ty
    1 140CPU11302 CPU MODULE 256K RAM 8K USER LOGIC 1 X MB+ 1
    2 AS-B804-116 I/O MODULE 115VAC 2
    3 AS-B805-016 INPUT MODULE 16POINT 115VAC 27
    4 AS-B806-032 OUTPUT MODULE 115VAC 1A/PT 32POINT 12
    5 AS-B808-016 OUTPUT MODULE 16POINT 230VAC 3
    6 AS-B809-016 INPUT MODULE 16POINT 800 I/O 230VAC 7
    7 AS-B824-016 OUTPUT MODULE TRUE HIGH 2A/PT 16POINT 1
    8 AS-B827-032 INPUT MODULE 32POINT 24VDC 3
    9 AS-B829-116 INPUT MODULE 5V TTL FAST RESPONSE 16POINT 2
    10 AS-B833-016 INPUT MODULE 16POINT 800IO 24VDC TRUE LOW 1
    11 AS-B840-108 OUTPUT MODULE 8POINT REED RELAY 1
    12 AS-B872-002 OUTPUT MODULE ANALOG 0-10+- -10-10 0-5 -5TO+5 4PT 12
    13 AS-B872-100 OUTPUT MODULE ANALOG 4-20MA 4POINT 1
    14 AS-B872-200 OUTPUT MODULE ANALOG VOLTAGE 4POINT 0
    15 AS-B875-001 ANALOG INPUT MODULE 4-20MA 8POINT W/CONN AR 800 5
    16 AS-B875-002 INPUT MODULE ANALOG 4-20MA 8POINT 1
    17 AS-B875-111 INPUT MODULE ANALOG 4-20MA 1-5 -10+10 0-20MA -5-+5 2
    18 AS-B883-201 INPUT MODULE 8POINT 800 I/O TRD 5
    19 AS-BDEP-216 INPUT MODULE 16POINT 24VDC TRUE HIGH 5
    20 AS-H827-100 RACK 11SLOT 27INCH SECONDARY 5
    21 AS-H827-209 RACK PRIMARY 11SLOT 984-38X 48X 68X 78X 27IN 2
    22 AS-J810-000 INTERFACE MODULE S901 RIO 1POINT 1
    23 AS-J890-001 REMOTE I/O INTERFACE SINGLE CHANNEL 984/800 3
    24 AS-P810-000 POWER SUPPLY MODULE PRE/AUX 115/230VAC 2A 50/60HZ 2
    25 AS-P830-000 POWER SUPPLY AUXILLARY 800IO AC 1
    26 AS-P884-001 POWER SUPPLY MODULE 170WATTS 4
    27 AS-S908-110 CPU MODULE REMOTE 800 I/O 2
    28 AS-S911-800 MODULE HOT STANDBY 2
    29 CM1000 COMMUNICATIONS MODULE FOR RF TAG SYSTEM 3
    30 PC-0984-685 CPU MODULE MBUS PLUS PEER TO PEER 4
    31 PC-A984-145 PLC 8K MEM/10K USER 256I/O MODBUS+PORTS 1
    32 PC-E984-385 CONTROLLER MODULE 984CPU 16K 24VDC/115/230VAC 1
    33 PC-E984-685 CPU MODULE 24VDC 115/230VAC PS 984 SLOT MNT 2
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • 劉治安 在2025/7/8 16:34:00留言
  • 详细留言:安川HW9171094-A請惠予報價
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
