Motorola Single Board Computer - MVME - 167
25 or 33 MHz MC68040 32-bit microprocessor with 8KBof cache, MMU, and FPU
Full 32-bit master/slave VMEbus interface
High performance DMA supports VMEbus D64 and local bus memory burst cycles
4, 8, 16, 32 or 64MB on-board DRAM, four-way interleaved, with parity checking
Checking and Correction (ECC) option
On-board SCSI interface with 32-bit local bus burst DMA
On-board Ethernet interface with 32-bit local bus DMA
Four 44-pin sockets for up to 4MB on-board ROM/EPROM
Four EIA-232-D serial ports implemented with quad serial I/O processor
8-bit, bidirectional, Centronics? compatible parallel port
Four 32-bit timers and one watchdog timer
8KB of NVRAM with real-time clock/calendar
Remote Reset/Abort/Status control functions
Completely programmable for maximum integration flexibility
Low power consumption—less than 20 watts typical
| MVME165 |
68040 CPU, 25Mhz, 4MB memory, VSB, 2 serial ports |
1 |
| MVME167 |
Various options and configs, see below.. |
5 |
| MVME167-04A |
68040U CPU, 25Mhz, 32MB |
2 |
| MVME167-031A |
68040 CPU, 33Mhz, FPU, Ethernet, SCSI, DMA |
3 |
| MVME167-032B |
68040 CPU, 33Mhz, 8KB, MMU, FPU, 8MB, ENET, SCSI |
4 |
| MVME167-033A |
68040 CPU, 33Mhz, 8KB, MMU, FPU, 16MB, ENET, SCSI |
2 |
| MVME167-033B |
1 |
| MVME167-034A |
68040 CPU, 33Mhz, 8KB, MMU, FPU, 32MB, ENET, SCSI |
2 |
| MVME167-34B |
68040 CPU, 33Mhz,8KB, MMU, FPU, 32MB, ENET, SCSI |
15 |
| MVME167-034B |
15 |
| MVME167-035B |
68040 CPU, 33Mhz,8KB, MMU, FPU, 64MB, ENET, SCSI |
4 |
| MVME167-036B |
68040 CPU, 33Mhz,8KB, MMU, FPU, 128MB, ENET, SCSI |
2 |
| MVME167P-036SE |
4 |
| MVME167P-35SE |
2 |
| MVME167P-34SE |
3 |
| MVME167-04 |
68040 CPU, 25 MHz, 32MB |
5 |
| MVME167A |
68040 CPU, 25MHz, 8MB |
1 |
| MVME167C |
68040 CPU, 25Mhz, 8KB, MMU, FPU, 4,8,16,or 32MB |
1 |
| MVME167P-24SE |
68040 CPU, 25Mhz, 8KB, MMU, FPU, 16MB, ENET, SCSI |
2 |
| MVME167P-35SE |
68040 CPU, 25Mhz, 8KB, MMU, FPU, 32MB, ENET, SCSI |
5 |
Motorola Single Board Computer - 712/M with P2 Adapter and Cables - Adapters
