厦门兴锐达自动化设备有限公司
  • 供应FOXBORO I/A
  • 发布时间:2009/7/7 14:32:06   修改时间:2009/7/7 14:32:06 浏览次数:622
    FOXBORO I/A
    FOXBORO I/A
    Part#/Description Q"ty
    1 AW51B P61000436240 SUN Spare Station5 3
    2 AW51B P62060176240 SUN Spare Station5 2
    3 CM400YQ 1
    4 P0400DA FBM10 0-20mA Input 7
    5 P0400HH REV L 3
    6 P0400HH REV M 5
    7 P0400VE 8
    8 P0400VP CMP10 1
    9 P0400VT Application Processor 20 1
    10 P0400YC FBM02 Thermcouple/MV Input 51
    11 P0400YE FBM04 0-20mA Input/Output 13
    12 P0400YG FBM06 Pluse Input 1
    13 P0400YV FBM18 Intelligent Transmitter 26
    14 P0400ZE FBM04 0-20mA Input/Output 1
    15 P0500RG REV J 49
    16 P0500RU 2
    17 P0500RY REV M 61
    18 P0700TT REV G 21
    19 P0700TT REV H 1
    20 P0700TT REV M 2
    21 P0800DA REV M 10
    22 P0800DC REV K 37
    23 P0800DG REV K 1
    24 P0800DV REV K 1
    25 P0902UT FBM39 Intell Xmitter 0-20mA 72
    26 P0903CW ANNUM/Nuberic Keyboard 2
    27 P0903ZE Fieldbus Isolater 39
    28 P0903ZL Power Supply 96
    29 P0904BR CRT Converter 3
    30 P0904BR Keyboard 4
    31 P0904HW power supply 500W 8
    32 P0912AR Fiber Optic LAN Converter 1
    33 P0912KA-OC 1
    34 P0914WM FBM241C 1
    35 P0916AM Termination Assembly FBM207 2tier Compression 8
    36 P0916CP FCM10Ef 2
    37 P0916JT Terminal Assembly Compression FBM211 Ext Powered 8
    38 P0916JZ-0A Termination Assembly FBM242 Fused 2tier Compressio 2
    39 P0916NG Termination Assembly FBM242 2tier Compression 7
    40 P0951AK 2
    41 P0951AP FOR FBC21 1
    42 P0951BA-0E FBP10 Fieldbus Processor 10 5
    43 P0951BV REV E 8
    44 P0951BX REV B 2
    45 P0951CE-A FBC01 4-20mA Analog Input Module (32Point) 1
    46 P0951CJ-C FBC-07B Contact Sense Input Module (32Point) 3
    47 P0951CK-A FBC09 Digital Output Module (32Point) 2
    48 P0951CL-C FBC21 4-20mA Analog Input Module (16Point) 2
    49 P0951CL-H FBC21 4-20mA Analog Input Module (16Point) 1
    50 P0951CP IPM27 Chassis PWR Supply 120 VAC 1
    51 P0951CQ REV G 99
    52 P0951CQ REV G 78
    53 P0951CR 72
    54 P0951CT-A PM20 PWR Monitor Card 1
    55 P0951DK 2
    56 P0951EA FBC07 I/O Module Rack 1
    57 P0960GC WP30 Workstation Processor 1
    58 P0960JA CP40 Control Processor 9
    59 P0970BM-B VOLEX 5
    60 P0970JE-0A 547G4672 CD-ROM 1
    61 P0970WX REV B 1
    62 P0971PE-B VOLEX 5
    63 P0971UN 9.1GB Hard Disk 2
    64 PM400YD FBM03 2
    Model Type Qty Description
    1 Base P0914XA  29 Foxboro 200 Series Horizontal Baseplate
    2 FBM203 P0914SV  10 RTD Input Module Gently Used
    3 FBM205 P0914XG  93 FBM205 Redundant 0-20 Combo Module
    4 FBM207 P0914TD  21 Channel Isolated 16 DIN Voltage Monitor
    5 FBM211 P0914TN  43 Differential 16 Input 0-20 mA
    6 FBM217 P0914TR  55 Discrete Inputs, 32 Channels
    7 FBM217 TA P0916PY  73 Compression Term Assy, FBM217, 120/125V Switch DI
    8 FBM242 P0916TA  48 Channel Isolated External Source DO
    9 FBM242 TA P0916JZ  57 Compression Term Assembly, FBM242, Fused Relay Out
    10 FBM242 TA P0916NG  10 Compression Term Assembly, FBM242, 5A Relay Out
    11 FCM10EF P0916CP   4 2KM Fieldbus Communication Module
    1 CP40B P0961BC   3 CP40B-CPU Control Processor 40 Style B Module
    2 CP60 P0961FR   1 CP60-CPU Control Processor 60
    3 FB110E P0972AJ   2 FB110E Field Bus Isolator for 10MB Ethernet
    4 FBM01 P0400DA   3 FBM01 0-20mA Input
    5 FBM02 P0400YC   6 FBM02 Thermocouple/mV Input
    6 FBM03 P0400YD   3 FBM03 RTD Input
    7 FBM04 P0400YE   1 FBM04 0-20mA Input/Output
    8 FBM07 CM400YH   1 FBM07 Contact/dc Input
    9 FBM08  CM400YJ   2 FBM08 120 Vac Input
    10 FBM10 CM400YL   5 FBM10 120 Vac I/O
    11 FBM11  CM400YM   1 FBM11 240 Vac Input/Output
    12 FBM18 P0400YV   8 FBM18, Intelligent Transmitter I/O, P/N - P0400YV
    13 FBM203 P0914SV   4 P0914SV OB 1801372428
    14 FBM241C P0914WM   34 FBM241C 8 input Ch Isolated contact sense, 8 output switch
    15 FBM39 P0902UT   16 FBM39 Intelligent Transmitter Input / 0-20mA Output
    16 FBM41 P0902XA   2 FBM41 Contact/dc Input/High Current Dc Output
    17 FBM43 P0950BM   1 FBM43 Dual Baud Intelligent Transmitter Interface
    18 FBM44  P0950BN   13 FBM44 Dual Baud IT Input/0-20 mA Output Interface
    19 CM902WL   3 2, 120-240Vac, 100 mS
    20 P0400VE   3 Fieldbus Isolator
    21 P0903ZL   2 Industrial Pwr Mod 2, 120-240 Vac, 100 ms (EC96
    22 P0914XB   3 FBM 2xx Vertical Baseplate
    23 P0916FK   24 FBM 2xx, TYPE 4 TERM CABLE, 5 METERS, P/N P0916FK
    24 P0916JW   24 Comp TA FBM241c Contact Sense I/O 2A 60V Fused Out
    25 P0970BC   1 DNB1 Dual Node Interface Module
    26 P0971WV   1 DNBT - Communication Module
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • 劉治安 在2025/7/8 16:34:00留言
  • 详细留言:安川HW9171094-A請惠予報價
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
