艾讯宏达推出英特尔H61芯片组工业母板SYM76993VGGA
发布时间:2013-01-18 作者:www.cechina.cn
近日,艾讯宏达隆重推出英特尔H61芯片组工业母板SYM76993VGGA。SYM76993VGGA支持LGA1155英特尔i3/i5/i7处理器,最大支持16GB DDR3 内存。集成2个英特尔千兆网络控制器, 10个USB接口。支持1个PCIe 16X,1个PCIe 1X,2个PCI扩展槽。SYM76993VGGA能够支持10个串口,特别适用于高铁/地铁自动售票机、ATM机、自助终端机等金融自动化领域。
详细规格:
| >> System |
| Processor |
LGA1155 for Intel® Core i3/i5/i7/Pentium/Celeron Processors Support Sandy Bridge and Ivy Bridge CPU |
| Chipset |
Intel® H61 PCH |
| DRAM |
2 x 240pin DDR3 1666/1333MHz DIMM up to 16GB |
| BIOS |
32Mb AMI Flash ROM |
| Power Supply |
Standard ATX power |
| Watchdog |
Watchdog timer function |
| Dimension |
244mm x 220mm |
| >> I/O Ports |
| HDD |
4 x SATA 2.0 |
| Serial Port |
9 x RS232 + 1 x RS232/422/485 (Auto Flow control function) COM ports |
| Parallel |
1 x LPT port support with ECP/EPP/SPP mode |
| Audio |
Realtek ALC662 High Definition Audio, line-out, line-in and MIC |
| Keyboard/Mouse |
1 x Mini-DIN port for PS/2 Keyboard and Mouse |
| LAN |
2 x Realtek 8111E PCI-E Gigabit controller |
| USB |
10 x USB2.0 |
| Digital I/O |
1 x 8 bits Digital I/O connector |
| Expansion |
1 x PCI-Ex16, 1 x PCI-E x1, 2 x PCI slots |
| >> Display |
| Graphics |
Intel® Integrated Graphics Engine with HD3000/HD2000 |
| VGA |
1 x VGA port ,2048x1536 @ 75Hz max Resolution |
| DVI-D |
1 x DVI-D port ,1920 x 1200@60Hz max Resolution |
| >> Environment |
| Operation Temperature |
0°~60°C (32°~140°F) |
| Humidity |
10~90% |
