当PLC/HMI拥有了彩色显示屏
发布时间:2008-08-12 来源:www.cechina.cn
  摘要:使用彩色显示屏后,机器制造可以拥有更加详尽的内容、更加生动的画面、更加醒目的警报等等。总而言之,彩色显示屏照亮了整个系统。Unitronics最新Vision350将所有这些优势包含在一个紧凑的PLC/接口设备中。
  Vision350加配了彩色触摸屏、先进的处理器与不同的I/O选项。能适应大多数TCP/IP或串行协议,同时提供其它的通信模式,如通过TCP/IP的以太网连接、GSM/SMS/GPRS、Modbus总线、CANopen总线,以及免费的远程访问应用。
  英文全文如下:
  Color displays enable machine builders to reveal greater details, display vivid, attention-grabbing alarms, and in general brighten up their systems. Unitronics’ new Vision350 incorporates all these color advantages into a compact all-in-one PLC/interface device.
  Unitronics'Vision350combinesafullyfunctioningHMIwithacompactPLCreducingcostscabinetspaceandwiring
  Unitronics' Vision 350 combines a fully functioning HMI witha compact PLC, reducing costs, cabinet space and wiring.
  This PLC and enhanced HMI is equipped with a color touchscreen, an improved processor, and diverse I/O options. Adaptable to most TCP/IP or serial protocols, the Vision350 offers exceptional communication features, such as Ethernet connection via TCP/IP, GSM/SMS/GPRS, MODBUS, CANopen and UniCAN, and also includes free remote access utilities.
  On the surface, the Vision350’s fully functioning HMI features a 3.5-in. color touchscreen display capable of supporting 3 MB of application memory for images and 512 KB for fonts, which allows about 250 images and 1,024 displays per application. Five programmable keys allow customization of customer logo, function and layout (keys could be labeled as arrow keys using a supplied keypad slide). Enhanced programming features include trending, built-in alarm screens and easy HMI language support.
  This high-speed PLC allows for 1 MB of logic memory, and a scan time of 15μsec per 1 KB of typical application. It also offers up to 38 onboard digital and analog I/Os that can expand up to 166, and includes digital and analog I/Os, temperature measurement and load cell inputs, plus recipe programming via 120 KB of internal datalogging. At 24 PID loops with auto-tune, plus onboard Thermocouple and PT100 inputs, the Vision350 incorporates a full function temperature controller.
标签:彩色显示屏,PLC,HMI
